[应用相关] stm32 pwm 呼吸灯
733|1
 楼主| kxsi 发表于 2021-9-2 17:16 | 显示全部楼层 |阅读模式
#include "main.h"
#include "stm32f0xx_hal.h"
/* USER CODE BEGIN Includes */
int i=0;
/* USER CODE END Includes */
/* Private variables ---------------------------------------------------------*/
TIM_HandleTypeDef htim3;
UART_HandleTypeDef huart1;
/* USER CODE BEGIN PV */
/* USER CODE END PV */
/* Private function prototypes -----------------------------------------------*/
void SystemClock_Config(void);
static void MX_GPIO_Init(void);
static void MX_USART1_UART_Init(void);
static void MX_TIM3_Init(void);
void HAL_TIM_MspPostInit(TIM_HandleTypeDef *htim);
/* USER CODE BEGIN PFP */
/* USER CODE END PFP */
/* USER CODE BEGIN 0 */
//Öжϴ¦Àí
void HAL_GPIO_EXTI_Callback(uint16_t GPIO_Pin)
        HAL_GPIO_TogglePin(GPIOB, GPIO_PIN_1|GPIO_PIN_2);
//¶¨Ê±Æ÷×ÔÔöº¯Êý
void HAL_TIM_PeriodElapsedCallback(TIM_HandleTypeDef *htim)
        i++;
/* USER CODE END 0 */
  * @brief  The application entry point.
  * @retval None
int main(void)
  /* USER CODE BEGIN 1 */
  /* USER CODE END 1 */
  /* MCU Configuration----------------------------------------------------------*/
  /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
  HAL_Init();
  /* USER CODE BEGIN Init */
  /* USER CODE END Init */
  SystemClock_Config();
  /* USER CODE BEGIN SysInit */
  /* USER CODE END SysInit */
  MX_GPIO_Init();
  MX_USART1_UART_Init();
  MX_TIM3_Init();
  /* USER CODE BEGIN 2 */
        HAL_TIM_Base_Start_IT(&htim3);
        HAL_TIM_PWM_Start(&htim3, TIM_CHANNEL_3);
  /* USER CODE END 2 */
  /* Infinite loop */
  /* USER CODE BEGIN WHILE */
  while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
                /*uint8_t data = 0;
                HAL_UART_Receive(&huart1, &data, 1, 0);
                if(data == 'l')
                        HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2, GPIO_PIN_RESET);
                        HAL_UART_Transmit(&huart1, &data, 1, 0);
                else if(data == 'h')
                        HAL_GPIO_WritePin(GPIOB, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_2, GPIO_PIN_SET);
                int j;
                for(j=100;j>=50;j--)
                        __HAL_TIM_SET_COMPARE(&htim3, TIM_CHANNEL_3, j);
                        HAL_Delay(15);
                for(j=50;j<=100;j++)
                        HAL_Delay(15);
  /* USER CODE END 3 */
mutable 发表于 2021-9-2 19:38 | 显示全部楼层
是用的什么片子?
