[活动专区] 【AT-START-F425测评】+ 驱动HT1621
1022|2
 楼主| 比神乐 发表于 2022-3-6 15:08 | 显示全部楼层 |阅读模式
今天搞了一一下HT1621
DA->B8,WR->B7,CS->B5
代码:
  1. #include "at32f425_board.h"
  2. #include "at32f425_clock.h"
  3. #include "stdio.h"
  4. #include "at32f425.h"
  5. /** @addtogroup AT32F425_periph_examples
  6.   * @{
  7.   */
  8. #define uchar unsigned char
  9. #define uint unsigned int
  10. /** @addtogroup 425_GPIO_led_toggle GPIO_led_toggle
  11.   * @{
  12.   */
  13. #define DA_PIN                         GPIO_PINS_8
  14. #define DA_GPIO                        GPIOB
  15. #define DA_GPIO_CRM_CLK                CRM_GPIOB_PERIPH_CLOCK
  16. #define WR_PIN                         GPIO_PINS_7
  17. #define WR_GPIO                        GPIOB
  18. #define WR_GPIO_CRM_CLK                CRM_GPIOB_PERIPH_CLOCK
  19. #define CS_PIN                         GPIO_PINS_5
  20. #define CS_GPIO                        GPIOB
  21. #define CS_GPIO_CRM_CLK                CRM_GPIOB_PERIPH_CLOCK
  22. #define DA_1 gpio_bits_set(GPIOB,GPIO_PINS_8)
  23. #define DA_0 gpio_bits_reset(GPIOB,GPIO_PINS_8)
  24. #define WR_1 gpio_bits_set(GPIOB,GPIO_PINS_7)
  25. #define WR_0 gpio_bits_reset(GPIOB,GPIO_PINS_7)
  26. #define CS_1 gpio_bits_set(GPIOB,GPIO_PINS_5)
  27. #define CS_0 gpio_bits_reset(GPIOB,GPIO_PINS_5)
  28. #define Smg_a    0x80
  29. #define Smg_b    0x40
  30. #define Smg_c    0x20
  31. #define Smg_d    0x01
  32. #define Smg_e    0x02
  33. #define Smg_f    0x08
  34. #define Smg_g    0x04
  35. #define Smg_dp   0x10
  36. #define Bmp0Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f
  37. #define Bmp1Map          Smg_b | Smg_c
  38. #define Bmp2Map          Smg_a | Smg_b | Smg_d | Smg_e | Smg_g
  39. #define Bmp3Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_g
  40. #define Bmp4Map          Smg_b | Smg_c | Smg_f | Smg_g
  41. #define Bmp5Map          Smg_a | Smg_c | Smg_d | Smg_f | Smg_g
  42. #define Bmp6Map          Smg_a | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  43. #define Bmp8Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  44. #define Bmp9Map          Smg_a | Smg_b | Smg_c | Smg_d | Smg_f | Smg_g
  45. #define Bmp7Map          Smg_a | Smg_b | Smg_c
  46. #define BmpAMap          Smg_a | Smg_b | Smg_c | Smg_e | Smg_f | Smg_g
  47. #define BmpBMap          Smg_c | Smg_d | Smg_e | Smg_f | Smg_g
  48. #define BmpCMap          Smg_a | Smg_d | Smg_e | Smg_f
  49. #define BmpDMap          Smg_b | Smg_c | Smg_d | Smg_e | Smg_g
  50. #define BmpEMap          Smg_a | Smg_d | Smg_e | Smg_f | Smg_g
  51. #define BmpFMap          Smg_a | Smg_e | Smg_f | Smg_g
  52. uint16_t HT1621_PIN[3]       = {DA_PIN,WR_PIN,CS_PIN};
  53. crm_periph_clock_type HT1621_gpio_crm_clk[3] = {DA_GPIO_CRM_CLK, WR_GPIO_CRM_CLK, CS_GPIO_CRM_CLK};
  54. gpio_type *HT1621_port[3]        = {DA_GPIO,WR_GPIO,CS_GPIO};
  55. const unsigned char SegCode[] = {Bmp0Map,Bmp1Map,Bmp2Map,Bmp3Map,Bmp4Map,Bmp5Map,Bmp6Map,Bmp7Map,Bmp8Map,Bmp9Map,BmpAMap,BmpBMap,BmpCMap,BmpDMap,BmpEMap,BmpFMap};
  56. unsigned char DpyNum[6] = {Smg_g,Smg_g,Smg_g,Smg_g,Smg_g,Smg_g}; //显示缓冲区
  57. unsigned int i;
  58. void COMMAND_HT1621(unsigned char comm)
  59. {
  60.     //unsigned char i;
  61.     CS_0;
  62.     WR_0;
  63.     for(i=0;i<3;i++)        //写命令
  64.     {
  65.         if((0x04<<i)&0x04)  DA_1;    //100
  66.         else                DA_0;
  67.         WR_0;
  68.         WR_1;
  69.     }
  70.     for(i=0;i<9;i++)        //写命令数据
  71.     {
  72.         if((comm<<i)&0x80)  DA_1;    //100
  73.         else                DA_0;
  74.         WR_0;
  75.         WR_1;
  76.     }
  77.     CS_1;
  78. }
  79. void HT1621_Display(void)
  80. {
  81.     //unsigned char i;
  82.     CS_0;                        //片选CS
  83.     WR_0;
  84.     for(i=0;i<3;i++)                   //写命令
  85.     {
  86.         if((0x05<<i)&0x04)  DA_1;
  87.         else                DA_0;
  88.         WR_0;
  89.         WR_1;
  90.     }
  91.     for(i=0;i<6;i++)                   //写地址
  92.     {
  93.         if((20<<i)&0x20)    DA_1;  //20对应 SEG地址
  94.         else                DA_0;
  95.         WR_0;
  96.         WR_1;
  97.     }
  98.     for(i=0;i<8;i++)                   //写数据
  99.     {
  100.         if((DpyNum[5]<<i)&0x80)   DA_1;
  101.         else                      DA_0;
  102.         WR_0;
  103.         WR_1;
  104.     }
  105.     for(i=0;i<8;i++)                   //写数据
  106.     {
  107.         if((DpyNum[4]<<i)&0x80)   DA_1;
  108.         else                      DA_0;
  109.         WR_0;
  110.         WR_1;
  111.     }
  112.     for(i=0;i<8;i++)                   //写数据
  113.     {
  114.         if((DpyNum[3]<<i)&0x80)   DA_1;
  115.         else                      DA_0;
  116.         WR_0;
  117.         WR_1;
  118.     }
  119.     for(i=0;i<8;i++)                   //写数据
  120.     {
  121.         if((DpyNum[2]<<i)&0x80)   DA_1;
  122.         else                      DA_0;
  123.         WR_0;
  124.         WR_1;
  125.     }
  126.     for(i=0;i<8;i++)                   //写数据
  127.     {
  128.         if((DpyNum[1]<<i)&0x80)   DA_1;
  129.         else                      DA_0;
  130.         WR_0;
  131.         WR_1;
  132.     }
  133.     for(i=0;i<8;i++)                   //写数据
  134.     {
  135.         if((DpyNum[0]<<i)&0x80)   DA_1;
  136.         else                      DA_0;
  137.         WR_0;
  138.         WR_1;
  139.     }
  140.     CS_1;                          //释放CS
  141. }
  142. void LCD_Init(void)
  143. {
  144.     COMMAND_HT1621(0x01);         //SYS EN
  145.     COMMAND_HT1621(0x03);         //LCD ON
  146.     COMMAND_HT1621(0x29);         //4 COM  1/3 BIAS
  147.     HT1621_Display();             //clear screen
  148. }
  149. void HT1621_io_init(void)
  150. {
  151.   gpio_init_type gpio_init_struct;
  152.   /* enable the led clock */
  153.   crm_periph_clock_enable(HT1621_gpio_crm_clk[0],TRUE);
  154.         crm_periph_clock_enable(HT1621_gpio_crm_clk[1],TRUE);
  155.         crm_periph_clock_enable(HT1621_gpio_crm_clk[2],TRUE);
  156.   /* set default parameter */
  157.   gpio_default_para_init(&gpio_init_struct);
  158.   /* configure the led gpio */
  159.   gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
  160.   gpio_init_struct.gpio_out_type  = GPIO_OUTPUT_PUSH_PULL;
  161.   gpio_init_struct.gpio_mode = GPIO_MODE_OUTPUT;
  162.   gpio_init_struct.gpio_pins = HT1621_PIN[0];
  163.   gpio_init_struct.gpio_pull = GPIO_PULL_NONE;
  164.   gpio_init(HT1621_port[0],&gpio_init_struct);
  165.
  166.         gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
  167.   gpio_init_struct.gpio_out_type  = GPIO_OUTPUT_PUSH_PULL;
  168.   gpio_init_struct.gpio_mode = GPIO_MODE_OUTPUT;
  169.   gpio_init_struct.gpio_pins = HT1621_PIN[1];
  170.   gpio_init_struct.gpio_pull = GPIO_PULL_NONE;
  171.   gpio_init(HT1621_port[1],&gpio_init_struct);
  172.
  173.         gpio_init_struct.gpio_drive_strength = GPIO_DRIVE_STRENGTH_STRONGER;
  174.   gpio_init_struct.gpio_out_type  = GPIO_OUTPUT_PUSH_PULL;
  175.   gpio_init_struct.gpio_mode = GPIO_MODE_OUTPUT;
  176.   gpio_init_struct.gpio_pins = HT1621_PIN[2];
  177.   gpio_init_struct.gpio_pull = GPIO_PULL_NONE;
  178.   gpio_init(HT1621_port[2],&gpio_init_struct);
  179. }
  180. /**
  181.   * [url=home.php?mod=space&uid=247401]@brief[/url]  main function.
  182.   * @param  none
  183.   * @retval none
  184.   */
  185. int main(void)
  186. {
  187.         long int i;
  188.   system_clock_config();
  189.   at32_board_init();
  190.         HT1621_io_init();
  191.         LCD_Init();
  192.     DpyNum[0] = Smg_a|Smg_d|Smg_g;              //"三"
  193.     DpyNum[1] = SegCode[1];
  194.     DpyNum[2] = SegCode[3];
  195.     DpyNum[3] = SegCode[5];
  196.     DpyNum[4] = SegCode[7];
  197.     DpyNum[5] = SegCode[9];
  198.     HT1621_Display();               //刷新LCD
  199.   while(1)
  200.   {
  201.
  202.
  203. //    at32_led_toggle(LED2);
  204. //    delay_ms(200);
  205. //    at32_led_toggle(LED3);
  206. //    delay_ms(200);
  207. //    at32_led_toggle(LED4);
  208. //    delay_ms(200);
  209. //                CLK_0;
  210. //                for(i=0;i<500000;i++);
  211. //                CLK_1;
  212. //                for(i=0;i<500000;i++);
  213.   }
  214. }
效果图
hello、C 发表于 2022-3-6 17:08 | 显示全部楼层
可以  很强
cr315 发表于 2022-3-8 10:29 | 显示全部楼层
相当不错
