[DemoCode下载] BPWM模块的计数器同步启动功能来同时生成多个波形输出
1134|1
 楼主| 小明的同学 发表于 2024-7-13 19:55 | 显示全部楼层 |阅读模式
  1. /**************************************************************************//**
  2. * [url=home.php?mod=space&uid=288409]@file[/url]     main.c
  3. * [url=home.php?mod=space&uid=895143]@version[/url]  V3.00
  4. * [url=home.php?mod=space&uid=247401]@brief[/url]    Demonstrate how to use BPWM counter synchronous start function.
  5. *
  6. * [url=home.php?mod=space&uid=17282]@CopyRight[/url] (C) 2016 Nuvoton Technology Corp. All rights reserved.
  7. ******************************************************************************/
  8. #include <stdio.h>
  9. #include "NuMicro.h"
  10. #define PLL_CLOCK       192000000
  11. void SYS_Init(void)
  12. {
  13.     /* Set XT1_OUT(PF.2) and XT1_IN(PF.3) to input mode */
  14.     PF->MODE &= ~(GPIO_MODE_MODE2_Msk | GPIO_MODE_MODE3_Msk);
  15.     /* Enable HXT clock (external XTAL 12MHz) */
  16.     CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
  17.     /* Wait for HXT clock ready */
  18.     CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
  19.     /* Set core clock as PLL_CLOCK from PLL */
  20.     CLK_SetCoreClock(PLL_CLOCK);
  21.     /* Set PCLK0 = PCLK1 = HCLK/2 */
  22.     CLK->PCLKDIV = (CLK_PCLKDIV_APB0DIV_DIV2 | CLK_PCLKDIV_APB1DIV_DIV2);
  23.     /* Enable UART module clock */
  24.     CLK_EnableModuleClock(UART0_MODULE);
  25.     /* Select UART module clock source */
  26.     CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UART0SEL_HXT, CLK_CLKDIV0_UART0(1));
  27.     /* Enable BPWM0 clock source */
  28.     CLK_EnableModuleClock(BPWM0_MODULE);
  29.     /* Select BPWM module clock source */
  30.     CLK_SetModuleClock(BPWM0_MODULE, CLK_CLKSEL2_BPWM0SEL_PCLK0, 0);
  31.     /* Update System Core Clock */
  32.     /* User can use SystemCoreClockUpdate() to calculate PllClock, SystemCoreClock and CycylesPerUs automatically. */
  33.     SystemCoreClockUpdate();
  34.     /* Set GPB multi-function pins for UART0 RXD and TXD */
  35.     SYS->GPB_MFPH &= ~(SYS_GPB_MFPH_PB12MFP_Msk | SYS_GPB_MFPH_PB13MFP_Msk);
  36.     SYS->GPB_MFPH |= (SYS_GPB_MFPH_PB12MFP_UART0_RXD | SYS_GPB_MFPH_PB13MFP_UART0_TXD);
  37.     /* Set PA.0~5 multi-function pin for BPWM0 channel 0~5 */
  38.     SYS->GPA_MFPL = (SYS->GPA_MFPL & ~SYS_GPA_MFPL_PA0MFP_Msk) | SYS_GPA_MFPL_PA0MFP_BPWM0_CH0;
  39.     SYS->GPA_MFPL = (SYS->GPA_MFPL & ~SYS_GPA_MFPL_PA1MFP_Msk) | SYS_GPA_MFPL_PA1MFP_BPWM0_CH1;
  40.     SYS->GPA_MFPL = (SYS->GPA_MFPL & ~SYS_GPA_MFPL_PA2MFP_Msk) | SYS_GPA_MFPL_PA2MFP_BPWM0_CH2;
  41.     SYS->GPA_MFPL = (SYS->GPA_MFPL & ~SYS_GPA_MFPL_PA3MFP_Msk) | SYS_GPA_MFPL_PA3MFP_BPWM0_CH3;
  42.     SYS->GPA_MFPL = (SYS->GPA_MFPL & ~SYS_GPA_MFPL_PA4MFP_Msk) | SYS_GPA_MFPL_PA4MFP_BPWM0_CH4;
  43.     SYS->GPA_MFPL = (SYS->GPA_MFPL & ~SYS_GPA_MFPL_PA5MFP_Msk) | SYS_GPA_MFPL_PA5MFP_BPWM0_CH5;
  44. }
  45. void UART0_Init()
  46. {
  47.     /* Configure UART0 and set UART0 baud rate */
  48.     UART_Open(UART0, 115200);
  49. }
  50. int32_t main(void)
  51. {
  52.     /* Unlock protected registers */
  53.     SYS_UnlockReg();
  54.     /* Init System, IP clock and multi-function I/O */
  55.     SYS_Init();
  56.     /* Lock protected registers */
  57.     SYS_LockReg();
  58.     /* Init UART to 115200-8n1 for print message */
  59.     UART0_Init();
  60.     printf("+------------------------------------------------------------------------+\n");
  61.     printf("|                          BPWM Driver Sample Code                        |\n");
  62.     printf("|        |\n");
  63.     printf("+------------------------------------------------------------------------+\n");
  64.     printf("  This sample code will output waveform with BPWM0 channel 0~5 at the same time.\n");
  65.     printf("  I/O configuration:\n");
  66.     printf("  waveform output pin: BPWM0_CH0(PA.0), BPWM0_CH1(PA.1), BPWM0_CH2(PA.2), BPWM0_CH3(PA.3), BPWM0_CH4(PA.4), BPWM0_CH5(PA.5)\n");
  67.     printf("Press any key to start.\n");
  68.     getchar();
  69.     /* BPWM0 channel 0~5 frequency and duty configuration are as follows */
  70.     BPWM_ConfigOutputChannel(BPWM0, 0, 1000, 50);
  71.     BPWM_ConfigOutputChannel(BPWM0, 1, 1000, 50);
  72.     BPWM_ConfigOutputChannel(BPWM0, 2, 1000, 50);
  73.     BPWM_ConfigOutputChannel(BPWM0, 3, 1000, 50);
  74.     BPWM_ConfigOutputChannel(BPWM0, 4, 1000, 50);
  75.     BPWM_ConfigOutputChannel(BPWM0, 5, 1000, 50);
  76.     /* Enable counter synchronous start function for BPWM0 channel 0~5 */
  77.     BPWM_ENABLE_TIMER_SYNC(BPWM0, 0x3F, BPWM_SSCTL_SSRC_BPWM0);
  78.     /* Enable output of BPWM0 channel 0~5 */
  79.     BPWM_EnableOutput(BPWM0, 0x3F);
  80.     /* Trigger BPWM counter synchronous start by BPWM0 */
  81.     BPWM_TRIGGER_SYNC_START(BPWM0);
  82.     while(1);
  83. }
  84. /*** (C) COPYRIGHT 2016 Nuvoton Technology Corp. ***/
 楼主| 小明的同学 发表于 2024-7-13 19:56 | 显示全部楼层
这段程序演示了如何使用BPWM模块的计数器同步启动功能来同时生成多个波形输出。让我们逐步解释这个程序的关键部分:
SYS_Init() 函数:
初始化系统时钟和外设模块,设置了HXT(外部晶振)作为系统时钟源,并设置了PLL作为核心时钟源。
选择了UART0模块的时钟源为HXT,并配置了UART0的引脚。
UART0_Init() 函数:
初始化UART0,设置波特率为115200,用于打印消息。
main() 函数:
解锁和锁定保护寄存器,以便初始化和配置系统时钟和外设。
初始化系统(调用SYS_Init())、初始化UART0(调用UART0_Init())。
打印欢迎消息和配置信息。
等待用户按下任意键继续(使用getchar())。
波形输出配置:
使用BPWM_ConfigOutputChannel()函数为BPWM0的6个通道(CH0到CH5)配置波形参数。
参数依次为:BPWM模块、通道号、频率(Hz)、占空比(%)。
这里将每个通道的频率设置为1000Hz,占空比设置为50%。
计数器同步启动配置:
使用BPWM_ENABLE_TIMER_SYNC()函数启用BPWM0的计数器同步启动功能。
参数1:BPWM模块。
参数2:掩码,指定哪些通道需要启用计数器同步启动。0x3F表示6个通道(CH0到CH5)全都启用。
参数3:指定计数器同步启动的来源。这里使用BPWM0作为同步源。
启用输出:
使用BPWM_EnableOutput()函数启用BPWM0的输出。
参数为掩码,同样0x3F表示启用所有6个通道的输出。
触发计数器同步启动:
使用BPWM_TRIGGER_SYNC_START()函数触发BPWM的计数器同步启动。
无限循环:
while(1);确保程序持续运行,以保持波形输出。
这段代码的主要目的是演示如何通过BPWM模块实现多个通道的波形生成,并通过计数器同步启动功能确保这些波形在同一时间开始。
