[放大器-信号链] TI TAS5630模拟输入300W立体声D类放大方案
9262|12
 楼主| 51xlf 发表于 2013-1-31 14:21 | 显示全部楼层 |阅读模式
TI 公司的TAS5630 是集成了反馈的模拟输入300W立体声(总功率600W)的D类放大器,能从单电源50V向4-8欧姆扬声器提供高达300W立体声,具有传统AB类放大器的性能(<0.03% THD)和D类放大器的电源效率.它的SNR大于100dB,PSRR为80dB,功率级的效率高达88%,主要用于Mini组合系统,AV接收器,DVD接收器和有源扬声器.本文介绍TAS5630主要特性, 功能方框图, 典型系统方框图,几种应用电路以及TAS5630PHD2EVM评估板主要特性,详细电路图和材料清单(BOM).
The TAS5630 is a high performance analog input Class D amplifier with integrated closed loop feedback technology (known as PurePath™ HD) with the ability to drive up to 300W Stereo into 4 to 8 Speakers from a single 50V supply.
PurePath™ HD technology enables traditional AB-Amplifier performance (<0.03% THD) levels while providing the power efficiency of traditional class D amplifiers.
Unlike traditional Class D amplifiers, the distortion curve only increases once the output levels move into clipping.
PurePath™ HD technology enables lower idle losses making the device even more efficient. Coupled with TI’s Class G power supply reference design for TAS563x, industry leading levels of efficiency can be achieved.
TAS5630主要特性:
PurePath™ HD Enabled Integrated Feedback Provides:
Signal Bandwidth up to 80kHz for High Frequency Content From HD Sources
Ultralow 0.03% THD at 1W into 4
Flat THD at all Frequencies for Natural Sound
80dB PSRR (BTL, No Input Signal)
>100dB (A weighted) SNR
Click and Pop Free Startup
Multiple Configurations Possible on the Same PCB With Stuffing Options:
Mono Parallel Bridge Tied Load (PBTL)
Stereo Bridge Tied Load (BTL)
2.1 Single Ended Stereo Pair and Bridge Tied Load Subwoofer
Quad Single Ended Outputs
Total Output Power at 10%THD+N
600W in Mono PBTL Configuration
300W per Channel in Stereo BTL Configuration
145W per Channel in Quad Single Ended Configuration
High Efficiency Power Stage (>88%) With 60-m Output MOSFETs
Two Thermally Enhanced Package Options:
PHD (64-Pin QFP)
DKD (44-Pin PSOP3)
TAS5630应用:
• Mini Combo System
23• AV Receivers
• DVD Receivers
• Active Speakers
图2.TAS5630典型系统方框图
图3.TAS5630带BD调制滤波器的差分输入BTL应用电路图
图4.TAS5630带BD调制滤波器的差分输入(2N)PBTL应用电路图
 楼主| 51xlf 发表于 2013-1-31 14:22 | 显示全部楼层
图5.TAS5630典型SE应用电路图
图6.TAS5630 2.1系统差分输入BTL和不平衡输入SE应用电路图
图7.TAS5630带BD调制滤波器DKD封装的差分输入BTL应用电路图
TAS5630PHD2EVM评估板
The TAS5630PHD is a high-performance, integrated Stereo Feedback Analog-Input Digital Amplifier Power Stage designed to drive 4Ω speakers at up to 300W per channel. This amplifier requires only a simple passive demodulation filter to deliver high-quality, high-efficiency audio amplification.
This EVM is configured with 2 BTL channels and the possibility to apply either a single ended or a differential analog input signal. It is also possible to configure the two BTL channels into one parallel BTL (PBTL) channel.
The OPA1632 is a High Performance Fully Differential Audio Op Amp designed to allow operation with single ended or differential input signals to the EVM.
This EVM is a complete stereo analog input 2 × 300 W power amplifier ready for evaluation and great music.
TAS5630PHD2EVM 指标:
图8.TAS5630PHD2EVM评估板外形图
图9.TAS5630PHD2EVM评估板电路图(1)
图10.TAS5630PHD2EVM评估板电路图(2)
TAS5630PHD2EVM材料清单:
randyhsd 发表于 2013-2-1 11:17 | 显示全部楼层
梅花望青竹 发表于 2013-2-2 23:46 | 显示全部楼层
这个方案很齐全的,谢谢分享了
ppxia 发表于 2013-2-4 09:25 | 显示全部楼层
玩过,不过俺放弃了!:(
lanjin3528517 发表于 2013-4-18 14:03 | 显示全部楼层
请问下该芯片输入信号可不可以是模拟信号,还是必须把模拟信号转换为PWM信号才行
