CKFA的CMD,其中
MEMORY
PAGE 0: /* Program Memory */
/* Memory (RAM/FLASH/OTP) blocks can be moved to PAGE1 for data allocation */
RAMM0M1 : origin = 0x000100, length = 0x000200 /* on-chip RAM block M0 */
OTP : origin = 0x3D7800, length = 0x000800 /* on-chip OTP */
FLASHJ : origin = 0x3D8000, length = 0x002000 /* on-chip FLASH */
FLASHI : origin = 0x3DA000, length = 0x002000 /* on-chip FLASH */
FLASHH : origin = 0x3DC000, length = 0x004000 /* on-chip FLASH */
FLASHG : origin = 0x3E0000, length = 0x004000 /* on-chip FLASH */
FLASHF : origin = 0x3E4000, length = 0x004000 /* on-chip FLASH */
FLASHE : origin = 0x3E8000, length = 0x004000 /* on-chip FLASH */
FLASHD : origin = 0x3EC000, length = 0x004000 /* on-chip FLASH */
FLASHC : origin = 0x3F0000, length = 0x004000 /* on-chip FLASH */
FLASHB : origin = 0x3F4000, length = 0x002000 /* on-chip FLASH */
FLASHA : origin = 0x3F6000, length = 0x001F80 /* on-chip FLASH */
CSM_RSVD : origin = 0x3F7F80, length = 0x000076 /* Part of FLASHA. Program with all 0x0000 when CSM is in use. */
BEGIN : origin = 0x3F7FF6, length = 0x000002 /* Part of FLASHA. Used for "boot to Flash" bootloader mode. */
CSM_PWL : origin = 0x3F7FF8, length = 0x000008 /* Part of FLASHA. CSM password locations in FLASHA */
ROM : origin = 0x3FF000, length = 0x000FC0 /* Boot ROM available if MP/MCn=0 */
RESET : origin = 0x3FFFC0, length = 0x000002 /* part of boot ROM (MP/MCn=0) or XINTF zone 7 (MP/MCn=1) */
VECTORS : origin = 0x3FFFC2, length = 0x00003E /* part of boot ROM (MP/MCn=0) or XINTF zone 7 (MP/MCn=1) */
PAGE 1 :
SCIA : origin = 0x007050, length = 0x000010 /* SCI-A registers */
RAML0L1 : origin = 0x008000, length = 0x002000 /* on-chip RAM block L0 & L1 */
RAMM0M1 : origin = 0x000300, length = 0x000500 /* on-chip RAM block M0 */
RAMH0_1 : origin = 0x3F8000, length = 0x001000 /* on-chip RAM block H0 */
RAMH0_2 : origin = 0x3F9000, length = 0x001000 /* on-chip RAM block H0 */
PAGE 2 :
SECTIONS
.text_unsecured : > RAMM0M1 PAGE = 0
.\debug\obj\unlock_main.obj (.text)
.\debug\obj\DSP281x_CodeStartBranch.obj (.text)
.\debug\obj\Example_Flash281x_CsmKeys.obj (.text)
.\debug\obj\DSP281x_MemCopy.obj (.text)
rts2800_ml.lib (.text)
.econst_unsecured : > RAMM0M1 PAGE = 0
.\debug\obj\unlock_main.obj (.econst)
.text : LOAD = RAMH0_1,
RUN = RAML0L1,
LOAD_START(_textLoadStart),
LOAD_END(_textLoadEnd),
RUN_START(_textRunStart),
PAGE = 1
.econst : LOAD = RAMH0_1,
RUN = RAML0L1,
LOAD_START(_econstLoadStart),
LOAD_END(_econstLoadEnd),
RUN_START(_econstRunStart),
PAGE = 1
.cinit : > RAMM0M1 PAGE = 0
/* User Defined Sections */
codestart : > RAMM0M1 PAGE = 0
BlockTransferBuffer1: > RAMH0_1 PAGE = 2
BlockTransferBuffer2: > RAMH0_2 PAGE = 2
csmpasswds : > CSM_PWL PAGE = 0
csm_rsvd : > CSM_RSVD PAGE = 0
/* Allocate uninitalized data sections: */
.stack : > RAMM0M1 PAGE = 1
.ebss : > RAML0L1 PAGE = 1
/* .reset is a standard section used by the compiler. It contains the */
/* the address of the start of _c_int00 for C Code. /*
/* When using the boot ROM this section and the CPU vector */
/* table is not needed. Thus the default type is set here to */
/* DSECT */
.reset : > RESET, PAGE = 0, TYPE = DSECT
vectors : > VECTORS PAGE = 0, TYPE = DSECT
.SCIARegs : > SCIA PAGE = 1
我用CCSV4编译,说找不到 .\debug\obj\unlock_main.obj (.text)
疑问1:里面出现的obj 和 lib是什么意思?看了TI手册还没找到。
疑问2:介绍CMD的一篇文档说cmd空间要把装载和运行分开,分别在page0 page1,但这个例子好像没有这么处理,都放在page1了,这有何影响?
疑问3:同一片文档里说修改rts2xx.lib,释放boot.asm做参数修改等,生成新的rts2xx.lib是否我这也必须做?原因和目的是什么?
