- // TIM3 输出比较通道2
- #define GENERAL_TIM_CH2_GPIO_CLK RCC_APB2Periph_GPIOA
- #define GENERAL_TIM_CH2_PORT GPIOA
- #define GENERAL_TIM_CH2_PIN GPIO_Pin_7
- static void GENERAL_TIM_GPIO_Config(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- // 输出比较通道1 GPIO 初始化
- RCC_APB2PeriphClockCmd(GENERAL_TIM_CH1_GPIO_CLK, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GENERAL_TIM_CH1_PIN;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GENERAL_TIM_CH1_PORT, &GPIO_InitStructure);
- RCC_APB2PeriphClockCmd(GENERAL_TIM_CH2_GPIO_CLK, ENABLE);
- GPIO_InitStructure.GPIO_Pin = GENERAL_TIM_CH2_PIN;
- GPIO_Init(GENERAL_TIM_CH2_PORT, &GPIO_InitStructure);
- static void GENERAL_TIM_Mode_Config(void)
- // 开启定时器时钟,即内部时钟CK_INT=72M
- GENERAL_TIM_APBxClock_FUN(GENERAL_TIM_CLK,ENABLE);
- /*--------------------时基结构体初始化-------------------------*/
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- // 自动重装载寄存器的值,累计TIM_Period+1个频率后产生一个更新或者中断
- TIM_TimeBaseStructure.TIM_Period=GENERAL_TIM_Period;
- // 驱动CNT计数器的时钟 = Fck_int/(psc+1)
- TIM_TimeBaseStructure.TIM_Prescaler= GENERAL_TIM_Prescaler;
- // 时钟分频因子 ,配置死区时间时需要用到
- TIM_TimeBaseStructure.TIM_ClockDivision=TIM_CKD_DIV1;
- // 计数器计数模式,设置为向上计数
- TIM_TimeBaseStructure.TIM_CounterMode=TIM_CounterMode_Up;
- // 重复计数器的值,没用到不用管
- TIM_TimeBaseStructure.TIM_RepetitionCounter=0;
- // 初始化定时器
- TIM_TimeBaseInit(GENERAL_TIM, &TIM_TimeBaseStructure);
- /*--------------------输出比较结构体初始化-------------------*/
- TIM_OCInitTypeDef TIM_OCInitStructure;
- // 配置为PWM模式1
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
- // 输出使能
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- // 输出通道电平极性配置
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
- // 输出比较通道 1
- TIM_OCInitStructure.TIM_Pulse = 0;
- TIM_OC1Init(GENERAL_TIM, &TIM_OCInitStructure);
- TIM_OC1PreloadConfig(GENERAL_TIM, TIM_OCPreload_Enable);
- // 输出比较通道 2
- TIM_OC2Init(GENERAL_TIM, &TIM_OCInitStructure);
- TIM_OC2PreloadConfig(GENERAL_TIM, TIM_OCPreload_Enable);
- // 使能计数器
- TIM_Cmd(GENERAL_TIM, ENABLE);
