用过max3221的人看下这个图,求助!
2784|2
Tinnal| | 2012-5-14 13:09 | 只看该作者
对了一下,电路图是没有错的。检查一下焊接,供电等等。同时,注意:
With auto-powerdown enabled, the device is activated automatically when a valid signal is applied to the receiver
input. The INVALID output notifies the user if an RS-232 signal is present at the receiver input. INVALID is high
(valid data) if the receiver input voltage is greater than 2.7 V or less than −2.7 V, or has been between −0.3 V
and 0.3 V for less than 30 µs. INVALID is low (invalid data) if the receiver input voltage is between −0.3 V and
0.3 V for more than 30 µs. Refer to Figure 5 for receiver input levels.
以下下面的两个真值表,弄不好没有输出是可能的。
http://www.ti.com/lit/ds/symlink/max3221.pdf
你可以通过INVALID 检查一个芯片这时是否已经工作。
如果搞不清楚就上MAX3232吧。这个片子没么多要求,上电就工作。可以从手册的真值表看得出来。
http://www.ti.com/lit/ds/slls697a/slls697a.pdf
lintriumph|  楼主 | 2012-5-16 10:31 | 只看该作者
2# Tinnal
谢谢,嗯,还需好好检查!
