Bcrypt hashedSecret too short to be a bcrypted password
1530|0
 楼主| keer_zu 发表于 2020-11-10 17:54 | 显示全部楼层 |阅读模式
https://stackoverflow.com/questi ... a-bcrypted-password
bcrypt produces hashes of 59-60 bytes (see this answer for details). In order to store the hash as varchar, you need to ensure its size is sufficient. According to your comment, you use varchar(50), which is not enough, and that's the reason that changing its size fixed your problem.
1493
