[电源技术资料]
代理天钰FR9833降压转换器芯片
522|0
kuake0618|  楼主 | 2020-11-5 17:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  Description
   The FR9833 is a synchronous step-down DC/DC converter that provides wide 6V to 32V input voltage range and 3A continuous load current capability.
   The FR9833 fault protection includes cycle-by-cycle current limit, input UVLO, output over voltage protection and thermal shutdown. Besides, adjustable soft-start function prevents inrush current at turn-on. This device uses current mode control scheme which provides fast transient response. Internal compensation function reduces external compensation components and simplifies the design process. In shutdown mode, the supply current is less than 1μA.
   The FR9833 is available in an SOP-8 (exposed pad) packages, provides a very compact system solution and good thermal conductance. It is RoHS compliant and 100% lead (Pb) free.
  Features
 Low R DS(ON) Integrated Power MOSFET(120mΩ/90mΩ)
 Wide Input Voltage Range: 6V to 32V
 Adjustable Output Voltage from 0.925V to 16V
 3A Output Current
 Fixed 340kHz Switching Frequency
 Current Mode Operation
 Internal Compensation Function
 Adjustable Soft-Start
 Cycle-by-Cycle Current Limit
 Input Under Voltage Lockout
 Over Voltage Protection
 Over Temperature Protection with Auto Recovery
 SOP-8 Exposed Pad Package
  Applications
 Car Charger
 LCD Display, TV
 Distributed Power System
 Networking, XDSL Modem
