- // ST7735-library (declaration)
- // Author: Bernhard Bablok
- // The code is based on work from Gavin Lyons, see
- // https://github.com/gavinlyonsrepo/pic_16F18346_projects
- // https://github.com/bablokb/pic-st7735
- #ifndef ST7735_TFT_H
- #define ST7735_TFT_H
- #include <stdbool.h>
- #include <stdint.h>
- #include <string.h>
- #if defined _PTC
-   #include "picconfig.h"
- #endif
- #if defined TFT_ENABLE_FONTS
-   #if !defined TFT_ENABLE_TEXT
-     #define TFT_ENABLE_TEXT
-   #endif
-   #if !defined PROGMEM
-     #define PROGMEM
-   #endif
- #endif
- #if defined TFT_ENABLE_ALL
-   #if !defined TFT_ENABLE_SHAPES
-     #define TFT_ENABLE_SHAPES
-   #endif
-   #if !defined TFT_ENABLE_SCROLL
-     #define TFT_ENABLE_SCROLL
-   #endif
-   #endif
-   #if !defined TFT_ENABLE_ROTATE
-     #define TFT_ENABLE_ROTATE
-   #endif
- #endif
- extern uint8_t tft_width, tft_height;
- #define _swap(a, b) { int16_t t; t = a; a = b; b = t;}
- #define ST7735_NOP     0x00
- #define ST7735_SWRESET 0x01
- #define ST7735_RDDID   0x04
- #define ST7735_RDDST   0x09
- #define ST7735_SLPIN   0x10
- #define ST7735_SLPOUT  0x11
- #define ST7735_PTLON   0x12
- #define ST7735_NORON   0x13
- #define ST7735_INVOFF  0x20
- #define ST7735_INVON   0x21
- #define ST7735_DISPOFF 0x28
- #define ST7735_DISPON  0x29
- #define ST7735_CASET   0x2A
- #define ST7735_RASET   0x2B
- #define ST7735_RAMWR   0x2C
- #define ST7735_RAMRD   0x2E
- #define ST7735_PTLAR   0x30
- #define ST7735_VSCRDEF 0x33
- #define ST7735_COLMOD  0x3A
- #define ST7735_MADCTL  0x36
- #define ST7735_MADCTL_MY 0x80
- #define ST7735_MADCTL_MX 0x40
- #define ST7735_MADCTL_MV 0x20
- #define ST7735_MADCTL_ML 0x10
- #define ST7735_MADCTL_RGB 0x00
- #define ST7735_VSCRSADD 0x37
- #define ST7735_FRMCTR1 0xB1
- #define ST7735_FRMCTR2 0xB2
- #define ST7735_FRMCTR3 0xB3
- #define ST7735_INVCTR  0xB4
- #define ST7735_DISSET5 0xB6
- #define ST7735_PWCTR1  0xC0
- #define ST7735_PWCTR2  0xC1
- #define ST7735_PWCTR3  0xC2
- #define ST7735_PWCTR4  0xC3
- #define ST7735_PWCTR5  0xC4
- #define ST7735_VMCTR1  0xC5
- #define ST7735_RDID1   0xDA
- #define ST7735_RDID2   0xDB
- #define ST7735_RDID3   0xDC
- #define ST7735_RDID4   0xDD
- #define ST7735_PWCTR6  0xFC
- #define ST7735_GMCTRP1 0xE0
- #define ST7735_GMCTRN1 0xE1
- // Color definitions
- #define   ST7735_BLACK   0x0000
- #define   ST7735_BLUE    0x001F
- #define   ST7735_RED     0xF800
- #define   ST7735_GREEN   0x07E0
- #define   ST7735_CYAN    0x07FF
- #define   ST7735_MAGENTA 0xF81F
- #define   ST7735_YELLOW  0xFFE0
- #define   ST7735_WHITE   0xFFFF
- #define LCD_ASCII_OFFSET 0x20 //0x20, ASCII character for Space, The font table starts with this character
- // ******** FUNCTION  PROTOTYPES ************
- // SPI
- void write_command(uint8_t );
- void write_data(uint8_t );
- // Init
- #if defined TFT_ENABLE_GREEN
- void TFT_GreenTab_Initialize(void);
- void Rcmd2green();
- #endif
- #if defined TFT_ENABLE_RED
- void TFT_RedTab_Initialize(void);
- #endif
- #if defined TFT_ENABLE_BLACK
- void TFT_BlackTab_Initialize(void);
- #endif
- #if defined(TFT_ENABLE_RED) || defined(TFT_ENABLE_BLACK)
- void Rcmd2red();
- #endif
- #if defined TFT_ENABLE_GENERIC
- void TFT_ST7735B_Initialize(void);
- void Bcmd();
- #endif
- #if defined TFT_ENABLE_RESET
- void TFT_ResetPIN(void);
- #endif
- void Rcmd1();
- void Rcmd3();
- // Misc + Screen related
- void setAddrWindow(uint8_t , uint8_t , uint8_t , uint8_t );
- void fillScreen(uint16_t color);
- void drawFastVLine(uint8_t x, uint8_t y, uint8_t h, uint16_t color);
- void drawFastHLine(uint8_t x, uint8_t y, uint8_t w, uint16_t color);
- void drawPixel(uint8_t , uint8_t , uint16_t );
- void fillRectangle(uint8_t , uint8_t , uint8_t , uint8_t , uint16_t );
- void fillRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h, uint16_t color);
- void invertDisplay(bool i);
- void NormalDisplay(void);
- void pushColor(uint16_t color);
- //Scroll
- #if defined TFT_ENABLE_SCROLL
- void setScrollDefinition(uint8_t top_fix_height, uint8_t bottom_fix_height, bool _scroll_direction);
- void VerticalScroll(uint8_t _vsp);
- #endif
- // Shapes
- #if defined TFT_ENABLE_SHAPES
- void drawLine(int16_t x0, int16_t y0, int16_t x1, int16_t y1, uint16_t color);
- void drawRectWH(uint8_t x, uint8_t y, uint8_t w, uint8_t h, uint16_t color);
- void drawRoundRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h, uint8_t r, uint16_t color);
- void fillRoundRect(uint8_t x, uint8_t y, uint8_t w, uint8_t h, uint8_t r, uint16_t color);
- void drawCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color);
- void drawCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername, uint16_t color);
- void fillCircleHelper(int16_t x0, int16_t y0, int16_t r, uint8_t cornername, int16_t delta, uint16_t color);
- void fillCircle(int16_t x0, int16_t y0, int16_t r, uint16_t color);
- void drawTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color);
- void fillTriangle(int16_t x0, int16_t y0, int16_t x1, int16_t y1, int16_t x2, int16_t y2, uint16_t color);
- #endif
- // Text
- #if defined(TFT_ENABLE_TEXT)
- void drawChar(uint8_t x, uint8_t y, uint8_t c, uint16_t color, uint16_t bg,  uint8_t size);
- void setTextWrap(bool w);
- void drawText(uint8_t x, uint8_t y, const char *_text, uint16_t color, uint16_t bg, uint8_t size);
- #endif
- #if defined TFT_ENABLE_ROTATE
- void setRotation(uint8_t m);
- #endif
- /// Font data stored PER GLYPH
- typedef struct {
-   uint16_t bitmapOffset; ///< Pointer into GFXfont->bitmap
-   uint8_t width;         ///< Bitmap dimensions in pixels
-   uint8_t height;        ///< Bitmap dimensions in pixels
-   uint8_t xAdvance;      ///< Distance to advance cursor (x axis)
-   int8_t xOffset;        ///< X dist from cursor pos to UL corner
-   int8_t yOffset;        ///< Y dist from cursor pos to UL corner
- } GFXglyph;
- /// Data stored for FONT AS A WHOLE
- typedef struct {
-   uint8_t *bitmap;     ///< Glyph bitmaps, concatenated
-   GFXglyph *glyph;     ///< Glyph array
-   uint16_t first;      ///< ASCII extents (first char)
-   uint16_t last;       ///< ASCII extents (last char)
-   uint8_t yAdvance;    ///< Newline distance (y axis)
-   const char *subset;  ///< subset of chars in the font
- } GFXfont;
- extern GFXfont *_gfxFont;
- void setFont(const GFXfont *f);
- #endif
- // ------ not functional yet ----------------------------------------------
- // needs fat-library
- // BMP processing from SD-card
- #if defined TFT_ENABLE_BMP
- bool bmpDraw(int8_t x, int8_t y, int8_t *bmpname);
- #endif
- #endif
