[STM8] STM8L之timer2产生PWM
643|5
 楼主| tpgf 发表于 2020-10-12 11:56 | 显示全部楼层 |阅读模式
实验步骤
1、工程中添加自己写的定时器2的驱动
1)写一个驱动GUA_Timer2_PWM.c (存放在工程的USER文件夹中)
  • //name:             GUA_Timer2_PWM.c
  • //introduce:        定时器2的PWM驱动
  • //author:           甜甜的大香瓜
  • //email:            897503845@qq.com
  • //QQ group          香瓜单片机之STM8/STM32(164311667)
  • //changetime:       2016.12.01
  • #include "stm8l10x.h"
  • #include "GUA_Timer2_PWM.h"
  • /*********************宏定义************************/
  • #ifndef U8
  • typedef unsigned char U8;
  • #endif
  • #ifndef U16
  • typedef unsigned short U16;
  • #endif
  • #ifndef U32
  • typedef unsigned long U32;
  • #endif
  • //红外引脚宏
  • #define GUA_TIMER2_PWM_PORT             GPIOB
  • #define GUA_TIMER2_PWM_PIN              GPIO_Pin_0
  • #define GUA_TIMER2_PWM_MODE             GPIO_Mode_Out_PP_High_Fast
  • //红外开关宏
  • #define GUA_TIMER2_PWM_ON               SET     //高电平开
  • #define GUA_TIMER2_PWM_OFF              RESET   //低电平关
  • //name:             GUA_Timer2_PWM_Status
  • //introduce:        定时器2的PWM开关
  • //parameter:        nGUA_Timer2_PWM_Status: GUA_TIMER2_PWM_STATUS_ON or GUA_TIMER2_PWM_STATUS_OFF
  • //return:           none
  • //author:           甜甜的大香瓜
  • void GUA_Timer2_PWM_Status(U8 nGUA_Timer2_PWM_Status)
  •   //打开PWM
  •   if(nGUA_Timer2_PWM_Status == GUA_TIMER2_PWM_STATUS_ON)
  •     TIM2_CtrlPWMOutputs(ENABLE);
  •     //GPIO_WriteBit(GUA_TIMER2_PWM_OFF, GUA_TIMER2_PWM_PIN, GUA_TIMER2_PWM_ON);
  •   //关闭PWM
  •   else
  •     TIM2_CtrlPWMOutputs(DISABLE);
  •     GPIO_WriteBit(GUA_TIMER2_PWM_PORT, GUA_TIMER2_PWM_PIN, GUA_TIMER2_PWM_OFF);
  • //name:             GUA_Timer2_PWM_SetDutyCycle
  • //introduce:        定时器2的PWM设置占空比
  • //parameter:        nGUA_Timer2_PWM_DutyCycle: 0~100为0%~100%
  • //return:           none
  • //author:           甜甜的大香瓜
  • void GUA_Timer2_PWM_SetDutyCycle(U8 nGUA_Timer2_PWM_DutyCycle)
  •   TIM2_SetCompare1(GUA_TIMER2_PWM_FREQUENCY_VALUE*nGUA_Timer2_PWM_DutyCycle/100);
  • //name:             GUA_Timer2_PWM_Init
  • //introduce:        定时器2的PWM初始化
  • //parameter:        none
  • //return:           none
  • //author:           甜甜的大香瓜
  • void GUA_Timer2_PWM_Init(void)
  •   //PB0通道IO配置为输出
  •   GPIO_Init(GUA_TIMER2_PWM_PORT, GUA_TIMER2_PWM_PIN, GUA_TIMER2_PWM_MODE);
  •   //时钟配置
  •   CLK_PeripheralClockConfig(CLK_Peripheral_TIM2,ENABLE);
  •   //配置
  •   TIM2_DeInit();        //复位
  •   TIM2_TimeBaseInit(TIM2_Prescaler_1, TIM2_CounterMode_Up, GUA_TIMER2_PWM_FREQUENCY_VALUE);                     //每26us定时重新计数一次,38K
  •   TIM2_OC1Init(TIM2_OCMode_PWM2, TIM2_OutputState_Enable, 0, TIM2_OCPolarity_High, TIM2_OCIdleState_Reset);     //先空闲后运行的模式、输出使能、占空比初始化为0、运行时为高、死区时为低
  •   TIM2_Cmd(ENABLE);        //使能定时器2
  •   //关闭PWM
  •   GUA_Timer2_PWM_Status(GUA_TIMER2_PWM_STATUS_OFF);
这里总计数值为26us,占空比暂时初始化为0%。
注意,关闭PWM时需要把IO口置低,否则红外射线会一直发出会导致功耗高。
 楼主| tpgf 发表于 2020-10-12 11:57 | 显示全部楼层
2)写一个驱动头文件GUA_Timer2_PWM.h(存放在工程的USER文件夹中)
  • //name:             GUA_Timer2_PWM.h
  • //introduce:        定时器2的PWM驱动的头文件
  • //author:           甜甜的大香瓜
  • #ifndef _GUA_TIMER2_PWM_H_
  • #define _GUA_TIMER2_PWM_H_
  • //PWM的开关宏
  • #define GUA_TIMER2_PWM_STATUS_ON                0       //PWM打开
  • #define GUA_TIMER2_PWM_STATUS_OFF               1       //PWM关闭
  • //PWM的频率值
  • #define GUA_TIMER2_PWM_FREQUENCY_VALUE          16*26   //26us为一个周期
  • /*********************外部函数声明************************/
  • void GUA_Timer2_PWM_Status(unsigned char nGUA_Timer2_PWM_Status);
  • void GUA_Timer2_PWM_SetDutyCycle(unsigned char nGUA_Timer2_PWM_DutyCycle);
  • void GUA_Timer2_PWM_Init(void);
  • #endif
3)工程中添加 GUA_Timer2_PWM .c
4)添加驱动的路径
$PROJ_DIR$\..\USER   注意USER文件夹是与“Project”等文件夹同级的自定义文件,用于存放香瓜写的代码。
2、添加库的驱动
1)添加库的驱动文件
3、应用层中调用
1)添加头文件(main.c中)
2)初始化(main.c的main函数中)
  •   //定时器2的PWM初始化
  •   GUA_Timer2_PWM_Init();
3)测试代码(可以自行放置在不同按键处理代码中)
①开启50%占空比的PWM
  •   GUA_Timer2_PWM_SetDutyCycle(50);
  •   GUA_Timer2_PWM_Status(GUA_TIMER2_PWM_STATUS_ON);
②关闭PWM
开启60%占空比的PWM
  •   GUA_Timer2_PWM_SetDutyCycle(60);
zhuotuzi 发表于 2020-10-12 11:57 | 显示全部楼层
感谢分享啊。
 楼主| tpgf 发表于 2020-10-12 11:58 | 显示全部楼层
4、复用IO口为timer2
stm8的复用功能比较特殊,需要手动修改,香瓜在此入坑了两天。
1)点开工程的ST-LINK下的Option Bytes(网上有些资料显示必须在仿真模式下,香瓜实测不一定要在仿真模式下)
2)配置并保存
3)形成.obc的配置文件
4)使工程能够自动加载保存的配置文件
5)rebuild all。
实验结果
用逻辑分析仪连接PB0,分别抓取三个测试代码的波形,实验结果如下:
1、开启50%占空比的PWM
可见PB0产生了38.647K的方波,占空比为13/25.875(约为50.2%)。
2、关闭PWM
无产生波形
3、开启60%占空比的PWM
可见PB0产生了38.647K的方波,占空比为15.5/25.875(约为59.9%)。
因此,实验成功。
