PWM输出不对
3043|2
 楼主| learnxp 发表于 2013-1-11 21:54 | 显示全部楼层 |阅读模式
做BLDC驱动IR2136,按照公式,输出12.5K的PWM,可用示波器看,输出的只有1.25K,少了10倍,这是为什么啊,是不是我哪里没有设置好啊,但我用KEIL模拟的是12.5K,用IC时只有1.25K了
是不是SystemInit有问题啊,我是用SDK 3.5的LIB
希望那个大侠提醒一下啊
下面是code:
#define PWM_PERIOD 0x0B3F   //(72000000 / (2 * 12500)) - 1
TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
TIM_OCInitTypeDef  TIM_OCInitStructure;
TIM_BDTRInitTypeDef  TIM_BDTRInitStructure;
TIM_DeInit(TIM1);
TIM_TimeBaseStructure.TIM_Prescaler = 0;
TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_CenterAligned3;
TIM_TimeBaseStructure.TIM_Period = PWM_PERIOD;
TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV2;
TIM_TimeBaseStructure.TIM_RepetitionCounter = 1;
TIM_TimeBaseInit(TIM1,&TIM_TimeBaseStructure);
TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
TIM_OCInitStructure.TIM_Pulse = PWM_PERIOD >> 1;
TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_Low;
TIM_OCInitStructure.TIM_OCIdleState = TIM_OCIdleState_Set;
TIM_OCInitStructure.TIM_OCNIdleState = TIM_OCNIdleState_Set;
TIM_OC1Init(TIM1,&TIM_OCInitStructure);
TIM_OC2Init(TIM1,&TIM_OCInitStructure);
TIM_OC3Init(TIM1,&TIM_OCInitStructure);
TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Disable;
TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;
TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_1;
TIM_BDTRInitStructure.TIM_DeadTime = 0;;
TIM_BDTRInitStructure.TIM_Break = TIM_Break_Enable;
TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_Low;
TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Enable;
TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
TIM_CCPreloadControl(TIM1, ENABLE);
TIM_SelectCOM(TIM1,ENABLE);
  TIM_ITConfig(TIM1, TIM_IT_Break | TIM_IT_COM,ENABLE);
TIM_Cmd(TIM1,ENABLE);
TIM_CtrlPWMOutputs(TIM1,ENABLE);
 楼主| learnxp 发表于 2013-1-14 16:26 | 显示全部楼层
有那为DX出来帮助一下啊
yjmwxwx 发表于 2013-1-15 23:44 | 显示全部楼层
看不懂函数库版本啊。。
系统时钟初始化有无问题?
定时器时钟有没有分频?
看看下面几个寄存器里面是啥东西。。。 (俺也是新手
RCC_CR                  0x40021000
RCC_CFGR                0x40021004
TIM1_CR1                0x40012C00
TIM1_PSC                0x40012C28
TIM1_ARR                0x40012C2C
