arm的系统时钟设置问题
2646|0
 楼主| sxy4517 发表于 2012-6-28 13:54 | 显示全部楼层 |阅读模式
void SystemInit (void)
#if (CLOCK_SETUP)                       /* Clock Setup                        */
  LPC_SC->SCS       = SCS_Val;
  if (SCS_Val & (1 << 5)) {             /* If Main Oscillator is enabled      */
    while ((LPC_SC->SCS & (1<<6)) == 0);/* Wait for Oscillator to be ready    */
  LPC_SC->CCLKCFG   = CCLKCFG_Val;      /* Setup Clock Divider                */
#if (PLL0_SETUP)
  LPC_SC->CLKSRCSEL = CLKSRCSEL_Val;    /* Select Clock Source for PLL0       */
  LPC_SC->PLL0CFG   = PLL0CFG_Val;      /* configure PLL0                     */
  LPC_SC->PLL0FEED  = 0xAA;
  LPC_SC->PLL0FEED  = 0x55;
  LPC_SC->PLL0CON   = 0x01;             /* PLL0 Enable                        */
  while (!(LPC_SC->PLL0STAT & (1<<26)));/* Wait for PLOCK0                    */
  LPC_SC->PLL0CON   = 0x03;             /* PLL0 Enable & Connect              */
  while (!(LPC_SC->PLL0STAT & ((1<<25) | (1<<24))));/* Wait for PLLC0_STAT & PLLE0_STAT */
#endif
#if (PLL1_SETUP)
  LPC_SC->PLL1CFG   = PLL1CFG_Val;
  LPC_SC->PLL1FEED  = 0xAA;
  LPC_SC->PLL1FEED  = 0x55;
  LPC_SC->PLL1CON   = 0x01;             /* PLL1 Enable                        */
  while (!(LPC_SC->PLL1STAT & (1<<10)));/* Wait for PLOCK1                    */
  LPC_SC->PLL1CON   = 0x03;             /* PLL1 Enable & Connect              */
  while (!(LPC_SC->PLL1STAT & ((1<< 9) | (1<< 8))));/* Wait for PLLC1_STAT & PLLE1_STAT */
#else
  LPC_SC->USBCLKCFG = USBCLKCFG_Val;    /* Setup USB Clock Divider            */
#endif
  LPC_SC->PCLKSEL0  = PCLKSEL0_Val;     /* Peripheral Clock Selection         */
  LPC_SC->PCLKSEL1  = PCLKSEL1_Val;
  LPC_SC->PCONP     = PCONP_Val;        /* Power Control for Peripherals      */
  LPC_SC->CLKOUTCFG = CLKOUTCFG_Val;    /* Clock Output Configuration         */
#endif
#if (FLASH_SETUP == 1)                  /* Flash Accelerator Setup            */
  LPC_SC->FLASHCFG  = FLASHCFG_Val;
#endif
谁能大体给讲解一下
