初学edk,有两个问题请教
2244|5
 楼主| wrigleymint 发表于 2012-10-10 20:17 | 显示全部楼层 |阅读模式
ST, AN, TE, DM, IO
初学者,做了edk的6个实验,感觉对edk有了最初级的了解,有些问题想请教大家:
1.想打开别人的工程文件,结果总是不成功,提示错误是:
ERROR:EDK:1550 - IPNAME: microblaze, INSTANCE: microblaze_0 - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 42 - cannot find MPD for the pcore 'microblaze_v7_10_b' in any of the repositories.
ERROR:EDK:1550 - IPNAME: plb_v46, INSTANCE: mb_plb - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 56 - cannot find MPD for the pcore 'plb_v46_v1_02_a' in any of the repositories.
ERROR:EDK:1550 - IPNAME: mpmc, INSTANCE: DDR_SDRAM - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 130 - cannot find MPD for the pcore 'mpmc_v4_01_a' in any of the repositories.
ERROR:EDK:1550 - IPNAME: mdm, INSTANCE: debug_module - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 191 - cannot find MPD for the pcore 'mdm_v1_00_b' in any of the repositories.
ERROR:EDK:1552 - IPNAME:microblaze INSTANCE: microblaze_0 - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 42 - cannot find MPD for the pcore
ERROR:EDK:1552 - IPNAME:plb_v46 INSTANCE: mb_plb - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 56 - cannot find MPD for the pcore
ERROR:EDK:1552 - IPNAME:mpmc INSTANCE: DDR_SDRAM - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 130 - cannot find MPD for the pcore
ERROR:EDK:1552 - IPNAME:mdm INSTANCE: debug_module - E:\qiaodong\FPGA\test_edk0\sp3ekit_101\solutions\lab3\system.mhs line 191 - cannot find MPD for the pcore
INFO:EDK:397 - mpmc (DDR_SDRAM) version 4.03.a is now available, but it does not support the current architecture.
Done.
怎么解决?
2.用sdk中的debug,可以在memory中清楚的看到里面定义的变量值,但是当我想看一些外设的寄存器的时候,总是显示一堆问号。
比如说我想看GPIO的寄存器,在mhs中找到它的bassaddr  = 0x81420000,但是当我在memory中找到这个地址的时候,显示的是一堆问号。
这是什么原因?能解决么?(如果可以的话,edk的软件调试就像单片机一样方便,基本上用不到chipscope了)
mentoscui 发表于 2012-10-10 20:27 | 显示全部楼层
找找MPD吧,看库里有没有?
GoldSunMonkey 发表于 2012-10-10 21:07 | 显示全部楼层
ERROR:EDK:1550 - IPNAME: microblaze, INSTANCE: microblaze_0 - E:\qiao ...
1 没有找IP.
2 这个问题我还没遇到过。
jerry_ls 发表于 2013-1-23 11:07 | 显示全部楼层
你好,我也是初学者,请问你用SDK调试时,会遇到死掉的状态吗
hawksabre 发表于 2013-1-23 20:28 | 显示全部楼层
不太清楚  呵呵   帮你把这个问题顶一个   呵呵   猛顶
charlydady 发表于 2013-1-25 12:33 | 显示全部楼层
https://bbs.21ic.com/forum.php?mo ... &fromuid=942616
我遇到过,而且有时候FPGA断电后,SDK要关闭再重新打开才能再RUN。
