LCD12864程序无法显示
3161|7
 楼主| lasic 发表于 2012-4-24 14:28 | 显示全部楼层 |阅读模式
主控为ST7920的12864.由于手头上Mega8 I/O口不够,只好用PC0-PC3接DB0~3口,PD0~3接DB4~7口。PSB写高电平,用并行输入。
    12864一直没反应,求路过的高手帮忙看看,指点迷津。以下是程序:
#include <avr/io.h>
#include "lcd12864.h"
#define uchar unsigned char
#define uint unsigned int
#define DB0  PC0
#define DB1  PC1
#define DB2  PC2
#define DB3  PC3
#define DB4  PD0
#define DB5  PD1
#define DB6  PD2
#define DB7  PD3
#define LCD_RS  PD7
#define LCD_RW  PD6
#define LCD_EN  PD5
#define LCD_RET PC6//接Mega8 RESET口,低电平有效
#define SET_DATA()  (1<<LCD_RS)    //写数据
#define SET_INC()   (~(1<<LCD_RS)) //写命令
#define SET_READ()  (1<<LCD_RW)    //读
#define SET_WRITE() (~(1<<LCD_RW)) //写
#define SET_EN()    (1<<LCD_EN)    //使能
#define CLR_EN()    (~(1<<LCD_EN)) //空闲
uchar LCD_DataPortRead(void)
   uchar a;
   a=((PINC&0x0f)|((PIND&0x0f)<<4));
   return a;
void LCD_DataPort(uchar Data)
     if(Data&0x80) PORTD|=(1<<PD3);
     if(Data&0x40) PORTD|=(1<<PD2);
     if(Data&0x20) PORTD|=(1<<PD1);
     if(Data&0x10) PORTD|=(1<<PD0);
     if(Data&0x08) PORTC|=(1<<PC3);
     if(Data&0x04) PORTC|=(1<<PC2);
     if(Data&0x02) PORTC|=(1<<PC1);
     if(Data&0x01) PORTC|=(1<<PC0);
void LCD_CheckBusy(void)
   uint temp,Timeout=0;
   SET_INC();
   SET_READ();
   CLR_EN();
   SET_EN();
   Delay(5);
      temp=LCD_DataPortRead();
   CLR_EN();
   while((temp&0x80)&&(++Timeout!=0));
void LCD_SendCmd(uchar Cmd)
      LCD_CheckBusy();
   SET_INC();
   SET_WRITE();
   SET_EN();
   LCD_DataPort(Cmd);
   _delay_us(100);
   CLR_EN();
void LCD_SendData(uchar Data)
      LCD_CheckBusy();
   SET_DATA();
   SET_WRITE();
   SET_EN();
   LCD_DataPort(Data);
   Delay(5);
   CLR_EN();
void Delay(uint z)
   uint x,y;
   for(x=z;x>0;x--)
    for(y=110;y>0;y--);
void LCD_Init(void)
      Delay(50);
   LCD_SendCmd(0x30); //基本指令集
   Delay(5);
   LCD_SendCmd(0x30);
   Delay(5);
   LCD_SendCmd(0x0c); //开显示
   Delay(5);
   LCD_SendCmd(0x01); //清屏
   Delay(5);
   LCD_SendCmd(0x06); //光标右移
void LCD_SetAddress(uchar x,uchar y)
      uchar Address;
   switch(y)
     case 0: Address=0x80+x;break;
  case 1: Address=0x90+x;break;
  case 2: Address=0x88+x;break;
  case 3: Address=0x98+x;break;
  default:
  break;
   LCD_SendCmd(Address);
void LCD_PutString(uchar x,uchar y,uchar *pData)
       LCD_SetAddress(x,y);
    while(*pData!='\0')
      LCD_SendData(*pData++);
主程序如下:
#include <avr/io.h>
#include <util/delay.h>
void Port_Init(void)
  DDRB = 0xEC;
  PORTB =0xF3;
  DDRC = 0x0F; //PC0~3设置输出,无上拉
  PORTC =0xF0;
  DDRD = 0x0F;
  PORTD =0xF0;
void main(void)
  Port_Init();
  PORTB|=(1<<PB5);
  LCD_Init();
  while(1)
  LCD_PutString(2,0,"12864");
  Delay(500);
  LCD_PutString(2,1,"OK");
  LCD_PutString(0,2,"LCD12864ST7920");
  LCD_PutString(0,3,"★○◇◆※☆■△");
 楼主| lasic 发表于 2012-4-24 14:29 | 显示全部楼层
:) 求路过的前辈指点下,谢谢了!
 楼主| lasic 发表于 2012-4-26 14:06 | 显示全部楼层
:)自己顶起来,菜鸟求助
 楼主| lasic 发表于 2012-4-26 14:09 | 显示全部楼层
看来好几遍,只有接口跟例程有些不一样:void LCD_DataPort(uchar Data)
莫非是这样把数据拆了 分别赋值 不能用并口通讯?
joing1999 发表于 2012-4-27 09:52 | 显示全部楼层
你这个赋值,错了吧?你自己看看
joyme 发表于 2012-4-27 15:18 | 显示全部楼层
在使能前调这个函数赋值,你这样PC0上电平变化比PD3上慢几十个us,怎么能把正确值写进去
 楼主| lasic 发表于 2012-5-4 17:05 | 显示全部楼层
谢谢LS两位,这样赋值的确是不对的,不过还有其他地方有错,还在改。
airwill 发表于 2012-5-5 10:42 | 显示全部楼层
什么叫一直没有反应呢?
读 READY 信号, 有没有反应呢? 如果一直没有 READY, 会不会上拉和时序方面的问题.
如果有 READY, 正常写了, 会不会液晶的对比度负压没有调好?
