请教兆易FAE关于GD32E505RBT6 SHRTIME占空比丢失问题
14073|33
 楼主| 夏洛克达尔 发表于 2022-3-6 15:09 | 显示全部楼层 |阅读模式
我在使用SHRTIME配置互补带死区的PWM时发现在输出PWM存在占空比丢失问题。在官方给的例程中也发现有同样问题。请求技术支持或单片机大牛帮忙分析分析。
代码如下
void shrtimer_config1(void)
    fSHRTIMER_CK:120MHz, from CK_SYS
    ST2_CHO_O: set request at Slave_TIMER2 compare 0 event, reset request at Slave_TIMER2 compare 1 event
    ST2_CH1_O: the waveform is complementary to channel 0
    shrtimer_baseinit_parameter_struct baseinit_para;
    shrtimer_timerinit_parameter_struct timerinit_para;
    shrtimer_timercfg_parameter_struct timercfg_para;
    shrtimer_comparecfg_parameter_struct comparecfg_para;
    shrtimer_channel_outputcfg_parameter_struct outcfg_para;
    shrtimer_deadtimecfg_parameter_struct deadtimecfg_para;
          shrtimer_synccfg_parameter_struct synccfg_para;
          rcu_periph_clock_enable(RCU_GPIOB);
    rcu_periph_clock_enable(RCU_AF);
          gpio_afio_port_config(AFIO_PB12_SHRTIMER_CFG, ENABLE);
    gpio_afio_port_config(AFIO_PB13_SHRTIMER_CFG, ENABLE);
    gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_12);
    gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_13);
                gpio_afio_port_config(AFIO_PB14_SHRTIMER_CFG, ENABLE);
    gpio_afio_port_config(AFIO_PB15_SHRTIMER_CFG, ENABLE);
    gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_14);
    gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_15);
    /* clock config */
    rcu_periph_clock_enable(RCU_SHRTIMER);
    rcu_shrtimer_clock_config(RCU_SHRTIMERSRC_CKSYS);
    /* periodic DLL calibration */
    shrtimer_dll_calibration_start(SHRTIMER0, SHRTIMER_CALIBRATION_16384_PERIOD);
    while(RESET == shrtimer_common_flag_get(SHRTIMER0, SHRTIMER_FLAG_DLLCAL));
    /* Slave_TIMER2,3 time base clock config  */
    shrtimer_baseinit_struct_para_init(&baseinit_para);
    baseinit_para.period = LLCFPWMMAX;   //
    baseinit_para.prescaler = SHRTIMER_PRESCALER_MUL16;
    baseinit_para.repetitioncounter = 0;
    baseinit_para.counter_mode = SHRTIMER_COUNTER_MODE_CONTINOUS;
    shrtimer_timers_base_init(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, &baseinit_para);
                shrtimer_timers_base_init(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, &baseinit_para);
//          shrtimer_synccfg_struct_para_init(&synccfg_para);
//    synccfg_para.input_source = SHRTIMER_SYNCINPUTSOURCE_INTERNAL;
//    shrtimer_synchronization_config(SHRTIMER0, &synccfg_para);
    /* initialize Slave_TIMER2,3 to work in waveform mode */
    shrtimer_timerinit_struct_para_init(&timerinit_para);
    timerinit_para.cnt_bunch = SHRTIMER_TIMERBUNCHNMODE_MAINTAINCLOCK;
    timerinit_para.dac_trigger = SHRTIMER_DAC_TRIGGER_NONE;
    timerinit_para.half_mode = SHRTIMER_HALFMODE_DISABLED;
    timerinit_para.repetition_update = SHRTIMER_UPDATEONREPETITION_DISABLED;
    timerinit_para.reset_sync = SHRTIMER_SYNCRESET_DISABLED;
    timerinit_para.shadow = SHRTIMER_SHADOW_DISABLED;
    timerinit_para.start_sync = SHRTIMER_SYNISTART_DISABLED;
    timerinit_para.update_selection = SHRTIMER_MT_ST_UPDATE_SELECTION_INDEPENDENT;
    shrtimer_timers_waveform_init(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, &timerinit_para);
    shrtimer_timers_waveform_init(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, &timerinit_para);
    /* configure the general behavior of a Slave_TIMER2,3 which work in waveform mode */
    shrtimer_timercfg_struct_para_init(&timercfg_para);
    timercfg_para.balanced_mode = SHRTIMER_STXBALANCEDMODE_DISABLED;
    timercfg_para.cnt_reset = SHRTIMER_STXCNT_RESET_NONE;
    timercfg_para.deadtime_enable = SHRTIMER_STXDEADTIME_ENABLED;
    timercfg_para.delayed_idle = SHRTIMER_STXDELAYED_IDLE_DISABLED;
    timercfg_para.fault_enable = SHRTIMER_STXFAULTENABLE_NONE;
    timercfg_para.fault_protect = SHRTIMER_STXFAULT_PROTECT_READWRITE;
    timercfg_para.reset_update = SHRTIMER_STXUPDATEONRESET_DISABLED;
    timercfg_para.update_source = SHRTIMER_STXUPDATETRIGGER_NONE;
    shrtimer_slavetimer_waveform_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, &timercfg_para);
    shrtimer_slavetimer_waveform_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, &timercfg_para);
    shrtimer_deadtimercfg_struct_para_init(&deadtimecfg_para);
    deadtimecfg_para.fallingsign_protect = SHRTIMER_DEADTIME_FALLINGSIGN_PROTECT_DISABLE;
    deadtimecfg_para.falling_protect = SHRTIMER_DEADTIME_FALLING_PROTECT_DISABLE;
    deadtimecfg_para.falling_sign = SHRTIMER_DEADTIME_FALLINGSIGN_POSITIVE;
    deadtimecfg_para.falling_value = 200;
    deadtimecfg_para.prescaler = SHRTIMER_DEADTIME_PRESCALER_MUL16;
    deadtimecfg_para.risingsign_protect = SHRTIMER_DEADTIME_RISINGSIGN_PROTECT_DISABLE;
    deadtimecfg_para.rising_protect = SHRTIMER_DEADTIME_RISING_PROTECT_DISABLE;
    deadtimecfg_para.rising_sign = SHRTIMER_DEADTIME_RISINGSIGN_POSITIVE;
    deadtimecfg_para.rising_value = 200;
    shrtimer_slavetimer_deadtime_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, &deadtimecfg_para);
    shrtimer_slavetimer_deadtime_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, &deadtimecfg_para);
    /* configures the compare unit of a Slave_TIMER2,3 which work in waveform mode */
    shrtimer_comparecfg_struct_para_init(&comparecfg_para);
    comparecfg_para.compare_value = 100;
    shrtimer_slavetimer_waveform_compare_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, SHRTIMER_COMPARE0, &comparecfg_para);
    comparecfg_para.compare_value = 100 + ((LLCFPWMMAX)/2);
    shrtimer_slavetimer_waveform_compare_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, SHRTIMER_COMPARE1, &comparecfg_para);
                shrtimer_slavetimer_waveform_compare_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, SHRTIMER_COMPARE0, &comparecfg_para);
                shrtimer_slavetimer_waveform_compare_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, SHRTIMER_COMPARE1, &comparecfg_para);
    /* configures the ST2_CH0_O/ST2_CH1_O output of a Slave_TIMER2 work in waveform mode */
                /* configures the ST3_CH0_O/ST3_CH1_O output of a Slave_TIMER3 work in waveform mode */
    shrtimer_channel_outputcfg_struct_para_init(&outcfg_para);
    outcfg_para.carrier_mode = SHRTIMER_CHANNEL_CARRIER_DISABLED;
    outcfg_para.deadtime_bunch = SHRTIMER_CHANNEL_BUNCH_ENTRY_REGULAR;
    outcfg_para.fault_state = SHRTIMER_CHANNEL_FAULTSTATE_NONE;
    outcfg_para.idle_bunch = SHRTIMER_CHANNEL_BUNCH_IDLE_DISABLE;
    outcfg_para.idle_state = SHRTIMER_CHANNEL_IDLESTATE_INACTIVE;
    outcfg_para.polarity = SHRTIMER_CHANNEL_POLARITY_HIGH;
    outcfg_para.reset_request = SHRTIMER_CHANNEL_RESET_CMP1;
    outcfg_para.set_request = SHRTIMER_CHANNEL_SET_CMP0;
    shrtimer_slavetimer_waveform_channel_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, SHRTIMER_ST2_CH0, &outcfg_para);
    shrtimer_slavetimer_waveform_channel_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, SHRTIMER_ST2_CH1, &outcfg_para);
    shrtimer_slavetimer_waveform_channel_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, SHRTIMER_ST3_CH0, &outcfg_para);
    shrtimer_slavetimer_waveform_channel_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, SHRTIMER_ST3_CH1, &outcfg_para);
    /* enable output channel */
    shrtimer_output_channel_enable(SHRTIMER0, SHRTIMER_ST2_CH0);
    shrtimer_output_channel_enable(SHRTIMER0, SHRTIMER_ST2_CH1);
                shrtimer_output_channel_enable(SHRTIMER0, SHRTIMER_ST3_CH0);
    shrtimer_output_channel_enable(SHRTIMER0, SHRTIMER_ST3_CH1);
    /* enable a counter */
    shrtimer_timers_counter_enable(SHRTIMER0, SHRTIMER_ST2_COUNTER);
    shrtimer_timers_counter_enable(SHRTIMER0, SHRTIMER_ST3_COUNTER);
 楼主| 夏洛克达尔 发表于 2022-3-6 15:18 | 显示全部楼层
图片中4个通道分别为ST2_CH0,CH1。ST3_CH0,CH1。每个通道都会占空比有丢失的情况。
代码按照官方例程SHRTIMER0_complementary_output改的,将官方例程烧进单片机里也会出现这个问题?
 楼主| 夏洛克达尔 发表于 2022-3-6 16:47 | 显示全部楼层
  1. void shrtimer_config1(void)
  3. /* -----------------------------------------------------------------------
  4.     fSHRTIMER_CK:120MHz, from CK_SYS
  5.     ST2_CHO_O: set request at Slave_TIMER2 compare 0 event, reset request at Slave_TIMER2 compare 1 event
  6.     ST2_CH1_O: the waveform is complementary to channel 0
  7.   ----------------------------------------------------------------------- */
  8.     shrtimer_baseinit_parameter_struct baseinit_para;
  9.     shrtimer_timerinit_parameter_struct timerinit_para;
  10.     shrtimer_timercfg_parameter_struct timercfg_para;
  11.     shrtimer_comparecfg_parameter_struct comparecfg_para;
  12.     shrtimer_channel_outputcfg_parameter_struct outcfg_para;
  13.     shrtimer_deadtimecfg_parameter_struct deadtimecfg_para;
  14.           shrtimer_synccfg_parameter_struct synccfg_para;
  15.
  16.           rcu_periph_clock_enable(RCU_GPIOB);
  17.     rcu_periph_clock_enable(RCU_AF);
  18.           gpio_afio_port_config(AFIO_PB12_SHRTIMER_CFG, ENABLE);
  19.     gpio_afio_port_config(AFIO_PB13_SHRTIMER_CFG, ENABLE);
  20.     gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_12);
  21.     gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_13);
  22.
  23.                 gpio_afio_port_config(AFIO_PB14_SHRTIMER_CFG, ENABLE);
  24.     gpio_afio_port_config(AFIO_PB15_SHRTIMER_CFG, ENABLE);
  25.     gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_14);
  26.     gpio_init(GPIOB,GPIO_MODE_AF_PP,GPIO_OSPEED_50MHZ,GPIO_PIN_15);
  27.
  28.     /* clock config */
  29.     rcu_periph_clock_enable(RCU_SHRTIMER);
  30.     rcu_shrtimer_clock_config(RCU_SHRTIMERSRC_CKSYS);
  31.
  32.     /* periodic DLL calibration */
  33.     shrtimer_dll_calibration_start(SHRTIMER0, SHRTIMER_CALIBRATION_16384_PERIOD);
  34.     while(RESET == shrtimer_common_flag_get(SHRTIMER0, SHRTIMER_FLAG_DLLCAL));
  35.
  36.     /* Slave_TIMER2,3 time base clock config  */
  37.     shrtimer_baseinit_struct_para_init(&baseinit_para);
  38.     baseinit_para.period = LLCFPWMMAX;   //
  39.     baseinit_para.prescaler = SHRTIMER_PRESCALER_MUL16;
  40.     baseinit_para.repetitioncounter = 0;
  41.     baseinit_para.counter_mode = SHRTIMER_COUNTER_MODE_CONTINOUS;
  42.     shrtimer_timers_base_init(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, &baseinit_para);
  43.                 shrtimer_timers_base_init(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, &baseinit_para);
  44.
  45. //          shrtimer_synccfg_struct_para_init(&synccfg_para);
  46. //    synccfg_para.input_source = SHRTIMER_SYNCINPUTSOURCE_INTERNAL;
  47. //    shrtimer_synchronization_config(SHRTIMER0, &synccfg_para);
  48.     /* initialize Slave_TIMER2,3 to work in waveform mode */
  49.     shrtimer_timerinit_struct_para_init(&timerinit_para);
  50.     timerinit_para.cnt_bunch = SHRTIMER_TIMERBUNCHNMODE_MAINTAINCLOCK;
  51.     timerinit_para.dac_trigger = SHRTIMER_DAC_TRIGGER_NONE;
  52.     timerinit_para.half_mode = SHRTIMER_HALFMODE_DISABLED;
  53.     timerinit_para.repetition_update = SHRTIMER_UPDATEONREPETITION_DISABLED;
  54.     timerinit_para.reset_sync = SHRTIMER_SYNCRESET_DISABLED;
  55.     timerinit_para.shadow = SHRTIMER_SHADOW_DISABLED;
  56.     timerinit_para.start_sync = SHRTIMER_SYNISTART_DISABLED;
  57.     timerinit_para.update_selection = SHRTIMER_MT_ST_UPDATE_SELECTION_INDEPENDENT;
  58.     shrtimer_timers_waveform_init(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, &timerinit_para);
  59.     shrtimer_timers_waveform_init(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, &timerinit_para);
  60.     /* configure the general behavior of a Slave_TIMER2,3 which work in waveform mode */
  61.     shrtimer_timercfg_struct_para_init(&timercfg_para);
  62.     timercfg_para.balanced_mode = SHRTIMER_STXBALANCEDMODE_DISABLED;
  63.     timercfg_para.cnt_reset = SHRTIMER_STXCNT_RESET_NONE;
  64.     timercfg_para.deadtime_enable = SHRTIMER_STXDEADTIME_ENABLED;
  65.     timercfg_para.delayed_idle = SHRTIMER_STXDELAYED_IDLE_DISABLED;
  66.     timercfg_para.fault_enable = SHRTIMER_STXFAULTENABLE_NONE;
  67.     timercfg_para.fault_protect = SHRTIMER_STXFAULT_PROTECT_READWRITE;
  68.     timercfg_para.reset_update = SHRTIMER_STXUPDATEONRESET_DISABLED;
  69.     timercfg_para.update_source = SHRTIMER_STXUPDATETRIGGER_NONE;
  70.     shrtimer_slavetimer_waveform_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, &timercfg_para);
  71.     shrtimer_slavetimer_waveform_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, &timercfg_para);
  72.
  73.     shrtimer_deadtimercfg_struct_para_init(&deadtimecfg_para);
  74.     deadtimecfg_para.fallingsign_protect = SHRTIMER_DEADTIME_FALLINGSIGN_PROTECT_DISABLE;
  75.     deadtimecfg_para.falling_protect = SHRTIMER_DEADTIME_FALLING_PROTECT_DISABLE;
  76.     deadtimecfg_para.falling_sign = SHRTIMER_DEADTIME_FALLINGSIGN_POSITIVE;
  77.     deadtimecfg_para.falling_value = 200;
  78.     deadtimecfg_para.prescaler = SHRTIMER_DEADTIME_PRESCALER_MUL16;
  79.     deadtimecfg_para.risingsign_protect = SHRTIMER_DEADTIME_RISINGSIGN_PROTECT_DISABLE;
  80.     deadtimecfg_para.rising_protect = SHRTIMER_DEADTIME_RISING_PROTECT_DISABLE;
  81.     deadtimecfg_para.rising_sign = SHRTIMER_DEADTIME_RISINGSIGN_POSITIVE;
  82.     deadtimecfg_para.rising_value = 200;
  83.     shrtimer_slavetimer_deadtime_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, &deadtimecfg_para);
  84.     shrtimer_slavetimer_deadtime_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, &deadtimecfg_para);
  85.     /* configures the compare unit of a Slave_TIMER2,3 which work in waveform mode */
  86.     shrtimer_comparecfg_struct_para_init(&comparecfg_para);
  87.     comparecfg_para.compare_value = 100;
  88.     shrtimer_slavetimer_waveform_compare_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, SHRTIMER_COMPARE0, &comparecfg_para);
  89.     comparecfg_para.compare_value = 100 + ((LLCFPWMMAX)/2);
  90.     shrtimer_slavetimer_waveform_compare_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, SHRTIMER_COMPARE1, &comparecfg_para);
  91.
  92.                 comparecfg_para.compare_value = 100;
  93.                 shrtimer_slavetimer_waveform_compare_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, SHRTIMER_COMPARE0, &comparecfg_para);
  94.     comparecfg_para.compare_value = 100 + ((LLCFPWMMAX)/2);
  95.                 shrtimer_slavetimer_waveform_compare_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, SHRTIMER_COMPARE1, &comparecfg_para);
  96.
  97.     /* configures the ST2_CH0_O/ST2_CH1_O output of a Slave_TIMER2 work in waveform mode */
  98.                 /* configures the ST3_CH0_O/ST3_CH1_O output of a Slave_TIMER3 work in waveform mode */
  99.     shrtimer_channel_outputcfg_struct_para_init(&outcfg_para);
  100.     outcfg_para.carrier_mode = SHRTIMER_CHANNEL_CARRIER_DISABLED;
  101.     outcfg_para.deadtime_bunch = SHRTIMER_CHANNEL_BUNCH_ENTRY_REGULAR;
  102.     outcfg_para.fault_state = SHRTIMER_CHANNEL_FAULTSTATE_NONE;
  103.     outcfg_para.idle_bunch = SHRTIMER_CHANNEL_BUNCH_IDLE_DISABLE;
  104.     outcfg_para.idle_state = SHRTIMER_CHANNEL_IDLESTATE_INACTIVE;
  105.     outcfg_para.polarity = SHRTIMER_CHANNEL_POLARITY_HIGH;
  106.     outcfg_para.reset_request = SHRTIMER_CHANNEL_RESET_CMP1;
  107.     outcfg_para.set_request = SHRTIMER_CHANNEL_SET_PER;
  108.     shrtimer_slavetimer_waveform_channel_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, SHRTIMER_ST2_CH0, &outcfg_para);
  109.     shrtimer_slavetimer_waveform_channel_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER2, SHRTIMER_ST2_CH1, &outcfg_para);
  110.     shrtimer_slavetimer_waveform_channel_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, SHRTIMER_ST3_CH0, &outcfg_para);
  111.     shrtimer_slavetimer_waveform_channel_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER3, SHRTIMER_ST3_CH1, &outcfg_para);
  112.
  113.     /* enable output channel */
  114.     shrtimer_output_channel_enable(SHRTIMER0, SHRTIMER_ST2_CH0);
  115.     shrtimer_output_channel_enable(SHRTIMER0, SHRTIMER_ST2_CH1);
  116.                 shrtimer_output_channel_enable(SHRTIMER0, SHRTIMER_ST3_CH0);
  117.     shrtimer_output_channel_enable(SHRTIMER0, SHRTIMER_ST3_CH1);
  118.     /* enable a counter */
  119.     shrtimer_timers_counter_enable(SHRTIMER0, SHRTIMER_ST2_COUNTER);
  120.     shrtimer_timers_counter_enable(SHRTIMER0, SHRTIMER_ST3_COUNTER);
  121. }
sxy4517 发表于 2022-3-6 22:19 | 显示全部楼层
楼主是驱动什么?
lfgaijf 发表于 2022-3-21 23:49 | 显示全部楼层
我也遇到了,就离谱。 这个就只在例程的基础上把频率降了一点。
mcu型号是gd32 e503cet6 ,用的例程是shrtimer complementary output,也就是互补输出加死区的例程。
问题和楼主一样,都是有一个周期少了一个下降沿,reset失效,这用来驱动mos管必炸机。
lfgaijf 发表于 2022-3-22 00:02 来自手机 | 显示全部楼层
大哥您解决了吗,看你变量名是在做谐振变换器,我也是做开关电源的,交流一下。qq 865358482
lifeforrent 发表于 2022-3-22 16:32 | 显示全部楼层
我在E503Z-EVAL板子用楼主的代码测试波形是正确的。
lfgaijf 发表于 2022-3-24 22:17 | 显示全部楼层
发现这个bug触发规律是这样的,成对出现。从示波器图上可以看到-17ms和4us会出现这种无法置0的现象,719ms到736ms又是另一对。 QQ图片20220321234825.jpg
以下是我对shrtimer的配置。
void shrtimer_config_duli(void)
    fSHRTIMER_CK:180MHz, from CK_SYS
    waveform period: 384/(180M*64)=33.3ns
    ST0_CHO_O: set request at Slave_TIMER0 compare 0 event, reset request at Slave_TIMER0 compare 1 event
    ST0_CH1_O: set request at Slave_TIMER0 compare 2 event, reset request at Slave_TIMER0 compare 3 event
    /* clock config */
    /* Slave_TIMER0 time base clock config  */
    baseinit_para.period = 15999;
    baseinit_para.prescaler = SHRTIMER_PRESCALER_MUL4;
    shrtimer_timers_base_init(SHRTIMER0, SHRTIMER_SLAVE_TIMER0, &baseinit_para);
    /* initialize Slave_TIMER0 to work in waveform mode */
    shrtimer_timers_waveform_init(SHRTIMER0, SHRTIMER_SLAVE_TIMER0, &timerinit_para);
    /* configure the general behavior of a Slave_TIMER0 which work in waveform mode */
    timercfg_para.deadtime_enable = SHRTIMER_STXDEADTIME_DISABLED;
    shrtimer_slavetimer_waveform_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER0, &timercfg_para);
    /* configures the compare unit of a Slave_TIMER0 which work in waveform mode */
    shrtimer_slavetimer_waveform_compare_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER0, SHRTIMER_COMPARE0, &comparecfg_para);
    comparecfg_para.compare_value = 1100;
    shrtimer_slavetimer_waveform_compare_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER0, SHRTIMER_COMPARE1, &comparecfg_para);
    comparecfg_para.compare_value = 5000;
    shrtimer_slavetimer_waveform_compare_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER0, SHRTIMER_COMPARE2, &comparecfg_para);
    comparecfg_para.compare_value = 15550;
    shrtimer_slavetimer_waveform_compare_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER0, SHRTIMER_COMPARE3, &comparecfg_para);
    /* configures the ST0_CH0_O output of a Slave_TIMER0 work in waveform mode */
    shrtimer_slavetimer_waveform_channel_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER0, SHRTIMER_ST0_CH0, &outcfg_para);
    /* configures the ST0_CH1_O output of a Slave_TIMER0 work in waveform mode */
    outcfg_para.reset_request = SHRTIMER_CHANNEL_RESET_CMP3;
    outcfg_para.set_request = SHRTIMER_CHANNEL_SET_CMP2;
    shrtimer_slavetimer_waveform_channel_config(SHRTIMER0, SHRTIMER_SLAVE_TIMER0, SHRTIMER_ST0_CH1, &outcfg_para);
    shrtimer_output_channel_enable(SHRTIMER0, SHRTIMER_ST0_CH0);
    shrtimer_output_channel_enable(SHRTIMER0, SHRTIMER_ST0_CH1);
    shrtimer_timers_counter_enable(SHRTIMER0, SHRTIMER_ST0_COUNTER);
tpgf 发表于 2022-4-2 17:18 | 显示全部楼层
就是波形丢失了是吗
wakayi 发表于 2022-4-2 17:29 | 显示全部楼层
是不是产生了竞争现象啊
wowu 发表于 2022-4-2 17:37 | 显示全部楼层
这些全是配置代码吗
renzheshengui 发表于 2022-4-2 17:43 | 显示全部楼层
会不会是示波器引入的干扰啊
xiaoqizi 发表于 2022-4-2 17:53 | 显示全部楼层
这个问题的原因可是不好找
木木guainv 发表于 2022-4-2 18:01 | 显示全部楼层
这是多快的速度啊
CharryW 发表于 2022-4-7 16:27 | 显示全部楼层
可以试下把初始化时的周期校准改成单次校准,这个周期出现可能是周期校准导致的。
loala 发表于 2022-4-7 16:42 | 显示全部楼层
shrtimer_dll_calibration_start(SHRTIMER0, SHRTIMER_CALIBRATION_16384_PERIOD);这一句,改成
    shrtimer_dll_calibration_start(SHRTIMER0, SHRTIMER_CALIBRATION_ONCE);
lfgaijf 发表于 2022-4-21 07:03 | 显示全部楼层
    shrti ...
已经按您的说法解决,非常感谢
廖为情 发表于 2022-4-21 09:20 | 显示全部楼层
国产进口MCU,GD现货,有技术支持,有需要的小伙伴加微信,L18121451280 廖**
JIA XUAN 发表于 2022-4-21 14:40 | 显示全部楼层
准备用这个片子替代stmG474呢,多亏楼上两个细心的坛友发现这个bug,否则同步整流炸机没商量,希望官方能重视此问题。
