[STM32F0]
STM32F072产生不了PWM
934|16
juventus9554|  楼主 | 2021-5-9 21:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
int main(void)
        RCC_ClocksTypeDef  RCC_Clocks;
        uint32_t sys;
        RCC_HSI_Configuration();
        UART1_Configuration();//波特率9600
        LED_Init();
        TIM1_PWM_Init(23,1);
        while (1)
                Clr_LED_1;
                Clr_LED_2;
                //TIM1_Set_PWM();
                //Clr_LED_4;
void TIM1_PWM_Init(uint16_t arr,uint16_t psc) //产生pwm
        TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
        TIM_OCInitTypeDef TIM_OCInitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
        RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOF, ENABLE);//使能GPIO外设和AFIO复用功能模块时钟使能
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
        GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
        GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP ;
        GPIO_Init(GPIOF, &GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOF, GPIO_PinSource0, GPIO_AF_1);
        TIM_TimeBaseStructure.TIM_Period = arr;//设置在下一个更新事件装入活动的自动重装载寄存器周期的值
        TIM_TimeBaseStructure.TIM_Prescaler =0;//设置用来作为TIMx时钟频率除数的预分频值
        TIM_TimeBaseStructure.TIM_ClockDivision = 0;//设置时钟分割:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;//TIM向上计数模式
        TIM_TimeBaseStructure.TIM_RepetitionCounter = 0;
        TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);//根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;//PWM模式1
        TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;//正向通道有效
        TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;//反向通道无效
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCPolarity_Low;
    TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
    TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCIdleState_Reset;
        TIM_OCInitStructure.TIM_Pulse = 100;
        TIM_OC1Init(TIM1,&TIM_OCInitStructure); //通道1
        TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable);
        TIM_CtrlPWMOutputs(TIM1,ENABLE);
        TIM_ARRPreloadConfig(TIM1, ENABLE);//使能TIMx在ARR上的预装载寄存器
        TIM_Cmd(TIM1, ENABLE);//使能TIMx外设
stly| | 2021-5-9 21:57 | 只看该作者
如果其它配置【时钟、GPIO、TIM外设时钟]都配好了,你现在ARR=23,而CCR又等于100,此时输出的是固定的低电平
supernan| | 2021-5-9 21:59 | 只看该作者
结合你当前极性选择
jiajs| | 2021-5-9 22:03 | 只看该作者
你把ARR调整大点,或者把CCR调得比Arr小,你看看还有无波形输出?
juventus9554|  楼主 | 2021-5-9 22:10 | 只看该作者
应该是我用的IO口不对,定时器1复用不在PF0上
juventus9554|  楼主 | 2021-5-9 22:13 | 只看该作者
stly| | 2021-5-9 22:16 | 只看该作者
强烈建议使用STM32CUBEMX进行配置,就可以绕开基本的GPIO/时钟这些配置错误。
juventus9554|  楼主 | 2021-5-9 22:18 | 只看该作者
void TIM2_PWM_Init() //产生pwm
        float TimerPeriod = 0;
        uint16_t Channel1Pulse = 0, Channel2Pulse = 0, Channel3Pulse = 0, Channel4Pulse = 0;
        /* GPIOA Clocks enable */
        RCC_AHBPeriphClockCmd( RCC_AHBPeriph_GPIOA, ENABLE);
        /* GPIOA Configuration: Channel 1, 2, 3 and 4 as alternate function push-pull */
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_PinAFConfig(GPIOA, GPIO_PinSource2, GPIO_AF_2);
        /* TIM1 clock enable */
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2 , ENABLE);
        /* Time Base configuration */
        TIM_TimeBaseStructure.TIM_Prescaler = 48-1;//预分频值
        TIM_TimeBaseStructure.TIM_Period = 500000;  //自动重装载值
        TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
        /* Channel 1, 2, 3 and 4 Configuration in PWM mode */
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;//设置输出极性
        TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
        TIM_OCInitStructure.TIM_Pulse = 100000;  //占空比时间
        TIM_OC3Init(TIM2, &TIM_OCInitStructure);
        /* TIM1 counter enable */
        TIM_Cmd(TIM2, ENABLE);
        /* TIM1 Main Output Enable */
        TIM_CtrlPWMOutputs(TIM2, ENABLE);
juventus9554|  楼主 | 2021-5-9 22:20 | 只看该作者
改用PA2,定时器TIM2,通道TIM2_CH3,可是也是产生不了pwm.是在是不知道哪出问题。
heweibig| | 2021-5-9 22:23 | 只看该作者
预分频系数和占空比的时间设置不正确
zhanghqi| | 2021-5-9 22:25 | 只看该作者
给的数值均超出了uint32_t的最大值。
juventus9554|  楼主 | 2021-5-9 22:27 | 只看该作者
搞定了,呵呵,犯了低级错误……
labasi| | 2021-6-2 18:21 | 只看该作者
极性改变了 波形会发生什么变化呢
paotangsan| | 2021-6-2 18:23 | 只看该作者
产生不产生的 跟占空比没有影响的
renzheshengui| | 2021-6-2 18:37 | 只看该作者
目前使用了复用 是吗
wakayi| | 2021-6-2 18:39 | 只看该作者
ARR是调节什么的呢
wowu| | 2021-6-2 18:40 | 只看该作者
检查一下时钟的配置
