GD32E230 PWM配置
//GPIO配置
void PWM_gpio_config(void)
rcu_periph_clock_enable(RCU_GPIOA);
gpio_mode_set(GPIOB, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_1);
gpio_output_options_set(GPIOB, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_1);
gpio_af_set(GPIOB, GPIO_AF_1, GPIO_PIN_1);
gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_9);
gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_9);
gpio_af_set(GPIOA, GPIO_AF_2, GPIO_PIN_9);
gpio_mode_set(GPIOA, GPIO_MODE_AF, GPIO_PUPD_NONE, GPIO_PIN_10);
gpio_output_options_set(GPIOA, GPIO_OTYPE_PP, GPIO_OSPEED_50MHZ,GPIO_PIN_10);
gpio_af_set(GPIOA, GPIO_AF_2, GPIO_PIN_10);
void PWM_timer_config(void)
timer_oc_parameter_struct timer_ocintpara;
timer_parameter_struct timer_initpara;
rcu_periph_clock_enable(RCU_TIMER0);
timer_deinit(TIMER0);
rcu_periph_clock_enable(RCU_TIMER2);
timer_deinit(TIMER2);
/* TIMER0 configuration */
timer_initpara.prescaler = 3;
timer_initpara.alignedmode = TIMER_COUNTER_EDGE;
timer_initpara.counterdirection = TIMER_COUNTER_UP;
timer_initpara.period = 999;
timer_initpara.clockdivision = TIMER_CKDIV_DIV1;
timer_initpara.repetitioncounter = 0;
timer_init(TIMER0,&timer_initpara);
timer_init(TIMER2,&timer_initpara);
/* CH1,CH2 and CH3 configuration in PWM mode1 */
timer_ocintpara.ocpolarity = TIMER_OC_POLARITY_HIGH;
timer_ocintpara.outputstate = TIMER_CCX_ENABLE;
timer_ocintpara.ocnpolarity = TIMER_OCN_POLARITY_HIGH;
timer_ocintpara.outputnstate = TIMER_CCXN_ENABLE;
timer_ocintpara.ocidlestate = TIMER_OC_IDLE_STATE_HIGH;
timer_ocintpara.ocnidlestate = TIMER_OCN_IDLE_STATE_LOW;
timer_channel_output_config(TIMER2,TIMER_CH_3,&timer_ocintpara);
timer_channel_output_config(TIMER0,TIMER_CH_1,&timer_ocintpara);
timer_channel_output_config(TIMER0,TIMER_CH_2,&timer_ocintpara);
/* CH1 configuration in PWM mode1,duty cycle 25% */
timer_channel_output_pulse_value_config(TIMER2,TIMER_CH_3,500);
timer_channel_output_mode_config(TIMER2,TIMER_CH_3,TIMER_OC_MODE_PWM0);
timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_1,500);
timer_channel_output_mode_config(TIMER0,TIMER_CH_1,TIMER_OC_MODE_PWM0);
timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_2,500);
timer_channel_output_mode_config(TIMER0,TIMER_CH_2,TIMER_OC_MODE_PWM0);
timer_primary_output_config(TIMER0,ENABLE);
/* auto-reload preload enable */
timer_enable(TIMER0);
timer_primary_output_config(TIMER2,ENABLE);
timer_enable(TIMER2);
int main(void)
//PWM Init Motor
PWM_gpio_config();
PWM_timer_config();
while(1)
timer_channel_output_pulse_value_config(TIMER2,TIMER_CH_3,(uint16)rollPhase[2]);
timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_1,(uint16)rollPhase[0]);
timer_channel_output_pulse_value_config(TIMER0,TIMER_CH_2,(uint16)rollPhase[1]);
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
以上例程经测试OK,希望能帮到你!!
原文链接:https://blog.csdn.net/u014694105/article/details/105976954 |
