大侠帮我看看我的程序哪错了啊?
2845|8
 楼主| 发霉的味道 发表于 2007-3-20 16:38 | 显示全部楼层 |阅读模式
ST, AC, ck, sd, se
#include "IO.H"
/* #define  WRITE  0xA0  ; */
/* #define  READ   0xA1  ; */
void delay ( unsigned int timeM )
{  unsigned  int  con1;
         TH0  = 0x06 ;
         TL0  = 0x06 ;
         TMOD = 0x02 ;
            TF0  = 0 ;
            TR0  = 1 ;
   for ( ; timeM > 0 ; timeM-- )
       { for ( con1=4 ; con1>0 ; )
              if ( TF0 ) {   con1-- ;
                            TF0 = 0;
/* I2C Start */
void startI2C ( void )
{    SDAT = 1 ,SCLK = 1 ;
     someNOP()  ;
     SDAT = 0   ;
     someNOP()  ;
     SCLK = 0   ;
     return ;
/*    stop          */
void stopI2C ( void )
{    SDAT = 0  ,SCLK = 1 ;
     someNOP()   ;
     SDAT = 1    ;
     someNOP()   ;
     return  ;
/*    answer  */
void ackI2C ( bit answer)
{   if ( answer == 0 )  SDAT = 0  ;
    else   SDAT = 1   ;
    SCLK =  1    ;
    someNOP()    ;
    SCLK = 0     ;
   return    ;
/*   test ack */
bit testack ( void )
{      bit ack  ;
    SDAT = 1 ;
    SCLK = 1  ;
    _nop_()  ;
    _nop_()  ;
    if ( SDAT == 1 )  ack = 0 ;
    else  ack = 1  ;
    SCLK = 0  ;
    _nop_()  ;
    _nop_()  ;
   return ( ack ) ;
/*  send byte */
void senddata ( unsigned char sdata )
{  unsigned char bitcount ;
   for ( bitcount = 0 ; bitcount < 8 ; bitcount ++ )
       {     if ( sdata << bitcount & 0x80 )  SDAT = 1  ;
            else  SDAT = 0  ;
            SCLK = 1  ;
            someNOP() ;
            SCLK = 0  ;
    return  ;
/*  receive byte  */
unsigned char receivedata ()
{   unsigned char bitcount , rdata = 0 ;
        {    SCLK = 0  ;
            someNOP() ;
            SCLK = 1  ;
            _nop_() ;
            _nop_() ;
            if ( SDAT == 1 ) rdata = ( rdata << 1 ) + 1  ;
            else  rdata <<= 1  ;
            _nop_() ;
            _nop_() ;
            SCLK = 0  ;
     return ( ( unsigned char ) rdata ) ;
 /*   read data  */
void  Rreceivedata ( unsigned char headadd , unsigned char N , unsigned char *buf )
{   startI2C () ;
    senddata ( 0xa0 ) ;
    testack () ;
    senddata ( headadd ) ;
    testack ()  ;
    startI2C () ;
    senddata ( 0xa1 ) ;
    testack () ;
    for (  ;  N != 0 ; N -- )
        {  *buf = receivedata () ;
           buf ++  ;
           ackI2C ( 0 ) ;
    ackI2C ( 1 ) ;
    stopI2C () ;
    return   ;
/*   write data */
void  Wsenddata ( unsigned char headadd , unsigned char N , unsigned char *buf )
{   startI2C () ;
    senddata ( 0xa0 ) ;
    testack () ;
    testack () ;
    for (  ; N != 0 ; N ++ )
        {   senddata ( *buf ) ;
            while ( testack () == 0 )
            buf ++   ;
     stopI2C ()  ;
     delay ( 10 )  ;
     return  ;
 楼主| 发霉的味道 发表于 2007-3-20 16:45 | 显示全部楼层
{   startI2C () ;
    senddata ( 0xa0 ) ;
{   startI2C () ;
    senddata ( 0xa0 ) ;
这几句不知道为什么总是无法编译,其它语句却可以正常编译.真急死我了.
taoest 发表于 2007-3-21 00:02 | 显示全部楼层
出错信息呢?
出错信息呢?
turmary 发表于 2007-3-21 05:09 | 显示全部楼层
试试这个
#include "AtmelAT89X52.H"
#include "INTRINS.H"
#define someNOP() _nop_();
    _nop_()
#define SDAT P2_0
#define SCLK P2_1
void delay(unsigned int timeM)
    unsigned int con1;
    TH0 = 0x06;
    TL0 = 0x06;
    TMOD = 0x02;
    TF0 = 0;
    TR0 = 1;
    for (; timeM > 0; timeM--) {
        for (con1 = 4; con1 > 0;)
            if (TF0) {
                con1--;
                TF0 = 0;
/* I2C Start */
void startI2C(void)
    SDAT = 1, SCLK = 1;
    someNOP();
    SDAT = 0;
    someNOP();
    SCLK = 0;
    return;
/*    stop          */
void stopI2C(void)
    SDAT = 0, SCLK = 1;
    someNOP();
    SDAT = 1;
    someNOP();
    return;
/*    answer  */
void ackI2C(bit answer)
    if (answer == 0)
        SDAT = 0;
    else
        SDAT = 1;
    SCLK = 1;
    someNOP();
    SCLK = 0;
    return;
/*   test ack */
bit testack(void)
    bit ack;
    SDAT = 1;
    SCLK = 1;
    _nop_();
    _nop_();
    if (SDAT == 1)
        ack = 0;
    else
        ack = 1;
    SCLK = 0;
    _nop_();
    _nop_();
    return (ack);
/*  send byte */
void senddata(unsigned char sdata)
    unsigned char bitcount;
    for (bitcount = 0; bitcount < 8; bitcount++)
        if (sdata << bitcount & 0x80)
            SDAT = 1;
        else
            SDAT = 0;
        SCLK = 1;
        someNOP();
        SCLK = 0;
    return;
/*  receive byte  */
unsigned char receivedata()
    unsigned char bitcount, rdata = 0;
        SCLK = 0;
        someNOP();
        SCLK = 1;
        _nop_();
        _nop_();
        if (SDAT == 1)
            rdata = (rdata << 1) + 1;
        else
            rdata <<= 1;
        _nop_();
        _nop_();
        SCLK = 0;
    return ((unsigned char) rdata);
/*   read data  */
void Rreceivedata(unsigned char headadd, unsigned char N,
          unsigned char *buf)
    startI2C();
    senddata(0xa0);
    testack();
    senddata(headadd);
    testack();
    startI2C();
    senddata(0xa1);
    testack();
    for (; N != 0; N--)
        *buf = receivedata();
        buf++;
        ackI2C(0);
    ackI2C(1);
    stopI2C();
    return;
/*   write data */
void Wsenddata(unsigned char headadd, unsigned char N, unsigned char *buf)
    startI2C();
    senddata(0xa0);
    testack();
    senddata(headadd);
    testack();
    for (; N != 0; N++)
        senddata(*buf);
        while (testack() == 0) {;
        buf++;
    stopI2C();
    delay(10);
    return;
 楼主| 发霉的味道 发表于 2007-3-21 08:53 | 显示全部楼层
不是啊
我的这些IO口已经定义了,在IO.H中,我一直想不明白编译不出错,但是跟踪时,总是不能跟到
{   startI2C () ;             无法设断点
    senddata ( 0xa0 ) ;       无法设断点
这两个函数是进行8个字节连续操作的,其他语句可以正常断点,就是这开头两行,跟不了,试了重写了函数单字节操作没有问题,为什么连续操作就不行呢?
 楼主| 发霉的味道 发表于 2007-3-21 12:33 | 显示全部楼层
我自己顶高点!!
rainbowwrh 发表于 2007-3-21 12:43 | 显示全部楼层
无法设断点??
无法设断点???
可能这两句不是有效的语句, 所以编译器不允许在无效的语句(如注释, 空白的地方)设断点的. 仔细看看是不是其他地方出错了.
nust1996 发表于 2007-3-21 14:17 | 显示全部楼层
无法设断点??
无法设断点??
是因为被优化了,如果程序有错,你就把错误信息发出来啊
 楼主| 发霉的味道 发表于 2007-3-21 14:36 | 显示全部楼层
没有出错信息啊,也没有提示出错.
