[Quartus] XC6SLX9通过JTAG向SPI flash 下载程序失败检测不到FLASH
10587|30
 楼主| lsh1985 发表于 2012-10-27 10:51 | 显示全部楼层 |阅读模式
我这提示的错误信息如下:
'1': Programming device...
LCK_cycle = NoWait.
LCK cycle: NoWait
done.
'1': Reading status register contents...
[0] CRC ERROR                                                              :         0
[1] IDCODE ERROR                                                           :         0
[2] DCM LOCK STATUS                                                        :         0
[3] GTS_CFG_B STATUS                                                       :         0
[4] GWE STATUS                                                             :         0
[5] GHIGH STATUS                                                           :         0
[6] DECRYPTION ERROR                                                       :         0
[7] DECRYPTOR ENABLE                                                       :         0
[8] HSWAPEN PIN                                                            :         0
[9] MODE PIN M[0]                                                          :         0
[10] MODE PIN M[1]                                                         :         0
[11] RESERVED                                                              :         0
12] INIT_B PIN                                                            :         0[13] DONE PIN                                                              :         0
[14] SUSPEND STATUS                                                        :         0
[15] FALLBACK STATUS                                                       :         0
INFO:iMPACT:2219 - Status register values:
INFO:iMPACT - 0000 0000 0000 0000
INFO:iMPACT:579 - '1': Completed downloading bit file to device.
INFO:iMPACT:188 - '1': Programming completed successfully.
LCK_cycle = NoWait.
LCK cycle: NoWait
INFO:iMPACT - '1': Checking done pin....done.
'1': Programmed successfully.
PROGRESS_END - End Operation.
Elapsed time =      3 sec.
// *** BATCH CMD : copyDevice -p 1
Selected part: M25P16
// *** BATCH CMD : attachflash -position 1 -spi "M25P16"
Unprotect sectors: FALSE
// *** BATCH CMD : assignfiletoattachedflash -position 1 -file "F:/ceshi/xianshi/Untitled.mcs"
Setting Target Device to Mode:BS, Device position 0.
INFO:iMPACT - Current time: ���� ʮ�� 26 11// *** BATCH CMD : Program -p 1 -dataWidth 1 -spionly -e -v -loadfpga
INFO:iMPACT:583 - '0': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '0':  Device IDCODE :        00000000000000000000000000000000
INFO:iMPACT:1579 - '0': Expected IDCODE:    00000100000000000001000010010011
PROGRESS_START - Starting Operation.
INFO:iMPACT:583 - '1': The idcode read from the device does not match the idcode in the bsdl File.
INFO:iMPACT:1578 - '1':  Device IDCODE :        00000000000000000000000000000000
INFO:iMPACT:1579 - '1': Expected IDCODE:    00000100000000000001000010010011
Elapsed time =      0 sec.
:23:09 2012
:10:16 2012
:09:59 2012
:09:30 2012
:50:42 2012
:50:17 2012
下程序的过程中,发现CSO_B一直是高电平,不能变低,init信号一直是低电平,done 信号一直是高电平有时钟信号
 楼主| lsh1985 发表于 2012-10-27 10:59 | 显示全部楼层
lanpad 发表于 2012-10-27 14:54 | 显示全部楼层
同问
我的连FPGA芯片也检测不到
是不是手册的错误?
 楼主| lsh1985 发表于 2012-10-27 16:50 | 显示全部楼层
3# lanpad 你的电路时怎么连接的呀
星星之火红 发表于 2012-10-27 22:23 | 显示全部楼层
这本身就有问题啊
 楼主| lsh1985 发表于 2012-10-28 00:31 | 显示全部楼层
能知道这是什么问题吗
 楼主| lsh1985 发表于 2012-10-28 07:12 | 显示全部楼层
能不能帮我看看硬件接口有什么问题吗,我的VCCINT是1.237V,VCCO和VCAUX都是3.3V
pocker5200 发表于 2012-10-28 22:11 | 显示全部楼层
VCCAUX的电压应该是2.5V
 楼主| lsh1985 发表于 2012-10-28 22:17 | 显示全部楼层
8# pocker5200 可是芯片资料上写的是VCCAUX可以是3.3V的
 楼主| lsh1985 发表于 2012-10-28 22:26 | 显示全部楼层
2.5V;
3.3V optional
星星之火红 发表于 2012-10-28 23:10 | 显示全部楼层
对原理图和XILINX推荐的。
GoldSunMonkey 发表于 2012-10-28 23:29 | 显示全部楼层
请好好比较您的电路图和xilinx推荐的是不是一样的。如果完全一样检查板卡电压对否?
如果都对,那请检查芯片是否有虚焊等情况。
如果,没有有虚焊等情况,检查信号完整性有没有问题。
如果都没有问题,就是芯片坏了。
如果以上都没有问题,那我也不知道说什么了。
rx_78gp02a 发表于 2012-10-28 23:30 | 显示全部楼层
1# lsh1985
我记得TDO是不用上拉的
Backkom80 发表于 2012-10-29 09:05 | 显示全部楼层
参看xilinx给配置方面文档:
Spartan-6 FPGA Configuration User Guide.pdf
 楼主| lsh1985 发表于 2012-10-29 10:17 | 显示全部楼层
13# rx_78gp02a 我TDO去掉上拉也不行
lanpad 发表于 2012-10-29 10:52 | 显示全部楼层
https://bbs.21ic.com/icview-388282-1-1.html
 楼主| lsh1985 发表于 2012-10-29 19:59 | 显示全部楼层
还是不行,想问一下,电路和VCCINT ,VCCAUX,VCCO的上电顺序有没有关系
星星之火红 发表于 2012-10-29 22:40 | 显示全部楼层
GoldSunMonkey 发表于 2012-10-29 23:01 | 显示全部楼层
S6没有顺序要求
 楼主| lsh1985 发表于 2012-10-29 23:26 | 显示全部楼层
19# GoldSunMonkey 谢谢猴哥
