flush_cache_all() API consuming 200+ microseconds.
328|0
 楼主| 没名字的人 发表于 2018-9-9 10:18 | 显示全部楼层 |阅读模式
Is this is normal behavior? Or suggest any other alternative.
Since flush_cache_all() consuming major portion of total execution time, I couldn\'t proceed with this. Is there any other way, which helps to clean cache area related to a particular kernel program space.
Note : Cortex A17 core, 1.25 GHz , supporting 32 KB I-cache, 32 KB D-cache, and 256 KB L2 cache, ARM@big-LITTLE architecture
