请教两个STM32芯片通过 SPI 通讯问题
2909|1
 楼主| zhang..yb 发表于 2012-10-23 15:53 | 显示全部楼层 |阅读模式
从机设置程序:  SPI2口
/* DMA1 channel4 configuration ---------------------------------------------*/
  DMA_DeInit(DMA1_Channel4);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)SPI2_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SPI2_Buffer_Rx;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = BufferSize;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_Byte;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_Byte;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Normal;
  DMA_InitStructure.DMA_Priority = DMA_Priority_VeryHigh;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel4, &DMA_InitStructure);
  /* DMA1 channel5 configuration ---------------------------------------------*/
  DMA_DeInit(DMA1_Channel5);
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SPI2_Buffer_Tx;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;
  /* SPI2 configuration ------------------------------------------------------*/
  SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex;//SPI_Direction_1Line_Tx;
  SPI_InitStructure.SPI_Mode = SPI_Mode_Slave;
  SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b;
  SPI_InitStructure.SPI_CPOL = SPI_CPOL_High;
  SPI_InitStructure.SPI_CPHA = SPI_CPHA_1Edge;
  SPI_InitStructure.SPI_NSS = SPI_NSS_Hard;
  //SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_4;
  SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB;
  SPI_InitStructure.SPI_CRCPolynomial = 7;
  SPI_Init(SPI2, &SPI_InitStructure);
  /* Enable SPI2 Rx/Tx request */
  SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Rx, ENABLE);
  SPI_I2S_DMACmd(SPI2, SPI_I2S_DMAReq_Tx, ENABLE);
  /* Enable SPI2 */
  SPI_Cmd(SPI2, ENABLE);
  /* Enable DMA1 Channel4 */
  DMA_Cmd(DMA1_Channel4, ENABLE);
  /* Enable DMA1 Channel5 */
  DMA_Cmd(DMA1_Channel5, ENABLE);
主机设置程序:  SPI1 口
  /* DMA1 channel3 configuration ---------------------------------------------*/
  DMA_DeInit(DMA1_Channel3);
  DMA_InitStructure.DMA_PeripheralBaseAddr = (u32)SPI1_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SPI1_Buffer_Tx;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralDST;//PeripheralSRC;
  DMA_Init(DMA1_Channel3, &DMA_InitStructure);
  /* DMA1 channel2 configuration ---------------------------------------------*/
  DMA_DeInit(DMA1_Channel2);
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)SPI1_Buffer_Rx;
  DMA_Init(DMA1_Channel2, &DMA_InitStructure);
  /* SPI1 configuration ------------------------------------------------------*/
  SPI_InitStructure.SPI_Mode = SPI_Mode_Master;
  SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_128;
  SPI_Init(SPI1, &SPI_InitStructure);
  /* Enable SPI1 NSS output for master mode */
  SPI_SSOutputCmd(SPI1, ENABLE);
  /* Enable SPI1 Rx/Tx request */
  SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Rx, ENABLE);
  SPI_I2S_DMACmd(SPI1, SPI_I2S_DMAReq_Tx, ENABLE);
  /* Enable SPI1 */
  SPI_Cmd(SPI1, ENABLE);
  /* Enable DMA1 Channel2 */
  DMA_Cmd(DMA1_Channel2, ENABLE);
  /* Enable DMA1 Channel3 */
  DMA_Cmd(DMA1_Channel3, ENABLE);
互联后主从机收到的数据都不对的,是哪里有问题?
d_zhzh 发表于 2012-10-31 20:18 | 显示全部楼层
请问,有用过查询模式或者中断模式测试成功过吗?:)
