[技术问答]
如何设定NM1200为48M CPU Clock?
851|3
duo点|  楼主 | 2024-3-14 11:00 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
zhuotuzi| | 2024-3-14 21:47 | 只看该作者
配置PLL到48Mhz
zhuotuzi| | 2024-3-14 21:48 | 只看该作者
#include "NM1120.h"
void SYS_Init(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
                /* Enable 48MHz HIRC */
    CLK->PWRCTL = CLK->PWRCTL | CLK_PWRCTL_HIRCEN_Msk;
    /* Waiting for 48MHz clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
                /* HCLK Clock source from HIRC */
                CLK->CLKSEL0 = CLK->CLKSEL0 | CLK_HCLK_SRC_HIRC;
          /* Enable USCI0 IP clock */
                CLK->APBCLK = CLK->APBCLK | CLK_APBCLK_USCI0CKEN_Msk;
    /* Update System Core Clock */
    /* User can use SystemCoreClockUpdate() to calculate SystemCoreClock and cyclesPerUs automatically. */
    SystemCoreClockUpdate();
                /* USCI-Uart0-GPD5(TX) + GPD6(RX) */
    /* Set GPD multi-function pins for USCI UART0 GPD5(TX) and GPD6(RX) */
          SYS->GPD_MFP = SYS->GPD_MFP & ~(SYS_GPD_MFP_PD5MFP_Msk | SYS_GPD_MFP_PD6MFP_Msk) | (SYS_GPD_MFP_PD5_UART0_TXD | SYS_GPD_MFP_PD6_UART0_RXD);
                /* Set GPD5 as output mode and GPD6 as Input mode */
                PD->MODE = PD->MODE & ~(GPIO_MODE_MODE5_Msk | GPIO_MODE_MODE6_Msk) | (GPIO_MODE_OUTPUT << GPIO_MODE_MODE5_Pos);
    /* Lock protected registers */
    SYS_LockReg();
zhuotuzi| | 2024-3-14 21:49 | 只看该作者
HIRC本身就是48MHz时钟发生器。
