4GB的SD卡的初始化没有成功,热心的高手帮忙看看
2486|2
 楼主| zxb1717 发表于 2008-6-10 13:47 | 显示全部楼层 |阅读模式
SD卡, GB, 4G, se, TE
看了很多资料,例程,但还是没有成功,可能哪里出了问题没发现,请大家帮我看看。以下是关键的3个函数,CMD0和CMD55返回的响应是0x01,但ACMD41返回的响应还是0x01,应该是0才对,但是怎么调试都不行,大侠帮看一下吧,先在此谢过了!
BYTE SD_SendCmd(BYTE cmd, BYTE *param, BYTE resptype, BYTE *resp)
    WORD i;                            //所有SD卡命令都是6字节长
    BYTE xdata tmp,rlen,Cmd_Buf[6];
    char j;
    if(cmd == CMD0)
        Cmd_Buf[0] = 0x95;                // 发送CRC校验码,只用于第1个命令(command0=40 00 00 00 00 95)
    else                                    //起始位为0(bit47),传输位为1(bit46)
        Cmd_Buf[0] = 0xFF;
    for(j = 3;j >=0;j --)
        Cmd_Buf[j+1] = param[j];          //param[j]
    Cmd_Buf[5] = (cmd & 0x3F) | 0x40;
    if(cmd == CMD0)                        //先发送74个以上的时钟,为了使SD卡同步
        SET_Slave_select(0);
//        EZUSB_Delay(1);
        for(i=0;i<10;i++)
            SPI_Send_Byte(0xFF);
    else
    SET_Slave_select(2);
                    //片选SPI从机
    SPI_Send_Byte(Cmd_Buf[5]);
    SPI_Send_Byte(Cmd_Buf[4]);
    SPI_Send_Byte(Cmd_Buf[3]);
    SPI_Send_Byte(Cmd_Buf[2]);
    SPI_Send_Byte(Cmd_Buf[1]);
    SPI_Send_Byte(Cmd_Buf[0]);
    i = 0;
    do                                      // 等待响应,响应的最高位为0
    {                                    //Wait for a response,a response is a start bit(zero)
        tmp = 0xFF;
        tmp = SPI_Rec_Byte();            //在没收到响应令牌之前,tmp=0xFF,因此tmp & 0x80==1,
           i++;
    while (((tmp & 0x80) != 0) && (i < SD_CMD_TIMEOUT));    //收到响应以后由于响应最高位是0,因此tmp & 0x80==0
    if (i >= SD_CMD_TIMEOUT)            //超时
//        SPI_CS_Deassert();                //释放总线
        TD_Poll(0x15);
        EZUSB_Delay(2000);
        TD_Poll(tmp);
        EZUSB_Delay(2000);
        return SD_ERR_CMD_TIMEOUT;        // 返回命令超时 return response timeout of command
    rlen = 0;
    switch (resptype)                    //根据不同的命令,得到不同的响应长度
     {                                    //according various command,get the various response length
          case R1:
            case R1B:
            rlen = 1;
        break;
                 case R2:
            rlen = 2;
        break;
           case R3:
            rlen = 5;
        break;
        default:
            rlen = 1;
//            SPI_Send_Byte(0xFF);
            SPI_CS_Deassert();
            return SD_ERR_CMD_RESPTYPE;     // 返回命令响应类型错误 return error of command response type
        break;
//    EZUSB_Delay(1);
    *resp = tmp;
    for (j = rlen - 1; j >= 0; j--)
          SPI_Send_Byte(0xFF);                //resp的最高字节保存响应令牌Rx,其他字节装入0xFF
//        SPI_Send_Byte(0xFF);        // 发送周期的最后发送8clock  at the last recycle,clock out 8 clock
    return SD_NO_ERR;                 // 返回执行成功 return perform sucessfully
//////////复位/////////////
BYTE SD_ResetSD(void)        /////
    BYTE  xdata param[4] = {0,0,0,0},ret,resp;
    ret = SD_SendCmd(CMD0, param, CMD0_R, &resp);    /* 复位命令 command that reset sd card */
    if(ret != SD_NO_ERR)
        return 1;
    if(resp != 0x01)
        TD_Poll(0x11);
        EZUSB_Delay(2000);
        TD_Poll(resp);
        EZUSB_Delay(2000);
        return 1;
    return SD_NO_ERR;
///////////激活/////////////////
BYTE SD_Active(void)
    BYTE xdata param[4] = {0,0,0,0},*resp1,*resp2,ret;
    BYTE xdata i;
     ret = SD_SendCmd(CMD55, param, CMD55_R, resp1);        // 后续命令为一个应用命令
        if (ret != SD_NO_ERR)
               TD_Poll(0x21);
            EZUSB_Delay(2000);
               return ret;                        // command that the followed commnad is a specific application
        if (*resp1 & 0x01 != 1 )    //CMD55响应值是0x01
             TD_Poll(0x22);
            EZUSB_Delay(2000);
//            TD_Poll(*resp);
//            EZUSB_Delay(2000);
             return SD_ERR_CMD_RESP;                    // 响应错误 response is error
    i = 0;
    do                         // 循环发出CMD55+ACMD41, 查询卡的状态
        ret = SD_SendCmd(ACMD41, param, ACMD41_R, resp2);
            TD_Poll(0x23);
            EZUSB_Delay(2000);
               return ret;
        i++;
    }while ((i < 200)&& (*resp2 != 0));/* 如果响应R1的最低位Idle位为1,则继续循环 */
    if (i >= 200)
        TD_Poll(0x24);
        EZUSB_Delay(2000);
        TD_Poll(*resp2);
        EZUSB_Delay(2000);
        return SD_ERR_TIMEOUT_WAITIDLE;                    // 超时,返回错误 time out,return error
    if (*resp2 != 0)
        return SD_ERR_CMD_RESP;                    //响应错误 response is error
    return SD_NO_ERR;        // 读出寄存器内容 read the content of the register
 楼主| zxb1717 发表于 2008-6-10 14:06 | 显示全部楼层
哪位大侠路过这里给我个建议吧
以前做过类似项目的大侠给我一个建议吧
 楼主| zxb1717 发表于 2008-6-10 17:19 | 显示全部楼层
看来这里没有高手路过啊
