51汇编代码缩进程序
2379|0
turmary|  楼主 | 2007-3-15 13:30 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
源代码如下.
使用TC或VC均可编译.
可执行程序到
http://tary.any.cn下载
#define NDEBUG
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <ctype.h>
#include <assert.h>
#define MAXLINE 512
#define OPCODE_NUM 52
int divtoken(char linet[]);
int getline(char line[]);
void copy(char to[], char from[]);
int line2upper(char line[], int n);
int addblank(char *line);
int getsign(char linet[], char cpos[], char sign[]);
char* opocur(char linet[], char opcode[]);
int getopcode(char si[], char comment[], char oppart[]);
char *OpCodes[OPCODE_NUM] = {
    "NOP", "MOVX", "MOVC", "MOV",
    "PUSH", "POP", "XCHD", "XCH",
    "SWAP", "ADDC", "DJNZ", "ADD",
    "SUBB", "INC", "DEC", "MUL",
    "DIV", "DA", "ANL", "ORL",
    "XRL", "CLR", "CPL", "RL",
    "RLC", "RR", "RRC", "SETB",
    "ACALL", "LCALL", "RETI", "RET",
    "AJMP", "LJMP", "SJMP", "JZ",
    "JNZ", "JC", "JNC", "JBC",
    "JNB", "JB", "CJNE", "JMP",
    "DATA", "BIT", "EQU", "DS",
    "DB", "DW", "END", "ORG"
main(){
    int len;
    char line[MAXLINE], linet[MAXLINE], *reline;
    printf("%s\n", ";indented by indent51(written by Tary 2006-05-17)");
    do {
        len = getline(line);
        line2upper(line, len);
        copy(linet, line);
        if(divtoken(linet))
            printf("%s\n", linet);
        else
            printf("%s\n", line);
    } while(len >= 0);
    return 0;
int line2upper(char line[], int n){
    int i;
    for (i = 0; i < n && !(line == ';' || line == '\n'); ++i)
        line = toupper(line);
    return 1;
char* opocur(char linet[], char opcode[]) {
    int i, j, ocur = 0;
    char* cp;
    for(i = 0; i < OPCODE_NUM; ++i){
        j = strlen(OpCodes);
        if(NULL != (cp = strstr(linet, OpCodes)) &&
          (cp == linet    || cp[-1] == ':' ||
           cp[-1] == '\t' || cp[-1] == ' ') &&
          (cp[j] == '\t'  || cp[j] == ' '||
           cp[j] == ';'   || cp[j] == '\0' ||
           cp[j] == '\n')) {
            ocur = 1;
            strcpy(opcode, OpCodes);
            break;
    return (ocur ? cp : NULL);
int getsign(char linet[], char cpos[], char sign[]) {
    int i;
    char *si;
    for (i = 0, si = linet; (*si == ' ' || *si == '\t'); ++si);
    if (cpos != si) {
        for (; si < cpos; si++){
            if (*si == ' ' || *si == '\t') continue;
            sign[i++] = *si;
    sign[i++] = '\t';
    sign = '\0';
    return (i-1);
int getopcode(char si[], char comment[], char oppart[]) {
    int ocur = 0;
    char *cpos, *cpcom;
    /* si point to the stoken behind opcode */
    if (*si != '\n') {
        cpos = si;
        if (NULL != (cpcom = strchr(si, ';'))){
            ocur = 1;
            strcat(comment, cpcom);
            while(*--cpcom == '\t' || *cpcom == ' ');
            *(cpcom+1) = '\0';
        if (';' != *(cpos = si)) strcpy (oppart, cpos);
    }else ;
    return ocur;
int divtoken(char linet[]) {
    char *si, *cpos;
    char sign[50] = "\0",
      opcode[10] = {0},
      oppart[MAXLINE] = {0},
      comment[MAXLINE] = "\t\t";
    int cmtocur = 0;
    if (!(cpos = opocur(linet, opcode)))
        return 0;
    getsign(linet, cpos, sign);
    cpos += strlen(opcode);
    for (si = cpos; (*si == ' ' || *si == '\t')
      && *si != '\n'; ++si);
    cmtocur = getopcode(si, comment, oppart);
    strcpy (linet, sign);
    strcat (linet, opcode);
    if (addblank(oppart) > 0) {
        strcat(linet, "\t");
        strcat (linet, oppart);
    if (cmtocur) strcat (linet, comment);
    return 1;
int addblank(char *line){
    char delim[10] = "\t, ", *p;
    char linet[64];
    if (strlen(line) == 0)
        return 0;
    strcpy(linet, strtok(line, delim));
    if (linet[0] == '\0')
        return 0;
    while (p = strtok(NULL, delim)) {
        strcat (linet, ", ");
        strcat (linet, p);
    strcpy(line, linet);
    return 1;
/*read a line and return the length of it*/
int getline(char s[]){
    int c, i;
    for(i = 0; (c = fgetc(stdin)) != EOF && c != '\n'; ++i)
        s = c;
    s = '\0';
    return (c == EOF)? -1: i;
/*copy string from array arg2 to array arg1*/
void copy(char to[], char from[]){
    int i;
    i = 0;
    while((to = from) != '\0')
        ++i;
