* 函 数 名: uart_init
* 函数说明: 初始化串口通讯引脚 ,串口配置初始化,中断优先级配置
* 输 入:           bound 串口通讯波特率
* 返 回:    无
void uart_init(u32 bound)
     //GPIO端口设置
         USART_InitTypeDef USART_InitStructure;
         NVIC_InitTypeDef NVIC_InitStructure;
         RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);        //使能 USART3 时钟
         USART_DeInit(USART3);  //复位串口3
         GPIO_InitStructure.GPIO_Pin =GPIO_Pin_12;          //PB12 max485 R/W Enable
         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;        //复用推挽输出
         GPIO_Init(GPIOB, &GPIO_InitStructure);
        //USART3_TX   PB10
         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
         GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;        //复用推挽输出
         //USART3_RX          PB11
         GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
         GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;//浮空输入
     //USART 初始化设置
         USART_InitStructure.USART_BaudRate = bound;//一般设置为4800;
         USART_InitStructure.USART_WordLength = USART_WordLength_8b;//字长为8位数据格式
         USART_InitStructure.USART_StopBits = USART_StopBits_1;//一个停止位
         USART_InitStructure.USART_Parity = USART_Parity_No;//无奇偶校验位
         USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;//无硬件数据流控制
           USART_InitStructure.USART_Mode =  USART_Mode_Tx;        //发模式
     USART_Init(USART3, &USART_InitStructure); //初始化串口
     //Usart1 NVIC 配置
     NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn;
         NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=2 ;//抢占优先级2
         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;                //子优先级0
         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                        //IRQ通道使能
         NVIC_Init(&NVIC_InitStructure);        //根据指定的参数初始化VIC寄存器
     USART_Cmd(USART3, ENABLE);  //使能串口
* 函 数 名: USARTSendData
* 函数说明: 串口数据发送函数,在发送完数据后,再发送CRC校验码的高低字节
* 输 入:           USARTx 串口号   prSendData 发送数据的数组名   leng 长度
* 返 回:    无
void USARTSendData(USART_TypeDef* USARTx,u8 prSendData[],u8 leng)
        u8 tempcrcH,tempcrcL; //存储CRC校验码的高低字节
        u8 i;
        tempcrcH= (u8)((usMBCRC16(prSendData,leng)&0xff00)>>8) ;
        tempcrcL= (u8)(usMBCRC16(prSendData, leng)&0x00ff) ;
        for(i=0;i<leng;i++)
          USART_SendData(USARTx, prSendData);
           while(USART_GetFlagStatus(USART3,USART_FLAG_TC)!=SET);//等待发送结束
        USART_SendData(USARTx,tempcrcL);//计算发送数据的校验码低字节
        USART_SendData(USARTx,tempcrcH);//计算发送数据的校验码高字节
main()
      while(1)
                GPIO_ResetBits(GPIOB,GPIO_Pin_12); //485设为发送
                delay_ms(5);
                USARTSendData( USART3,SendDataBuf2,4);   //SendDataBuf2[4]={0x7c,0x00,0x00,0x00}
                USART_Cmd(USART3, DISABLE);
                USART3->DR=0;
                 GPIO_SetBits(GPIOB,GPIO_Pin_12); //485设为接收
                delay_ms(5);
