主机SPI0无法接收到从机SPI2数据,反之可以
5214|12
 楼主| Japloya 发表于 2021-11-25 23:33 | 显示全部楼层 |阅读模式
使用官方例程,修改了管脚。使用的设备是GD32F303CET6 48PIN的单片机
主SPI0发给从SPI2的数据接收正常
从SPI2发给主SPI0的数据不正常
代码如下
  1. #include "gd32f30x.h"
  2. #include "gd32f307c_eval.h"
  3. #define arraysize         10
  4. #define SET_SPI0_NSS_HIGH          gpio_bit_set(GPIOA,GPIO_PIN_4);
  5. #define SET_SPI0_NSS_LOW           gpio_bit_reset(GPIOA,GPIO_PIN_4);
  6. #define SET_SPI2_NSS_HIGH          gpio_bit_set(GPIOA,GPIO_PIN_15);
  7. #define SET_SPI2_NSS_LOW           gpio_bit_reset(GPIOA,GPIO_PIN_15);
  8. uint32_t send_n = 0, receive_n = 0;
  9. uint8_t spi0_send_array[arraysize] = {0xA1, 0xA2, 0xA3, 0xA4, 0xA5, 0xA6, 0xA7, 0xA8, 0xA9, 0xAA};
  10. uint8_t spi2_send_array[arraysize] = {0xB1, 0xB2, 0xB3, 0xB4, 0xB5, 0xB6, 0xB7, 0xB8, 0xB9, 0xBA};
  11. uint8_t spi0_receive_array[arraysize];
  12. uint8_t spi2_receive_array[arraysize];
  13. ErrStatus memory_compare(uint8_t* src, uint8_t* dst, uint8_t length);
  14. void rcu_config(void);
  15. void gpio_config(void);
  16. void spi_config(void);
  17. /*!
  18.     \brief      main function
  19.     \param[in]  none
  20.     \param[out] none
  21.     \retval     none
  22. */
  23. int main(void)
  24. {
  25.     /* init led2 and led3 */
  26.     gd_eval_led_init(LED2);
  27.     gd_eval_led_init(LED3);
  28.     /* peripheral clock enable */
  29.     rcu_config();
  30.     /* GPIO config */
  31.     gpio_config();
  32.     /* SPI config */
  33.     spi_config();
  34.     SET_SPI0_NSS_HIGH
  35.     /* SPI enable */
  36.     spi_enable(SPI2);
  37.     spi_enable(SPI0);
  38.     SET_SPI0_NSS_LOW
  39.     /* wait for transmit complete */
  40.     while(send_n < arraysize){
  41.         while(RESET == spi_i2s_flag_get(SPI2, SPI_FLAG_TBE));
  42.                                 spi_i2s_data_transmit(SPI2, spi2_send_array[send_n]);
  43.         while(RESET == spi_i2s_flag_get(SPI0, SPI_FLAG_TBE));
  44.         spi_i2s_data_transmit(SPI0, spi0_send_array[send_n++]);
  45.         while(RESET == spi_i2s_flag_get(SPI2, SPI_FLAG_RBNE));
  46.         spi2_receive_array[receive_n] = spi_i2s_data_receive(SPI2);
  47.         while(RESET == spi_i2s_flag_get(SPI0, SPI_FLAG_RBNE));
  48.         spi0_receive_array[receive_n++] = spi_i2s_data_receive(SPI0);
  49.     }
  50.     SET_SPI0_NSS_HIGH
  51.     /* compare receive data with send data */
  52.     if(memory_compare(spi2_receive_array, spi0_send_array, arraysize))
  53.         gd_eval_led_on(LED2);
  54.     else
  55.         gd_eval_led_off(LED2);
  56.     if(memory_compare(spi0_receive_array, spi2_send_array, arraysize))
  57.         gd_eval_led_on(LED3);
  58.     else
  59.         gd_eval_led_off(LED3);
  60.     while(1);
  61. }
  62. /*!
  63.     \brief      configure different peripheral clocks
  64.     \param[in]  none
  65.     \param[out] none
  66.     \retval     none
  67. */
  68. void rcu_config(void)
  69. {
  70.     rcu_periph_clock_enable(RCU_GPIOA);
  71.     rcu_periph_clock_enable(RCU_GPIOB);
  72.     rcu_periph_clock_enable(RCU_SPI0);
  73.     rcu_periph_clock_enable(RCU_SPI2);
  74.     rcu_periph_clock_enable(RCU_AF);
  75. }
  76. /*!
  77.     \brief      configure the GPIO peripheral
  78.     \param[in]  none
  79.     \param[out] none
  80.     \retval     none
  81. */
  82. void gpio_config(void)
  83. {
  84.     /* SPI0 GPIO config:SCK/PA5, MISO/PA6, MOSI/PA7 */
  85.     gpio_init(GPIOA, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_5 | GPIO_PIN_7);
  86.     gpio_init(GPIOA, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
  87.     /* PA3 as NSS */
  88.     gpio_init(GPIOA, GPIO_MODE_OUT_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
  89.
  90.     /* SPI2 GPIO config: NSS/PA4, SCK/PC10, MISO/PC11, MOSI/PC12 */
  91.     gpio_init(GPIOB, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_3 | GPIO_PIN_5);
  92.     gpio_init(GPIOB, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
  93.     gpio_init(GPIOB, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
  94. }
  95. /*!
  96.     \brief      configure the SPI peripheral
  97.     \param[in]  none
  98.     \param[out] none
  99.     \retval     none
  100. */
  101. void spi_config0(void)
  102. {
  103.     spi_parameter_struct spi_init_struct;
  104.     /* SPI0 parameter config */
  105.     spi_init_struct.trans_mode           = SPI_TRANSMODE_FULLDUPLEX;
  106.     spi_init_struct.device_mode          = SPI_SLAVE;
  107.     spi_init_struct.frame_size           = SPI_FRAMESIZE_16BIT;
  108.     spi_init_struct.clock_polarity_phase = SPI_CK_PL_LOW_PH_1EDGE;
  109.     spi_init_struct.nss                  = SPI_NSS_HARD;
  110.     spi_init_struct.prescale             = SPI_PSC_256;
  111.     spi_init_struct.endian               = SPI_ENDIAN_MSB;
  112.     spi_init(SPI0, &spi_init_struct);
  113.     /* SPI2 parameter config */
  114.     spi_init_struct.device_mode = SPI_MASTER;
  115.     spi_init_struct.nss         = SPI_NSS_SOFT;
  116.     spi_init(SPI2, &spi_init_struct);
  117. }
  118. void spi_config(void)
  119. {
  120.     spi_parameter_struct spi_init_struct;
  121.
  122.                 spi_i2s_deinit(SPI0);
  123.                 spi_i2s_deinit(SPI2);
  124.     /* SPI0 parameter config */
  125.     spi_init_struct.trans_mode           = SPI_TRANSMODE_FULLDUPLEX;
  126.     spi_init_struct.device_mode          = SPI_MASTER;
  127.     spi_init_struct.frame_size           = SPI_FRAMESIZE_16BIT;
  128.     spi_init_struct.clock_polarity_phase = SPI_CK_PL_LOW_PH_1EDGE;
  129.     spi_init_struct.nss                  = SPI_NSS_SOFT;
  130.     spi_init_struct.prescale             = SPI_PSC_256;
  131.     spi_init_struct.endian               = SPI_ENDIAN_MSB;
  132.     spi_init(SPI0, &spi_init_struct);
  133.     /* SPI2 parameter config */
  134.     spi_init_struct.device_mode = SPI_SLAVE;
  135.     spi_init_struct.nss         = SPI_NSS_SOFT;
  136.     spi_init(SPI2, &spi_init_struct);
  137. }
  138. /*!
  139.     \brief      memory compare function
  140.     \param[in]  src: source data pointer
  141.     \param[in]  dst: destination data pointer
  142.     \param[in]  length: the compare data length
  143.     \param[out] none
  144.     \retval     ErrStatus: ERROR or SUCCESS
  145. */
  146. ErrStatus memory_compare(uint8_t* src, uint8_t* dst, uint8_t length)
  147. {
  148.     while (length--){
  149.         if (*src++ != *dst++)
  150.             return ERROR;
  151.     }
  152.     return SUCCESS;
  153. }
逻辑分析仪抓的波形如下:
使用单步调试功能发现,调用 spi_i2s_data_transmit(SPI2, spi2_send_array[send_n]); 之后,SPI2寄存器SPI2_DATA依旧为0
天意无罪 发表于 2021-11-26 13:46 | 显示全部楼层
那检查一下从机的SPI代码是否有问题,用示波器看一下从机的数据输出IO有没有信号就知道了。
@Japloya :如果MISO口无信号,那只能说明代码确实还有问题,当然前提是你也确定硬件没问题。  发表于 2021-11-28 17:51
实在没看出来代码有啥问题。。。 实际的MISO口无输出  发表于 2021-11-28 17:36
秦生0303 发表于 2021-11-26 16:01 | 显示全部楼层
这种情况还是需要抓取一下从机数据是否发送,有个SPI的使用技巧,从机的时钟也是主机给的,你在读取从机的数据的时候需要先随意发送一个数据给时钟信号,你可以检查一下只读数据是无法读到的
可以看我的代码,主从机读写是交替的  发表于 2021-11-28 17:36
秦生0303 发表于 2021-11-26 16:03 | 显示全部楼层
还有一种方法验证,用IO模拟SPI,看收发是否正常,之后再检查上面一步
 楼主| Japloya 发表于 2021-11-27 23:59 | 显示全部楼层
这种情况还是需要抓取一下从机数据是否发送,有个SPI的使用技巧,从机的时钟也是主机给的,你在读取从机的 ...
从机就没发出来
 楼主| Japloya 发表于 2021-11-28 00:28 | 显示全部楼层
    \file    main.c
    \brief   SPI fullduplex communication use polling mode
    \version 2017-02-10, V1.0.0, firmware for GD32F30x
    \version 2018-10-10, V1.1.0, firmware for GD32F30x
    \version 2018-12-25, V2.0.0, firmware for GD32F30x
    \version 2020-09-30, V2.1.0, firmware for GD32F30x
    Copyright (c) 2020, GigaDevice Semiconductor Inc.
    Redistribution and use in source and binary forms, with or without modification,
are permitted provided that the following conditions are met:
    1. Redistributions of source code must retain the above copyright notice, this
       list of conditions and the following disclaimer.
    2. Redistributions in binary form must reproduce the above copyright notice,
       this list of conditions and the following disclaimer in the documentation
       and/or other materials provided with the distribution.
    3. Neither the name of the copyright holder nor the names of its contributors
       may be used to endorse or promote products derived from this software without
       specific prior written permission.
    THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT,
INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT
NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
OF SUCH DAMAGE.
    \param[in]  none
    \param[out] none
    \retval     none
int main(void)
    rcu_config();
    /* GPIO config */
    gpio_config();
    /* SPI config */
    spi_config();
    SET_SPI0_NSS_HIGH
    /* SPI enable */
    spi_enable(SPI2);
    spi_enable(SPI0);
    SET_SPI0_NSS_LOW
        spi_i2s_data_transmit(SPI2, 'A');//spi2_send_array[send_n]);
    SET_SPI0_NSS_HIGH
    else
    else
    while(1);
    \param[in]  none
    \param[out] none
    \retval     none
    \param[in]  none
    \param[out] none
    \retval     none
    /* PA3 as NSS */
    gpio_init(GPIOA, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_15);
void gpio_config0(void)
    gpio_init(GPIOA, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_5 | GPIO_PIN_7);
    gpio_init(GPIOA, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_6);
    /* PA3 as NSS */
    gpio_init(GPIOA, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
    gpio_init(GPIOB, GPIO_MODE_AF_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_3 | GPIO_PIN_5);
    gpio_init(GPIOB, GPIO_MODE_IN_FLOATING, GPIO_OSPEED_50MHZ, GPIO_PIN_4);
    gpio_init(GPIOA, GPIO_MODE_OUT_PP, GPIO_OSPEED_50MHZ, GPIO_PIN_15);
    \param[in]  none
    \param[out] none
    \retval     none
    spi_init_struct.frame_size           = SPI_FRAMESIZE_8BIT;
    \param[out] none
    while (length--){
            return ERROR;
    return SUCCESS;
 楼主| Japloya 发表于 2021-11-28 17:35 | 显示全部楼层
尝试直接拉高 MISO 对应的管脚,逻辑分析仪抓到的还是低电平
地瓜patch 发表于 2021-11-28 22:36 | 显示全部楼层
两条数据线加10k上拉试试
 楼主| Japloya 发表于 2021-11-28 22:42 | 显示全部楼层
找到原因了
PA15默认不是普通IO口,要remap一下,此贴终结。。。。 没仔细看PA15定义。。。
多谢大家
