单片机问题return-expression on void-function
6596|0
 楼主| duhake 发表于 2012-11-10 15:14 | 显示全部楼层 |阅读模式
出错的是这个段代码void read_byte(uchar date)
uchar i,k;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i--)
scl=1;
delay();
k=(k<<1)|sda;
scl=0;
delay();
delay();
return(k);
这个是全部代码#include<reg52.h>
#define uint unsigned int
#define uchar unsigned char
bit write=0;
sbit sda=P2^0;
sbit scl=P2^1;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,0x66,
0x6d,0x7d,0x07,0x7f,0x6f,
0x77,0x7c,0x39,0x5e,0x79,
0x71};
void delay()
void delayms(uint xms)
uint i,j;
for(i=xms;i>0;i--)
for(j=110;j>0;j--);
void start()   //启动信号
sda=1;
delay();
scl=1;
delay();
scl=0;
delay();
void stop()
sda=0;
delay();
scl=1;
delay();
sda=1;
delay();
void respons()   //应答信号
uchar i;
scl=1;
delay();
while(sda=1&&(i<250))
i++;
scl=0;
delay();
void init()
sda=1;
delay();
scl=1;
delay();
void write_byte(uchar date)
uchar i,temp;
temp=date;
for(i=0;i<8;i--)
temp=temp<<1;
scl=0;
delay();
sda=CY;
delay();
scl=1;
scl=0;
delay();
sda=1;
delay();
uchar i,k;
scl=0;
delay();
sda=1;
delay();
for(i=0;i<8;i--)
scl=1;
delay();
k=(k<<1)|sda;
scl=0;
delay();
delay();
return(k);
void write_add(uchar address,uchar date)
start();
write_byte(0xa0);
respons();
write_byte(address);
respons();
write_byte(date);
respons();
stop();
uchar read_add(uchar address)
uchar date;
start();
write_byte(0xa0);
respons();
respons();
start();
write_byte(0xa1);
respons();
date=read_byte();
stop();
return date;
void display(uchar bai_c,uchar sh_c)
dula=1;
P0=table[bai_c];
dula=0;
P0=0xff;
wela=1;
P0=0x7e;
wela=0;
delayms(5);
dula=1;
P0=table[sh_c];
dula=0;
P0=0xff;
wela=1;
P0=0x7d;
wela=0;
delayms(5);
void main()
init();
sec=read_add(2);
if(sec>100)
sec=0;
TMOD=0x01;
TH0=(65536-45872)/256;
TL0=(65536-45872)%256;
EA=1;
ET0=1;
TR0=1;
while(1)
display(sec/10;sec%10);
if(write=1)   //判断计时器是否计时到一秒
write=0;
write_add(2,sec);  //在24c02的地址中写入数据sec
void to() interrupt 1
tcnt++;
if(tcnt>=20)
tcnt=0;
sec++;
write=1;
if(sec==100)  //定时100,从零开始
sec=0;
}  百度上说把void改为uchar,但还是不得,求高手指点
