 哎呀,今天终于更新了,昨天的时候遇到点问题,还是网友们帮忙找的问题,今天就直接上来说一下这个串口的事情哈,串口做为一个常用的通信接口,扮演着非常重要的角色,是对外信息的一个常见接口,APM32的开发板上是有两个对外串口可以使用的,串口一和串口2,通过板子上的跳线就可以实现串口介入DAP的选择。我们这里就简单一点,直接就上代码吧。
 #include "DRV_UART.h"
#include "bsp_delay.h"
void USART_Init(void)
            GPIO_Config_T GPIO_configStruct;
            USART_Config_T usartConfigStruct;
             RCM_EnableAHB1PeriphClock(RCM_AHB1_PERIPH_GPIOA);
                   RCM_EnableAPB2PeriphClock(RCM_APB2_PERIPH_USART1);
             GPIO_ConfigStructInit(&GPIO_configStruct);
             USART_ConfigStructInit(&usartConfigStruct);//UART恢复默认
                        /* Connect PXx to USARTx_Tx */
                        GPIO_ConfigPinAF(GPIOA,GPIO_PIN_SOURCE_9 , GPIO_AF_USART1);
                        /* Connect PXx to USARTx_Rx */
                        GPIO_ConfigPinAF(GPIOA, GPIO_PIN_SOURCE_10, GPIO_AF_USART1);
                        /* Configure USART Tx as alternate function push-pull */
                        GPIO_configStruct.mode = GPIO_MODE_AF;
            GPIO_configStruct.otype= GPIO_OTYPE_PP;
            GPIO_configStruct.pupd = GPIO_PUPD_UP;
                        GPIO_configStruct.pin  = GPIO_PIN_9;
                        GPIO_configStruct.speed = GPIO_SPEED_50MHz;
                        GPIO_Config(GPIOA, &GPIO_configStruct);
                        /* Configure USART Rx as input floating */
                        GPIO_configStruct.pin = GPIO_PIN_10;
    usartConfigStruct.baudRate = 115200;
    usartConfigStruct.hardwareFlow = USART_HARDWARE_FLOW_NONE;
    usartConfigStruct.mode = USART_MODE_TX_RX;
    usartConfigStruct.parity = USART_PARITY_NONE;
    usartConfigStruct.stopBits = USART_STOP_BIT_1;
    usartConfigStruct.wordLength = USART_WORD_LEN_8B;
        /* USART configuration */
    USART_Config(USART1,&usartConfigStruct);
    USART_Enable(USART1);
    Delay_ms(50);
    /* Enable USART1 RXBNE interrput */
    USART_EnableInterrupt(USART1, USART_INT_RXBNE);
    USART_ClearStatusFlag(USART1, USART_FLAG_RXBNE);
    NVIC_EnableIRQRequest(USART1_IRQn,1,0);
void USART1_SendData(uint8_t *dat, uint32_t count)
    while(count--)
        while(USART_ReadStatusFlag(USART1, USART_FLAG_TXBE) == RESET);
        USART_TxData(USART1, *dat++);
void  USART1_IRQHandler(void)
    /* USART1 Recieve Data */
    if(USART_ReadStatusFlag(USART1, USART_FLAG_RXBNE) == SET)
       USART_TxData( USART1,(uint8_t)USART_RxData(USART1));
void UART_Test(void)
                unsigned char Data[]={"This is APM32F411 USART Demo!\r\n"};
                USART1_SendData(Data,31);
我们这里测试的是直接上电之后先发送一个AMP的串口例程,然后中断接收到了数据之后直接返回传送回来。
