请教: 加法器IP例化后出错.
3005|5
 楼主| nongfuxu 发表于 2012-1-10 12:33 | 显示全部楼层 |阅读模式
请教: 加法器IP例化后出错.
怎么处理啊?
1)加法器例化
c_add_12int_12uint D4 (
  .clk(sys_clk),
  .sclr(rst),
  .s(pre_output_Chb),
  .a(multiplier_output),
  .b(selector_out)
2)出错信息
ERROR:NgdBuild:604 - logical block 'D4/D4' with type 'c_add_12int_12uint' could
   not be resolved. A pin name misspelling can cause this, a missing edif or ngc
   file, case mismatch between the block name and the edif or ngc file name, or
   the misspelling of a type name. Symbol 'c_add_12int_12uint' is not supported
   in target 'spartan3e'.
 楼主| nongfuxu 发表于 2012-1-10 12:34 | 显示全部楼层
在线急等中
 楼主| nongfuxu 发表于 2012-1-10 13:23 | 显示全部楼层
c_add_12int_12uint 是在同一芯片型号下用ISE 13.2 Core Generator发生的.
所选芯片型号是spartan3e 的xc3s250e-5vq100
不明白为什么"Symbol 'c_add_12int_12uint' is not supported  in target 'spartan3e'."会出现.
 楼主| nongfuxu 发表于 2012-1-10 13:53 | 显示全部楼层
估计是否是IP文件与项目文件没有放在同一个文件夹
GoldSunMonkey 发表于 2012-1-10 23:12 | 显示全部楼层
Please verify that the called out netlist file is located in the macro search path or project directory.
To set the macro search path, following these steps in ISE:
1. Select the top-level source in the Source window.
2. Right-click "Implementation Process" in the Process window and select "Properties."
3. Select the "Translate Properties tab." The Macro Search Path option is available.
 楼主| nongfuxu 发表于 2012-1-11 01:55 | 显示全部楼层
这么多洋文,难看啦
个人签名:是不是经济不KUA,房价下不来? 高房价只能带来“实体经济挤出效应”。
417
