STM32F205 CAN通信问题
5250|6
 楼主| na_sh13 发表于 2012-11-10 17:31 | 显示全部楼层 |阅读模式
使用ST的例程环回模式是可以的,小弟是新手,请问要改成正常模式怎么改?
我只是改了CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;  发现发送不成功,发送后检查状态CAN_TransmitStatus  一直没有CANTXOK,(用示波器看TX引脚也没有波形)是不是还要改别的地方?
#ifdef USE_CAN1
  /* CANx Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);
#else /* USE_CAN2 */
  /* CAN1 & 2  Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1 | RCC_APB1Periph_CAN2, ENABLE);
#endif  /* USE_CAN1 */
TestStatus CAN_Polling(void)
  /* CAN register init */
   CAN_DeInit(CANx);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM = DISABLE;
  CAN_InitStructure.CAN_ABOM = DISABLE;
  CAN_InitStructure.CAN_AWUM = DISABLE;
  CAN_InitStructure.CAN_NART = DISABLE;
  CAN_InitStructure.CAN_RFLM = DISABLE;
  CAN_InitStructure.CAN_TXFP = DISABLE;
  CAN_InitStructure.CAN_Mode = CAN_Mode_Normal;//只改了此处 设为正常模式
  CAN_InitStructure.CAN_SJW = CAN_SJW_1tq;
  /* CAN Baudrate = 125kbps (CAN clocked at 30 MHz) */
  CAN_InitStructure.CAN_BS1 = CAN_BS1_6tq;
  CAN_InitStructure.CAN_BS2 = CAN_BS2_8tq;
  CAN_InitStructure.CAN_Prescaler = 16;
  CAN_Init(CANx, &CAN_InitStructure);
  /* CAN filter init */
#ifdef  USE_CAN1
  CAN_FilterInitStructure.CAN_FilterNumber = 0;
  CAN_FilterInitStructure.CAN_FilterNumber = 14;
  CAN_FilterInitStructure.CAN_FilterMode = CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale = CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh = 0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow = 0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0;
  CAN_FilterInitStructure.CAN_FilterActivation = ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  /* transmit */
  TxMessage.StdId = 0x11;
  TxMessage.RTR = CAN_RTR_DATA;
  TxMessage.IDE = CAN_ID_STD;
  TxMessage.DLC = 4;
  TxMessage.Data[0] = 0x1;
  TxMessage.Data[1] = 0x2;
  TxMessage.Data[2] = 0x3;
  TxMessage.Data[3] = 0x4;
  TransmitMailbox = CAN_Transmit(CANx, &TxMessage);
  i = 0;
  while((CAN_TransmitStatus(CANx, TransmitMailbox)  !=  CANTXOK) && (i  !=  0xFFFF))//在环回模式下正常,换成正常模式发送状态函数就一直不返回CANTXOK
    i++;
  i = 0;
  while((CAN_MessagePending(CANx, CAN_FIFO0) < 1) && (i  !=  0xFFFF))
    i++;
void NVIC_Config(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  /* Enable CANx RX0 interrupt IRQ channel */
#ifdef  USE_CAN1
  NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX0_IRQn;
  NVIC_InitStructure.NVIC_IRQChannel = CAN2_RX0_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
 楼主| na_sh13 发表于 2012-11-11 11:03 | 显示全部楼层
各位大哥,回个话啊!
阿南 发表于 2012-11-11 18:58 | 显示全部楼层
找个现成的例子,测试一下先吧
airwill 发表于 2012-11-12 12:33 | 显示全部楼层
根据 CAN 协议, 后面还要有从机做应答的.
所以一直没有CANTXOK, 属于正常情况.
再找一个节点, 或者两个板子连接起来一起调试, 就没有这个问题了.
STM32F205 有两个 CAN, 一起使用可以构成两个节点调试.
嗯, 呵呵, 我就是这么干的.
 楼主| na_sh13 发表于 2012-11-13 16:32 | 显示全部楼层
4# airwill
我现在的情况是,我的板子连接两个经过验证的CAN设备(有120欧终端电阻),其中一个设备持续发CAN帧,在芯片RX引脚上能看到波形,但接收不到数据。如果用CAN1或CAN2发送数据,数据会放在发送邮箱里,然后持续挂号等待,就这么一直等,发不出去。我把板子的两个CAN连起来调也是一样结果。
airwill 发表于 2012-11-13 18:21 | 显示全部楼层
can 的初始化里没有看到你对 CAN 对应 IO 引脚的设置哪
 楼主| na_sh13 发表于 2012-11-14 16:12 | 显示全部楼层
6# airwill
的确是我的GPIO初始化错了,我原来的代码
//CAN init
  /* Configure CAN pin: RX */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_CAN_RX;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  GPIO_Init(GPIO_CAN, &GPIO_InitStructure);
  /* Configure CAN pin: TX */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_CAN_TX;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
后来看了手册发现F20x的还要加东西,如下:
/* Enable GPIO clock */
  RCC_AHB1PeriphClockCmd(CAN_GPIO_CLK, ENABLE);
  /* Connect CAN pins to AF9 */
  GPIO_PinAFConfig(CAN_GPIO_PORT, CAN_RX_SOURCE, CAN_AF_PORT);
  GPIO_PinAFConfig(CAN_GPIO_PORT, CAN_TX_SOURCE, CAN_AF_PORT);
  /* Configure CAN RX and TX pins */
  GPIO_InitStructure.GPIO_Pin = CAN_RX_PIN | CAN_TX_PIN;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd  = GPIO_PuPd_UP;
  GPIO_Init(CAN_GPIO_PORT, &GPIO_InitStructure);
主要F20x系列的手册是英文版的,10x系列是中文版。我主要看中文版的,结果GPIO初始化这里1 2不同,而且网上的参考例程都是1系列的,对照例程没发现什么错误,所以就卡在这了。
现在TX能发了,但可能是波特率不正确,要解决一个又一个的问题啊
谢谢楼上指点!
