[PCB] Qualcomm-AR9344-Minipcie-card-wifi-wallys
908|0
 楼主| wirelesswifi6 发表于 2022-4-18 11:59 | 显示全部楼层 |阅读模式
IPQ6010/IPQ6018/IPQ6000/IPQ8072/IPQ5018
IPQ8074/IPQ8072A/IPQ4029/IPQ4019/AR9344
Featuring with industrial-grade Atheros/ AR9344(560 MHz)chipset,DR344
Integrated with 1 x 5G high power (up to 30dBm aggregate ) radio card
Supports 1 x 10/100Mbps Fast Ethernet Port and 1 x 10/100/1000Mbps Gigabit Ethernet Port
Support WiFi application(Optional)
Support 2 x 5G MMCX connectors
Support 5M/10M/20M/40M Bandwidth
Support 1 x USB2.0(Optional)
Support operating frequency from 2.312 GHz to 2.502 GHz and 4.92GHz to 6.085GHz
RoHS compliance ensure a high level protection of human health and the environment from risks that can be posed by chemicals
    Hardware Information
    CPU
    Atheros/AR9344-AC2A 560 MHz processor frequency
    System Memory
    64MB(max 128MB DDR2 optional)
    NOR Flash
    8MB (max 16MB optional)
    Switch IC
    Atheros/AR8035-AL1A-R 1 GIGA port PHY/RGMII switch
    Power IC
    TI/TPS54531 24V to 5V 5A regulator
    AME/AME5291 5V to 3.3V 2A regulator
    Power consumption
    2.04W(Board Only)
    6.6W(Board + 2.4G card)
    7.1W(Board + 5G card)
    1000M LAN port POE define
    Pin 4/5 and pin 7/8 connect to the anode or cathode respectively 24V input
    Antenna Connector
    2 x 5G MMCX connectors(U3&U5)
    Power Connector
    1 x DC JACK(J2)D(center)=2.1mm Max 24V DC input /1 x 2 pin header pitch=3.96mm(J32)
    LAN Connector
    1 x 100M LAN(J4) port / 1 x 1000M LAN port(J3)
    ROHS Compliance
    YES
    Humidity
    Operating: 5% to 95% (non-condensing); Storage: Max.90% (non-condensing)
    Temperature Range
    Operating: -20ºC to 70ºC; Storage: -40ºC to 90ºC
    Reset Button
    RT push button(SW6)
    Dimension
    105mm x 105mm x 15.1mm
    Integrated Card specifications(Operating Frequency 5180-5825MHz)
    TX Specifications
    RX Specifications
    802.11
           a
    Data Rate
    TX Power
    Tolerance
    802.11
           a
    Data Rate
    Sensitivity
    Tolerance
    1 chain
    2 chains
    6Mbps
    27dBm
    30dBm
    ±2dB
    6Mbps
    -94dBm
    ±2dB
    54Mbps
    22dBm
    25dBm
    ±2dB
    54Mbps
    -75dBm
    ±2dB
    802.11
    N HT 20
    Data Rate
    TX Power
    Tolerance
    802.11
    N HT 20
    Data Rate
    Sensitivity
    Tolerance
    1 chain
    2 chains
    MCS0/8
    27dBm
    30dBm
    ±2dB
    MCS0/8
    -92dBm
    ±2dB
    MCS7/15
    22dBm
    25dBm
    ±2dB
    MCS7/15
    -73dBm
    ±2dB
    802.11
    N HT 40
    Data Rate
    TX Power
    Tolerance
    802.11
    N HT 40
    Data Rate
    Sensitivity
    Tolerance
    1 chain
    2 chains
    MCS0/8
    27dBm
    30dBm
    ±2dB
    MCS0/8
    -90dBm
    ±2dB
    MCS7/15
    22dBm
    25dBm
    ±2dB
    MCS7/15
    -70dBm
    ±2dB
      Ordering Information
    Item Code
    Processor
    On-board radio
    NOR Flash
    Memory
    Socket Height
    DR344-NAS27
    AR9344
    5GHz
    16MB
    128MB
    9.2mm
    Wallys Communications (Suzhou) Co LTD  develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, The market is global, welcome to consult.
    EMAIL:sales@wallystech.com
    WEB:https://www.wallystech.com/
