- * [url=home.php?mod=space&uid=288409]@file[/url] main.c
- * [url=home.php?mod=space&uid=895143]@version[/url] V1.00
- * $Revision: 10 $
- * $Date: 18/07/17 6:05p $
- * @brief
- * Change duty cycle of output waveform to show breathing effect of
- Red LED.
- * SPDX-License-Identifier: Apache-2.0
- * Copyright (C) 2018 Nuvoton Technology Corp. All rights reserved.
- #include <stdio.h>
- #include "NuMicro.h"
- /* Macro, type and constant definitions */
- #define PWM_Prescaler 48
- #define PWM_Period 1999
- /* Global variables */
- volatile uint8_t g_u8Forward = 1;
- volatile uint32_t g_u32BreathingCount = 0;
- void SYS_Init(void)
- /* Init System Clock */
- /* Enable HIRC clock */
- CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
- /* Waiting for HIRC clock ready */
- CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
- /* Switch HCLK clock source to HIRC and HCLK source divide 1 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
- /* Enable PWM1 module clock */
- CLK_EnableModuleClock(PWM1_MODULE);
- /* PWM clock frequency configuration */
- /* Set PLL clock as 96 MHz from HIRC/4 */
- CLK_EnablePLL(CLK_PLLCTL_PLLSRC_HIRC_DIV4, 96000000);
- /* Waiting for PLL clock ready */
- CLK_WaitClockReady(CLK_STATUS_PLLSTB_Msk);
- /* Select HCLK clock source as PLL and and HCLK clock divider as 2 */
- CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_PLL, CLK_CLKDIV0_HCLK(2));
- /* PWM clock frequency can be set equal or double to HCLK by choosing case 1 or case 2 */
- /* case 1.PWM clock frequency is set equal to HCLK: select PWM module clock source as PCLK */
- // CLK_SetModuleClock(PWM1_MODULE, CLK_CLKSEL2_PWM1SEL_PCLK0, 0);
- /* case 2.PWM clock frequency is set double to HCLK: select PWM module clock source as PLL */
- CLK_SetModuleClock(PWM1_MODULE, CLK_CLKSEL2_PWM1SEL_PLL, NULL);
- /* Reset PWM1 module */
- SYS_ResetModule(PWM1_RST);
- /* Update System Core Clock */
- SystemCoreClockUpdate();
- /* Init I/O Multi-function */
- /* Set PC.4 multi-function pins for PWM1 Channel 1 for Red LED */
- SYS->GPC_MFPL = (SYS->GPC_MFPL & (~SYS_GPC_MFPL_PC4MFP_Msk)) |
- SYS_GPC_MFPL_PC4MFP_PWM1_CH1;
- void PWM_Init()
- /* Init PWM1 */
- /* Set prescaler of PWM1 Channel 1 as PWM_Prescaler for Red LED */
- PWM_SET_PRESCALER(PWM1, 1, PWM_Prescaler - 1);
- /* Set period of PWM1 Channel 1 as PWM_Period for Red LED */
- PWM_SET_CNR(PWM1, 1, PWM_Period);
- /* Set compare of PWM1 Channel 1 as 0 for Red LED */
- PWM_SET_CMR(PWM1, 1, 0);
- /* Set Counter Type */
- PWM_SET_ALIGNED_TYPE(PWM1, BIT1, PWM_UP_COUNTER);
- /* Set Zero Point Output Low, Compare Up Point Output Nothing, Period Point Output High, Compare Down Point Output High */
- PWM_SET_OUTPUT_LEVEL(PWM1, BIT1, PWM_OUTPUT_LOW, PWM_OUTPUT_HIGH, PWM_OUTPUT_NOTHING, PWM_OUTPUT_NOTHING);
- /* Enable PWM1 Output path for channel 1 */
- PWM_EnableOutput(PWM1, BIT1);
- /* Enable PWM1 channel 1 period interrupt */
- PWM_EnablePeriodInt(PWM1, 1, 0);
- NVIC_EnableIRQ(PWM1_IRQn);
- /* Start PWM1 Counter */
- PWM_Start(PWM1, BIT1);
- void PWM1_IRQHandler(void)
- /* Increase LED brightness */
- if(g_u8Forward == 1)
- if(g_u32BreathingCount < PWM_Period)
- g_u32BreathingCount++;
- else
- g_u8Forward = 0;
- /* Decrease LED brightness */
- else
- if(g_u32BreathingCount > 0)
- g_u32BreathingCount--;
- else
- g_u8Forward = 1;
- /* Set compare of PWM1 Channel 1 for Red LED */
- PWM_SET_CMR(PWM1, 1, g_u32BreathingCount);
- /* Clear PWM1 channel 1 period interrupt flag */
- PWM_ClearPeriodIntFlag(PWM1, 1);
- /* Main Function */
- int32_t main(void)
- /* Unlock protected registers */
- SYS_UnlockReg();
- /* Init System, IP clock and multi-function I/O */
- SYS_Init();
- /* Lock protected registers */
- SYS_LockReg();
- /* Init PWM1 to drive RGB LED */
- PWM_Init();
- while(1);
