[其他模拟产品-信号链] 16位500kSPS模数转换方案
2544|2
 楼主| kakio 发表于 2011-12-23 17:14 | 显示全部楼层 |阅读模式
TI 公司的ADS8331 是低功耗16位500kSPS模数转换器(ADC),包括16位基于电容的SAR ADC和取样保持电路,同时具有单极4:1复接器的输入.ADS8331工作电压2.7V-5.5V,主要用在通信,传感器接口,医疗设备,磁力计,工业过程控制,数据采集系统和自动测试设备(ATE).本文介绍ADS8331主要特性, 方框图, 单极和双极输入驱动配置, 采用菊花链模式的多个转换器连接图以及典型应用电路.
The ADS8331 is a low-power, 16-bit, 500k samples-per-second (SPS) analog-to-digital converter (ADC) with a unipolar, 4-to-1 multiplexer (mux) input. The device includes a 16-bit capacitor-based successive approximation register (SAR) ADC with inherent sample and hold.
The ADS8332 is based on the same core and includes a unipolar 8-to-1 input mux. Both devices offer a high-speed, wide-voltage serial interface and are capable of daisy-chain operation when multiple converters are used.
These converters are available in 24-pin, 4x4 QFN and 24-pin TSSOPTSSOP (PW) package available Q1, 2010. packages and are fully specified for operation over the industrial –40℃ to +85℃ temperature range.
ADS8331主要特性:
Low-Power, Flexible Supply Range:
2.7V to 5.5V Analog Supply
8.7mW (250kSPS in Auto-Nap Mode, VA = 2.7V, VBD = 1.65V)
14.2mW (500kSPS, VA = 2.7V, VBD = 1.65V)
Up to 500kSPS Sampling Rate
Excellent DC Performance:
±1.2 LSB Typ, ±2 LSB Max INL at 2.7V
±0.6 LSB Typ, –1.0/1.5 LSB Max DNL at 2.7V
16-Bit NMC Over Temperature
Excellent AC Performance at 5V, fIN = 1kHz:
91.5dB SNR, 101dB SFDR, –100dB THD
Flexible Analog Input Arrangement:
On-Chip 4-/8-Channel Mux with Breakout
Auto/Manual Channel Select and Trigger
Other Hardware Features:
On-Chip Conversion Clock (CCLK)
Software/Hardware Reset
Programmable Status/Polarity EOC/INT
Daisy-Chain Mode
Global CONVST (Independent of CS)
ADS8331应用:
• Communications
• Transducer Interfaces
• Medical Instruments
• Magnetometers
• Industrial Process Control
• Data Acquisition Systems
• Automatic Test Equipment
图1.ADS8331方框图
图2.单极输入驱动配置
图3.双极输入驱动配置
图4.采用菊花链模式的多个转换器连接图
aass1 发表于 2011-12-23 17:17 | 显示全部楼层
了解了 原来是这样样
对我很有帮助
