[技术问答] PDMA 怎么实现一直接收,我的只能接受一次,必须加上while才可以重复接收
2453|1
 楼主| LYHlaiye 发表于 2024-6-19 20:21 | 显示全部楼层 |阅读模式
void PDMA_Init(uint8_t *g_au8TxBuffer)
    /* Open PDMA Channel */
    PDMA_Open(PDMA, 1 << 1); // Channel 1 for UART1 RX
    // Select basic mode
    PDMA_SetTransferMode(PDMA, 1, PDMA_UART1_RX, 0, 0);
    // Set data width and transfer count
    PDMA_SetTransferCnt(PDMA, 1, PDMA_WIDTH_8, 32);
    //Set PDMA Transfer Address
    PDMA_SetTransferAddr(PDMA, 1, UART1_BASE, PDMA_SAR_FIX, ((uint32_t)(&g_au8RxBuffer[0])), PDMA_DAR_INC);
    //Select Single Request
    PDMA_SetBurstType(PDMA, 1, PDMA_REQ_SINGLE, 0);
#ifdef ENABLE_PDMA_INTERRUPT
    //Set timeout
   // PDMA_SetTimeOut(PDMA, 0, 1, PDMA_TIME);
    PDMA_SetTimeOut(PDMA, 1, 1, PDMA_TIME);
   // PDMA_EnableInt(PDMA, 0, PDMA_INT_TRANS_DONE);
    PDMA_EnableInt(PDMA, 1, PDMA_INT_TRANS_DONE);
    PDMA_EnableInt(PDMA, 1, PDMA_INT_TIMEOUT);
    g_u32IsTestOver = 0;
#endif
MAIN函数:
while (1)
                PDMA_Init(g_au8TxBuffer[0]);
                // Enable UART PDMA Tx and Rx
           UART_PDMA_ENABLE(UART1,UART_INTEN_RXPDMAEN_Msk);
        while(g_u32IsTestOver==0);
        if (g_u32IsTestOver == 1)
                      printf("test done...\n");
                        //RX
                                for(int i=0;i<32;i++)
                                printf("%d:%x\n",i,g_au8RxBuffer[i]);
                                g_au8RxBuffer[i]=0;
        //UART_PDMA_DISABLE(UART1,UART_INTEN_RXPDMAEN_Msk);
 楼主| LYHlaiye 发表于 2024-6-20 09:36 | 显示全部楼层
