[资料分享] 50HZ陷波器python源码
1074|0
 楼主| tao180539 发表于 2022-3-24 19:57 | 显示全部楼层 |阅读模式
#50HZ陷波器
#分子
numerator =[0.96897, -1.84310, 0.96897 ]
#分母
denominator =[1, -1.84310 ,0.93795]
import numpy as np
from matplotlib import pyplot as plt
import random
W_50_Hz = 2*np.pi*50 #定义频率W
#x_row_length = 2*np.pi/W_50_Hz; #2个周期 T=2π/w
one_cycle_sample_point=1000 #1个周期内采样1000个点
cycle = 5
total_sample_number=(one_cycle_sample_point*cycle)
x_row_length = cycle*0.02 #50HZ的周期是1/50=0.02
total_num_length = int(cycle*50000) #原始信号一共的点数
#1个周期内采样1000个点,采样间隔是
sample_interval=int(total_num_length/cycle/1000)
print("sample_interval is ",sample_interval)
#sample_fre = 1000#采样频率。
Sin50_data = [0,0]
#Sin70_data = [0,0]
noise = []
t = [0]
sample_point = [0,0]
sample_Sin50_data = [0,0]
filter_Sin50_data = [0,0]
#filter_Sin70_data = [0,0]
#W_70_Hz = 2*np.pi*70 #定义频率W
t=np.linspace(0,x_row_length,(total_num_length))#原始信号的时间间隔 x=linspace(x0,xn,m)表示在x0和xn之间等间隔取m个数
#参数loc(float):正态分布的均值,对应着这个分布的中心。
#参数scale(float):正态分布的标准差,对应分布的宽度,scale越大,正态分布的曲线越矮胖,scale越小,曲线越高瘦。
#参数size(int 或者整数元组):输出的值赋在shape里,默认为None。
noise=np.random.normal(0,0.01,(total_num_length))#产生噪声
Sin50_data = np.sin(W_50_Hz*t) + noise#原始信号添加噪声
#sample_num=int(total_num_length/sample_fre)
#length = len(sample_Sin50_data)
index=0
for n in range(2,total_sample_number):
        time_point=2*np.pi*50*n/one_cycle_sample_point
        sample_Sin50_data.append( np.sin(time_point))
        #sample_Sin50_data[index]=Sin50_data[n]
        sample_point.append(time_point)
        #sample_point[index]=t[n]
        #index=index+1
sample_length=len(sample_point)
print("sample point length is %d sample data length is",len(sample_point),len(sample_Sin50_data))
for n in range(2,total_sample_number):# range(a,b,c) ,a为循环开始的数字(可不填,默认为0),b为循环结束的后一位(c为正数时)的数字
        now_data = 0.974025*sample_Sin50_data[n] - 1.852705*sample_Sin50_data[n-1] + 0.974025*sample_Sin50_data[n-2] + 1.852705*filter_Sin50_data[n-1] - 0.948050*filter_Sin50_data[n-2]
        filter_Sin50_data.append(now_data)
        #filter_Sin50_data[index]=now_data
        #index=index+1
#del filter_Sin50_data[0 : 2]
print("sample point length is\n\r",len(sample_point))
print("filter_Sin50_data length is\n\r",len(filter_Sin50_data))
plt.plot(sample_point, sample_Sin50_data,color='red',   label="Sin50_data")
plt.plot(sample_point ,filter_Sin50_data,color='blue',  label="filter_Sin50_data")
plt.legend()
plt.show()
