基于FPGA的图像处理(五)--状态机
1577|4
 楼主| LMQQ 发表于 2013-1-22 21:37 | 显示全部楼层 |阅读模式
    使用FPGA实现各种算法时,状态机是很常用的方法,在SysGen中有两种非常简便的方法构建状态机,一是使用Mcode,以switch-case语句轻松实现,二是使用SysGen自带状态机模块。
     状态机
假设我们要从01序列中检测出1011序列,则状态机模型如下
Next State Matrix:[0 1; 2 1; 0 3; 2 1]
Output Matrix : [0 0; 0 0; 0 0; 0 1]
一、使用Mcode实现
上一篇博客讲解了在Sysgen中Mcode的限制能力,这里直接使用
构建模型如下:
Singal From Workspace用于产生一个01序列,作为输入信号。
gatwayIn将数据类型转化为UFix_1_0
添加Mcode函数stateMcode.m
[plain] view plaincopy
  • <span style="font-size:24px;">function [nextState, matched] = stateMcode(currentState, din)
  • % This is the update function for detecting a pattern of 1011
  • % This function represents a stateless and combination logic block.
  • % The output nextState should be to a register, and the output
  • % of the register should be fed back to the input currentState.
  • % Because the state register block has a feed back connection, in
  • % order to propagate the port prototypes automatically, the prototype
  • % of nextState should be determined only by constants or through
  • % an explicity xfix() call.
  •   seen_none = 0; % initial state, if input is 1, switch to seen_1
  •   seen_1 = 1;    % first 1 has been seen, if input is 0, switch
  •                  % seen_10
  •   seen_10 = 2;   % 10 has been detected, if input is 1, switch to
  •                  % seen_1011
  •   seen_101 = 3;  % now 101 is detected, is input is 1, 1011 is
  •                  % detected and the FSM switches to seen_1
  •   % the default value of matched is false
  •   matched = false;
  •   switch currentState
  •    case seen_none
  •     if din==1
  •       nextState = seen_1;
  •     else
  •       nextState = seen_10;
  •     end
  •    case seen_1 % seen first 1
  •     if din==1
  •     else
  •     end
  •    case seen_10 % seen 10
  •     if din==1
  •       nextState = seen_101;
  •     else
  •       % no part of sequence seen, go to seen_none
  •       nextState = seen_none;
  •     end
  •    case seen_101
  •     if din==1
  •       matched = true;
  •     else
  •       matched = false;
  •     end
  •    otherwise
  •     % if nextState is not assigned outside the switch statement,
  •     % an otherwise statment is required
  •   end
  • </span>
Scope效果如图:
二、使用Mealy State Machine模块实现
构建模型:
设置Mealy State Machine参数,就是状态机的参数
仿真结果如下:
在进行FPGA图像处理时,经常会用到状态机,这几天刚学习过,记录一下,其实使用Verilog直接实现也不是很难,只是会比SysGen稍微麻烦一些,修改起来也会花费更多的时间。
Model Based Design 在Xilinx 的工具中逐渐得到加强,相信以后会更加的方便。
GoldSunMonkey 发表于 2013-1-22 21:46 | 显示全部楼层
很好,学习啦
feihong777 发表于 2013-1-23 22:28 | 显示全部楼层
没有图片啊
qin552011373 发表于 2013-1-27 20:41 | 显示全部楼层
看不到图
GoldSunMonkey 发表于 2013-1-27 20:55 | 显示全部楼层
看不到图
不知道为什么看不见图
