- * Copyright (C) 2020, Huada Semiconductor Co., Ltd. All rights reserved.
- * This software component is licensed by HDSC under BSD 3-Clause license
- * (the "License"); You may not use this file except in compliance with the
- * License. You may obtain a copy of the License at:
- * opensource.org/licenses/BSD-3-Clause
- /** \file main.c
- ** \brief This sample demonstrates how to set GPIO as output function.
- ** - 2021-04-16 CDT first version for Device Driver Library of GPIO.
- * Include files
- #include "hc32_ddl.h"
- #include "ev_hc32f460_lqfp100_v1.h"
- #include "TIM_Measure.h"
- #include "arm_math.h"
- #include "arm_const_structs.h"
- * Local type definitions ('typedef')
- * Local pre-processor symbols/macros ('#define')
- #define LENGTH 1024
- #define DOUBLE_LENGTH 2*LENGTH
- #define FS 5000.0f
- * Global variable definitions (declared in header file with 'extern')
- * Local function prototypes ('static')
- * Local variable definitions ('static')
- float t = 0.0f;
- float CFFT_Inputbuf[DOUBLE_LENGTH]; //FFT输入数组
- float CFFT_Outputbuf[LENGTH]; //FFT输出数组
- float CFFT_x2_Inputbuf[DOUBLE_LENGTH]; //FFT输入数组
- float CFFT_x2_Outputbuf[LENGTH]; //FFT输出数组
- float CFFT_x4_Inputbuf[DOUBLE_LENGTH]; //FFT输入数组
- float CFFT_x4_Outputbuf[LENGTH]; //FFT输出数组
- float RFFT_Inputbuf[LENGTH]; //FFT输入数组
- float RFFT_Outputbuf[LENGTH]; //FFT输出数组
- float RFFT_Output_buf[LENGTH]; //FFT输出数组
- * Function implementation - global ('extern') and local ('static')
- ** \brief Main function of GPIO output
- ** \param None
- ** \retval int32_t Return value, if needed
- int32_t main(void)
- int i = 0;
- stc_clk_freq_t stc_clk;
- arm_rfft_fast_instance_f32 S1;
- arm_cfft_radix2_instance_f32 S2;
- arm_cfft_radix4_instance_f32 S4;
- BSP_CLK_Init();
- DDL_PrintfInit(BSP_PRINTF_DEVICE, BSP_PRINTF_BAUDRATE, BSP_PRINTF_PortInit);
- TIM_Measure_Init();
- CLK_GetClockFreq(&stc_clk);
- DDL_Printf("System Clock: %dMHz\n",stc_clk.sysclkFreq/1000/1000);
- DDL_Printf("\n");
- for(i = 0;i < LENGTH;i++)
- CFFT_Inputbuf[i << 1] = 10 + 4.5*arm_sin_f32(2*PI*i*200/ FS)+ 3.2*arm_sin_f32(2*PI*i*350/ FS);
- CFFT_Inputbuf[(i << 1) + 1] = 0;
- CFFT_x2_Inputbuf[i << 1] = 10 + 4.5*arm_sin_f32(2*PI*i*200/ FS)+ 3.2*arm_sin_f32(2*PI*i*350/ FS);
- CFFT_x2_Inputbuf[(i << 1) + 1] = 0;
- CFFT_x4_Inputbuf[i << 1] = 10 + 4.5*arm_sin_f32(2*PI*i*200/ FS)+ 3.2*arm_sin_f32(2*PI*i*350/ FS);
- CFFT_x4_Inputbuf[(i << 1) + 1] = 0;
- RFFT_Inputbuf[i << 1] = 10 + 4.5*arm_sin_f32(2*PI*i*200/ FS)+ 3.2*arm_sin_f32(2*PI*i*350/ FS);
- while(1)
- TIM_Measure_Start();
- arm_cfft_f32(&arm_cfft_sR_f32_len1024,CFFT_Inputbuf,0,1);
- TIM_Measure_Stop();
- t = Get_Time();
- DDL_Printf("arm_cfft_f32 use time: %fus\n",t*1000.0f);
- arm_cmplx_mag_f32(CFFT_Inputbuf,CFFT_Outputbuf,LENGTH);
- DDL_Printf("calc amp at base: %f,actual is 10\n",CFFT_Outputbuf[0]/LENGTH);
- DDL_Printf("calc amp at 200Hz: %f,actual is 4.5\n",CFFT_Outputbuf[(unsigned int)(200*LENGTH/FS) + 1]/(LENGTH/2.0f));
- DDL_Printf("calc amp at 350Hz: %f,actual is 3.2\n",CFFT_Outputbuf[(unsigned int)(350*LENGTH/FS) + 1]/(LENGTH/2.0f));
- DDL_Printf("\n");
- arm_cfft_radix2_init_f32(&S2,LENGTH,0,1);
- arm_cfft_radix2_f32(&S2,CFFT_x2_Inputbuf);
- t = Get_Time();
- DDL_Printf("arm_cfft_radix2_f32 use time: %fus\n",t*1000.0f);
- arm_cmplx_mag_f32(CFFT_x2_Inputbuf,CFFT_x2_Outputbuf,LENGTH);
- DDL_Printf("calc amp at base: %f,actual is 10\n",CFFT_x2_Outputbuf[0]/LENGTH);
- DDL_Printf("calc amp at 200Hz: %f,actual is 4.5\n",CFFT_x2_Outputbuf[(unsigned int)(200*LENGTH/FS) + 1]/(LENGTH/2.0f));
- DDL_Printf("calc amp at 350Hz: %f,actual is 3.2\n",CFFT_x2_Outputbuf[(unsigned int)(350*LENGTH/FS) + 1]/(LENGTH/2.0f));
- DDL_Printf("\n");
- arm_cfft_radix4_init_f32(&S4,LENGTH,0,1);
- arm_cfft_radix4_f32(&S4,CFFT_x4_Inputbuf);
- t = Get_Time();
- DDL_Printf("arm_cfft_radix4_f32 use time: %fus\n",t*1000.0f);
- arm_cmplx_mag_f32(CFFT_x4_Inputbuf,CFFT_x4_Outputbuf,LENGTH);
- DDL_Printf("calc amp at base: %f,actual is 10\n",CFFT_x4_Outputbuf[0]/LENGTH);
- DDL_Printf("calc amp at 200Hz: %f,actual is 4.5\n",CFFT_x4_Outputbuf[(unsigned int)(200*LENGTH/FS) + 1]/(LENGTH/2.0f));
- DDL_Printf("calc amp at 350Hz: %f,actual is 3.2\n",CFFT_x4_Outputbuf[(unsigned int)(350*LENGTH/FS) + 1]/(LENGTH/2.0f));
- DDL_Printf("\n");
- arm_rfft_fast_init_f32(&S1,LENGTH);
- arm_rfft_fast_f32(&S1,RFFT_Inputbuf,RFFT_Outputbuf,0);
- t = Get_Time();
- DDL_Printf("arm_rfft_fast_f32 use time: %fus\n",t*1000.0f);
- arm_cmplx_mag_f32(RFFT_Outputbuf,RFFT_Output_buf,LENGTH);
- DDL_Printf("calc amp at base: %f,actual is 10\n",RFFT_Output_buf[0]/LENGTH);
- DDL_Printf("calc amp at 200Hz: %f,actual is 4.5\n",RFFT_Output_buf[(unsigned int)(200*LENGTH/FS) + 1]/(LENGTH/2.0f));
- DDL_Printf("calc amp at 350Hz: %f,actual is 3.2\n",RFFT_Output_buf[(unsigned int)(350*LENGTH/FS) + 1]/(LENGTH/2.0f));
- DDL_Printf("\n");
- while(1);
- * EOF (not truncated)
不开启FPU:
开启FPU:
可以看出FPU和FLASH Cache对结果影响很大。不知为什么arm_rfft_fast_f32始终不能得到正确结果。
HC32F460_FFT.zip
(2.72 MB, 下载次数: 47)
