仿真对比了PWM相关的寄存器,所有数据都正常,但是通道1与2就是没有输出。
void PWM_Config(void)
U32 PCLK1_fosc = 24000000L; //PCLK实际频率
GPIO_InitTypeDef GPIO_InitStructure; //IO口配置
TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; //定时器初始化结构
TIM_OCInitTypeDef TIM_OCInitStructure; //通道输出初始化结构
TIM_DeInit(TIM3);
TIM_DeInit(TIM4);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3|RCC_APB1Periph_TIM4, ENABLE); //①使能定时器 3 时钟
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE); //①使能 GPIO 和 AFIO 复用功能时钟
// Config PWM IO
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
GPIO_Init(GPIOA, &GPIO_InitStructure);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_6;
GPIO_Init(GPIOB, &GPIO_InitStructure);
//TIM3 TIM4通道初始化
TIM_TimeBaseStructure.TIM_Period = 3000; //设置在自动重装载周期值
TIM_TimeBaseStructure.TIM_Prescaler =0; //设置预分频值
TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM 向上计数模式
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //③初始化 TIMx
TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //③初始化 TIMx
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //选择 PWM 模式 1
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low; //输出极性低
TIM_OCInitStructure.TIM_Channel = TIM_Channel_1;
TIM_OCInit(TIM3, &TIM_OCInitStructure); //通道初始化
TIM_OCInitStructure.TIM_Channel = TIM_Channel_2;
TIM_OCInitStructure.TIM_Channel = TIM_Channel_3;
TIM_OCInitStructure.TIM_Channel = TIM_Channel_4;
TIM_OCInit(TIM4, &TIM_OCInitStructure);
TIM_ARRPreloadConfig(TIM3, ENABLE); //使能预装载寄存器
TIM_ARRPreloadConfig(TIM4, ENABLE); //使能预装载寄存器
TIM_Cmd(TIM3, ENABLE); //使能 TIM3
TIM_Cmd(TIM4, ENABLE); //使能 TIM4
