pfc161+tm1651_04
661|0
 楼主| 34af9uc 发表于 2021-6-13 17:28 | 显示全部楼层 |阅读模式
qq, PFC, AN, IO, IDT, ST
/*****************pfc161+tm1651********************/
/******************20210608************************/
/****************qq:774145445**********************/
/****************快手:共同学习stm8*****************/
//               _______    ______
//          dio-|1 pb7  \_/  pb010|-clk
//              |2 vdd       gnd 9|
//        cs-||-|3 pa7       pa0 8|-hong
//          tk8-|4 pa6       pa4 7|-lv
//          tk9-|5_pa5_______pa3_6|-lan
//       5v
//  pb0--clk
//  pb7--dio
//       gnd
#include        "extern.h"
tm1651_clk                bit                pb.0;
tm1651_dio                bit                pb.7;
byte                tm1651_a0;
byte                tm1651_a1;
byte                tm1651_a2;
byte                tm1651_a3;
byte                tm1651_a4;
void                tm1651_yanshi();                //延时
void                tm1651_start();                        //起始信号
void                tm1651_data();                        //数据
void                tm1651_ack();                        //应答
void                tm1651_stop();                        //结束
void                tm1651_xianshi();                //显示
void                yanshi()
.delay 1000000;
void        FPPA0 (void)
.ADJUST_IC        SYSCLK=IHRC/4                //        SYSCLK=IHRC/4
$                tm1651_clk                out,high;                //输出,高
$                tm1651_dio                out,high;
//0x7e;0x30;0x6d;0x79;0x33;0x5b;0x5f;0x70;0x7f;0x7b;0x77;0x1f;0x4e;0x3d;0x4f;0x47;
while (1)
tm1651_a1                =0x7e;
tm1651_a2                =0x30;
tm1651_a3                =0x6d;
tm1651_a4                =0x79;
tm1651_xianshi();
yanshi();
tm1651_a1                =0x33;
tm1651_a2                =0x5b;
tm1651_a3                =0x5f;
tm1651_a4                =0x70;
tm1651_xianshi();
yanshi();
tm1651_a1                =0x7f;
tm1651_a2                =0x7b;
tm1651_a3                =0x77;
tm1651_a4                =0x1f;
tm1651_xianshi();
yanshi();
tm1651_a1                =0x4e;
tm1651_a2                =0x3d;
tm1651_a3                =0x4f;
tm1651_a4                =0x47;
tm1651_xianshi();
yanshi();
void                tm1651_yanshi()                //延时
.delay 50;
void                tm1651_start()                        //起始信号
tm1651_clk        =1;        tm1651_dio        =1;        tm1651_yanshi();
tm1651_clk        =1;        tm1651_dio        =0;        tm1651_yanshi();
void                tm1651_data()                        //数据
tm1651_clk                =0;        tm1651_yanshi();
if(tm1651_a0.0){tm1651_dio        =1;}        else{tm1651_dio        =0;}
nop;nop;nop;                //太快检测不到需要加延时
tm1651_clk                =1;        tm1651_yanshi();
if(tm1651_a0.1){tm1651_dio        =1;}        else{tm1651_dio        =0;}
nop;nop;nop;
if(tm1651_a0.2){tm1651_dio        =1;}        else{tm1651_dio        =0;}
nop;nop;nop;
if(tm1651_a0.3){tm1651_dio        =1;}        else{tm1651_dio        =0;}
nop;nop;nop;
if(tm1651_a0.4){tm1651_dio        =1;}        else{tm1651_dio        =0;}
nop;nop;nop;
if(tm1651_a0.5){tm1651_dio        =1;}        else{tm1651_dio        =0;}
nop;nop;nop;
if(tm1651_a0.6){tm1651_dio        =1;}        else{tm1651_dio        =0;}
nop;nop;nop;
if(tm1651_a0.7){tm1651_dio        =1;}        else{tm1651_dio        =0;}
nop;nop;nop;
tm1651_ack();
void                tm1651_ack()                //应答
byte                tm1651_ack_a1;
tm1651_ack_a1                =0;
$                tm1651_dio                in,pull;
tm1651_clk                =0;        tm1651_yanshi();                //第八个时钟的下降沿
while(tm1651_dio==1)                //检测低电平
        tm1651_ack_a1                ++;
        if(tm1651_ack_a1>150)                //退出条件(死机)
                $                tm1651_dio                out,low;
                return;
void                tm1651_stop()                        //结束
tm1651_clk                =0;        tm1651_dio                =0;        tm1651_yanshi();
void                tm1651_xianshi()                //显示
tm1651_start();
tm1651_a0        =0b0100_0000;        tm1651_data();                //写数据到显示寄存器,自动地址增加
tm1651_stop();
tm1651_start();
tm1651_a0        =0b1100_0000;        tm1651_data();                //设置地址00H
tm1651_a0                =tm1651_a1;        tm1651_data();
tm1651_a0                =tm1651_a2;        tm1651_data();
tm1651_a0                =tm1651_a3;        tm1651_data();
tm1651_a0                =tm1651_a4;        tm1651_data();
tm1651_stop();
tm1651_start();
tm1651_a0        =0b1000_1011;        tm1651_data();                //显示开,10/16
tm1651_stop();
tm165108.rar
1.11 KB, 下载次数: 6
319
