请教MSP430F5438的AD问题
1834|2
 楼主| qinhuan7 发表于 2012-7-27 14:02 | 显示全部楼层 |阅读模式
这是AD配置 P6SEL=0xFF;  //A/D转换
  ADC12CTL0&=~ADC12ENC; //在对控制位进行设置时要先复位转换允许位
  ADC12CTL0=ADC12SHT0_8+ADC12MSC+ADC12ON; //4,3
  ADC12CTL1=ADC12CSTARTADD_0+ADC12SHP+ADC12DIV_7+ADC12SSEL_2+ADC12CONSEQ_1;  //7,4//转换速度是转换所需时间的倒数,此处为103kbps
  ADC12MCTL0=ADC12SREF_6+ADC12INCH_0;
  ADC12MCTL1=ADC12SREF_6+ADC12INCH_1;
  ADC12MCTL2=ADC12SREF_6+ADC12INCH_2;
  ADC12MCTL3=ADC12SREF_6+ADC12INCH_3;
  ADC12MCTL4=ADC12SREF_6+ADC12INCH_4;
  ADC12MCTL5=ADC12SREF_6+ADC12INCH_5;
  ADC12MCTL6=ADC12SREF_6+ADC12INCH_6;
  ADC12MCTL7=ADC12EOS+ADC12SREF_6+ADC12INCH_7;
  ADC12IFG=0;
  ADC12IE=BIT7;  //BIT7,1
  ADC12CTL0=ADC12CTL0|ADC12ENC;
  ADC12CTL0|=ADC12SC;  //启动AD采样
AD中断
#pragma vector=ADC12_VECTOR
__interrupt void ADC12ISR(void)
{  char i,j;
   int tmp;
   long sum0,sum1,sum2,sum3,sum4,sum5,sum6,sum7;
   switch(ADC12IV)
      case 0x14:
               { time_flag=0;
                 ADC12IE=0;
                 _EINT();
                 inch[0][ad_cnt]=ADC12MEM0;
                 inch[1][ad_cnt]=ADC12MEM1;
                 inch[2][ad_cnt]=ADC12MEM2;
                 inch[3][ad_cnt]=ADC12MEM3;
                 inch[4][ad_cnt]=ADC12MEM4;
                 inch[5][ad_cnt]=ADC12MEM5;
                 inch[6][ad_cnt]=ADC12MEM6;
                 inch[7][ad_cnt]=ADC12MEM7;
                 ad_cnt++;
                 ADC12IFG=0;
                 if(ad_cnt<40)
                 { delay(20);
                   ADC12CTL0|=ADC12SC;
                 else
                 { WDT_CTL();
                   ad_flag++;  //用于开机连续采样12的标志
                   sum0=0;sum1=0;sum2=0;sum3=0;sum4=0;sum5=0;sum6=0;sum7=0;
                   for(i=0;i<39;i++)
                   { for(j=0;j<39-i;j++)
                     { if(inch[0][j]>inch[0][j+1]){tmp=inch[0][j];inch[0][j]=inch[0][j+1];inch[0][j+1]=tmp;}
                       if(inch[1][j]>inch[1][j+1]){tmp=inch[1][j];inch[1][j]=inch[1][j+1];inch[1][j+1]=tmp;}
                       if(inch[2][j]>inch[2][j+1]){tmp=inch[2][j];inch[2][j]=inch[2][j+1];inch[2][j+1]=tmp;}
                       if(inch[3][j]>inch[3][j+1]){tmp=inch[3][j];inch[3][j]=inch[3][j+1];inch[3][j+1]=tmp;}
                       if(inch[4][j]>inch[4][j+1]){tmp=inch[4][j];inch[4][j]=inch[4][j+1];inch[4][j+1]=tmp;}
                       if(inch[5][j]>inch[5][j+1]){tmp=inch[5][j];inch[5][j]=inch[5][j+1];inch[5][j+1]=tmp;}
                       if(inch[6][j]>inch[6][j+1]){tmp=inch[6][j];inch[6][j]=inch[6][j+1];inch[6][j+1]=tmp;}
                       if(inch[7][j]>inch[7][j+1]){tmp=inch[7][j];inch[7][j]=inch[7][j+1];inch[7][j+1]=tmp;}
                   for(j=4;j<36;j++)  //求均值
                   { sum0+=inch[0][j];
                     sum1+=inch[1][j];
                     sum2+=inch[2][j];
                     sum3+=inch[3][j];
                     sum4+=inch[4][j];
                     sum5+=inch[5][j];
                     sum6+=inch[6][j];
                     sum7+=inch[7][j];
                   for(j=0;j<11;j++)   //滑动滤波
                   { channel[0][j]=channel[0][j+1];
                     channel[1][j]=channel[1][j+1];
                     channel[2][j]=channel[2][j+1];
                     channel[3][j]=channel[3][j+1];
                     channel[4][j]=channel[4][j+1];
                     channel[5][j]=channel[5][j+1];
                     channel[6][j]=channel[6][j+1];
                     channel[7][j]=channel[7][j+1];
                   channel[0][11]=sum0>>5;
                   channel[1][11]=sum1>>5;
                   channel[2][11]=sum2>>5;
                   channel[3][11]=sum3>>5;
                   channel[4][11]=sum4>>5;
                   channel[5][11]=sum5>>5;
                   channel[6][11]=sum6>>5;
                   channel[7][11]=sum7>>5;
                 break;
      default: break;
  ADC12IFG=0;
  ADC12IE=BIT7;
问题:上电后用串口发回的数据在一段时间内是正常的,但是过一段时间后(时间不确定),AD就停止工作了,串口发回的数据不变,请教各位大虾这是怎么回事?
 楼主| qinhuan7 发表于 2012-7-27 14:10 | 显示全部楼层
补充一下,要是我加定时器,每个1.2s重启AD,即  ADC12CTL0|=ADC12SC;它就可以正常工作了,please tell me why???
 楼主| qinhuan7 发表于 2012-7-27 16:55 | 显示全部楼层
怎么没人呢?
个人签名:把学习当成一种娱乐!
26
