[其他模拟产品-信号链] TI UCC28810中小功率LED照明应用方案
2834|2
 楼主| wewo 发表于 2012-5-6 21:18 | 显示全部楼层 |阅读模式
TI 公司的UCC28810和UCC28811是中小功率通用LED照明电源控制器,具有功率因素修正(PFC)和EMC兼容特性.设计用于工作在临界导通模式的反激,降压或升压转换器. UCC28810/1集成了用于反馈误差处理的跨导电压放大器,用来产生正比于输入电压的电流指令的电流基准发生器,电流检测(PWM)比较器,PWM逻辑和用来驱动外接FET的图腾柱驱动器.此外,控制器还提供峰值电流限制,重起定时器,过压保护(OVP)以及使能等. UCC28810和UCC28811广泛用在交流输入HB LED照明,工业,商业和住宅区照明以及户外照明如路灯,停车场,建筑物和装饰性LED照明等.本文介绍了UCC28810和UCC28811的主要特性,方框图, 简化应用电路图, 25W PFC反激转换器参考设计以及PR788 100W AC/DC LED电流驱动器参考设计和元件列表.
The UCC28810 and UCC28811 are general lighting power controllers for low to medium power lumens applications requiring power factor correction and EMC compliance. It is designed for controlling a flyback, buck or boost converter operating in critical conduction mode. It features a transconductance voltage amplifier for feedback error processing, a simple current reference generator for generating a current command proportional to the input voltage, a current-sense (PWM) comparator, PWM logic and a totem-pole driver for driving an external FET.
In the critical conduction mode operation, the PWM circuit is self-oscillating with the turn-on being governed by a transformer zero energy detector (TZE pin) and the turn-off being governed by the current sense comparator. Additionally, the controller provides features such as peak current limit, restart timer, overvoltage protection (OVP), and enable.
The efficient system performance is attained by incorporation of zero power detect function which allows the controller output to shut down at light load conditions without running into overvoltage. The device also features an innovative slew rate enhancement circuit which improves the large signal transient performance of the voltage error amplifier. The low start-up and operating currents of the device result in low power consumption and ease of start-up. The highly-accurate internal bandgap reference leads to tight regulation of the output voltage in normal and OVP conditions, resulting in higher system reliability. The enable comparator ensures that the controller is off if the feedback sense path is broken or if the input voltage is very low.
There are two key parametric differences between UCC28810 and UCC28811, the UVLO turn-on threshold and the gM amplifier source current. The UVLO turn-on threshold of the UCC28810 is 15.8 V and for the UCC28811 it is 12.5 V. The gM amplifier source current for UCC28810 is typically 1.3 mA, and for the UCC28811 it is 300µA. The higher UVLO turn-on threshold of the UCC28810 allows quicker and easier start-up with a smaller VDD capacitance while the lower UVLO turn-on threshold of UCC28811 allows operation of the critical conduction mode controller to be easily controlled by the downstream PWM controller in two-stage power converters. The UCC28810 gM amplifier also provides a full 1.3-mA typical source current for faster start-up and improved transient response when the output is low either at start-up or during transient conditions. The UCC28811 is suitable for applications such as street lights and larger area luminaires where a two-stage power conversion is needed. The UCC28810 is suitable for applications such as commercial or residential retrofit luminaires where there is no down-stream PWM conversion and the advantages of smaller VDD capacitor and improved transient response can be realized.
Devices are available in the industrial temperature range of –40℃ to 105℃. Package offering is an 8-pin SOIC (D) package.
UCC28810/1主要特性:
Transition Mode Controller for Low Implementation Cost of AC Input LED Lighting Applications
Implements Single Stage Power Factor Corrected LED Driver
Enhanced Transient Response With Slew-Rate Comparator
Interfaces with Traditional Wall Dimmers
Accurate Internal VREF for Tight Output Regulation
Two UVLO Options
Overvoltage Protection (OVP), Open-Feedback Protection and Enable Circuits
±750-mA Peak Gate Drive Current
Low Start-Up and Operating Currents
Lead (Pb)-Free Packages
UCC28810/1应用:
AC Input General Lighting Applications Using HB LEDs
Industrial, Commercial and Residential Lighting Fixtures
Outdoor Lighting: Street, Roadway, Parking, Construction and Ornamental LED Lighting Fixtures
图1.UCC28810方框图
图2.UCC28810简化应用电路图
图3.25W PFC反激转换器参考设计
The PR788 is a 100-W offline AC-to-DC LED current driver with power factor correction.
This design is a two stage converter design with a universal input boost follower PFC stage providing a 240-V to 400-V DC output and a low-side buck stage providing the current source to power the LEDs. This converter was designed to support up to 30 high-brightness LEDs in series with up to 900-mA average current. The design incorporates an interface for microprocessor control to allow for shutdown into a low power mode (< 0.5 W) and PWM dimming of the LEDs.
图4.PR788 100W AC/DC LED电流驱动器参考设计
图5.工作在CCM的低边降压转换器电路图
 楼主| wewo 发表于 2012-5-6 21:19 | 显示全部楼层
来自TI
jayy 发表于 2012-5-6 21:27 | 显示全部楼层
看过了 感觉一部分吧
