[RISC-V MCU 应用开发]
【RISC-V MCU CH32V103测评】 环境配置与第一个工程1
883|1
昱枫|  楼主 | 2020-10-30 23:03 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
新建开发环境相关这个就不做说明,具体参考这个
https://bbs.21ic.com/icview-3037572-1-1.html
CH32V103 架构
板卡简介
硬件电路  烧录接口与串口
建立完成工程,就自动有一个ADC采用实时串口输出Demo
主函数
#include "debug.h"
/* Global Variable */
u16 TxBuf[1024];
* Function Name  : ADC_Function_Init
* Description    : Initializes ADC collection.
* Input          : None
* Return         : None
void ADC_Function_Init(void)
        ADC_InitTypeDef ADC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE );
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1, ENABLE );
        RCC_ADCCLKConfig(RCC_PCLK2_Div8);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        ADC_DeInit(ADC1);
        ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
        ADC_InitStructure.ADC_ScanConvMode = DISABLE;
        ADC_InitStructure.ADC_ContinuousConvMode = ENABLE;
        ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None;
        ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
        ADC_InitStructure.ADC_NbrOfChannel = 1;
        ADC_Init(ADC1, &ADC_InitStructure);
        ADC_DMACmd(ADC1, ENABLE);
        ADC_Cmd(ADC1, ENABLE);
        ADC_ResetCalibration(ADC1);
        while(ADC_GetResetCalibrationStatus(ADC1));
        ADC_StartCalibration(ADC1);
        while(ADC_GetCalibrationStatus(ADC1));
* Function Name  : Get_ADC_Val
* Description    : Returns ADCx conversion result data.
* Input          : ch: ADC channel.
*                    ADC_Channel_0: ADC Channel0 selected.
*                    ADC_Channel_1: ADC Channel1 selected.
*                    ADC_Channel_2: ADC Channel2 selected.
*                    ADC_Channel_3: ADC Channel3 selected.
*                    ADC_Channel_4: ADC Channel4 selected.
*                    ADC_Channel_5: ADC Channel5 selected.
*                    ADC_Channel_6: ADC Channel6 selected.
*                    ADC_Channel_7: ADC Channel7 selected.
*                    ADC_Channel_8: ADC Channel8 selected.
*                    ADC_Channel_9: ADC Channel9 selected.
*                    ADC_Channel_10: ADC Channel10 selected.
*                    ADC_Channel_11: ADC Channel11 selected.
*                    ADC_Channel_12: ADC Channel12 selected.
*                    ADC_Channel_13: ADC Channel13 selected.
*                    ADC_Channel_14: ADC Channel14 selected.
*                    ADC_Channel_15: ADC Channel15 selected.
*                    ADC_Channel_16: ADC Channel16 selected.
*                    ADC_Channel_17: ADC Channel17 selected.
* Return         : val: The Data conversion value.
u16 Get_ADC_Val(u8 ch)
        u16 val;
        ADC_RegularChannelConfig(ADC1, ch, 1, ADC_SampleTime_239Cycles5 );
        ADC_SoftwareStartConvCmd(ADC1, ENABLE);
        while(!ADC_GetFlagStatus(ADC1, ADC_FLAG_EOC ));
        val = ADC_GetConversionValue(ADC1);
        return val;
* Function Name  : DMA_Tx_Init
* Description    : Initializes the DMAy Channelx configuration.
* Input          : DMA_CHx:
*                    x can be 1 to 7.
*                  ppadr: Peripheral base address.
*                  memadr: Memory base address.
*                  bufsize: DMA channel buffer size.
* Return         : None
void DMA_Tx_Init( DMA_Channel_TypeDef* DMA_CHx, u32 ppadr, u32 memadr, u16 bufsize)
        DMA_InitTypeDef DMA_InitStructure;
        RCC_AHBPeriphClockCmd( RCC_AHBPeriph_DMA1, ENABLE );
        DMA_DeInit(DMA_CHx);
        DMA_InitStructure.DMA_PeripheralBaseAddr = ppadr;
        DMA_InitStructure.DMA_MemoryBaseAddr = memadr;
        DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
        DMA_InitStructure.DMA_BufferSize = bufsize;
        DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
        DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
        DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
        DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
        DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
        DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
        DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
        DMA_Init( DMA_CHx, &DMA_InitStructure );
* Function Name  : main
* Description    : Main program.
* Input          : None
* Return         : None
int main(void)
        u16 i;
        Delay_Init();
        USART_Printf_Init(115200);
        printf("SystemClk:%d\r\n",SystemCoreClock);
    ADC_Function_Init();
        DMA_Tx_Init( DMA1_Channel1, (u32)&ADC1->RDATAR, (u32)TxBuf, 1024 );
        DMA_Cmd( DMA1_Channel1, ENABLE );
        ADC_RegularChannelConfig(ADC1, ADC_Channel_2, 1, ADC_SampleTime_239Cycles5 );
    Delay_Ms(50);
        ADC_SoftwareStartConvCmd(ADC1, DISABLE);
        for(i=0; i<1024; i++)
                printf( "%04d\r\n", TxBuf[i] );
                Delay_Ms(10);
        while(1);
接线图
烧录
输出效果
CH32V103电路图说明以及相关应用Demo 例子程序
CH32V103数据手册
游客,如果您要查看本帖隐藏内容请回复
lovexulu| | 2020-11-1 11:12 | 只看该作者
学习学习
