4GB的SD卡的初始化没有成功,热心的高手帮忙看看
9607|36
 楼主| zxb1717 发表于 2008-6-10 11:49 | 显示全部楼层 |阅读模式
SD卡, GB, 4G, se, TE
看了很多资料,例程,但还是没有成功,可能哪里出了问题没发现,请大家帮我看看。以下是关键的3个函数,CMD0和CMD55返回的响应是0x01,但ACMD41返回的响应还是0x01,应该是0才对,但是怎么调试都不行,大侠帮看一下吧,先在此谢过了!
BYTE SD_SendCmd(BYTE cmd, BYTE *param, BYTE resptype, BYTE *resp)
    WORD i;                            //所有SD卡命令都是6字节长
    BYTE xdata tmp,rlen,Cmd_Buf[6];
    char j;
    if(cmd == CMD0)
        Cmd_Buf[0] = 0x95;                // 发送CRC校验码,只用于第1个命令(command0=40 00 00 00 00 95)
    else                                    //起始位为0(bit47),传输位为1(bit46)
        Cmd_Buf[0] = 0xFF;
    for(j = 3;j >=0;j --)
        Cmd_Buf[j+1] = param[j];          //param[j]
    Cmd_Buf[5] = (cmd & 0x3F) | 0x40;
    if(cmd == CMD0)                        //先发送74个以上的时钟,为了使SD卡同步
        SET_Slave_select(0);
//        EZUSB_Delay(1);
        for(i=0;i<10;i++)
            SPI_Send_Byte(0xFF);
    else
    SET_Slave_select(2);
                    //片选SPI从机
    SPI_Send_Byte(Cmd_Buf[5]);
    SPI_Send_Byte(Cmd_Buf[4]);
    SPI_Send_Byte(Cmd_Buf[3]);
    SPI_Send_Byte(Cmd_Buf[2]);
    SPI_Send_Byte(Cmd_Buf[1]);
    SPI_Send_Byte(Cmd_Buf[0]);
    i = 0;
    do                                      // 等待响应,响应的最高位为0
    {                                    //Wait for a response,a response is a start bit(zero)
        tmp = 0xFF;
        tmp = SPI_Rec_Byte();            //在没收到响应令牌之前,tmp=0xFF,因此tmp & 0x80==1,
           i++;
    while (((tmp & 0x80) != 0) && (i < SD_CMD_TIMEOUT));    //收到响应以后由于响应最高位是0,因此tmp & 0x80==0
    if (i >= SD_CMD_TIMEOUT)            //超时
//        SPI_CS_Deassert();                //释放总线
        TD_Poll(0x15);
        EZUSB_Delay(2000);
        TD_Poll(tmp);
        EZUSB_Delay(2000);
        return SD_ERR_CMD_TIMEOUT;        // 返回命令超时 return response timeout of command
    rlen = 0;
    switch (resptype)                    //根据不同的命令,得到不同的响应长度
     {                                    //according various command,get the various response length
          case R1:
            case R1B:
            rlen = 1;
        break;
                 case R2:
            rlen = 2;
        break;
           case R3:
            rlen = 5;
        break;
        default:
            rlen = 1;
//            SPI_Send_Byte(0xFF);
            SPI_CS_Deassert();
            return SD_ERR_CMD_RESPTYPE;     // 返回命令响应类型错误 return error of command response type
        break;
//    EZUSB_Delay(1);
    *resp = tmp;
    for (j = rlen - 1; j >= 0; j--)
          SPI_Send_Byte(0xFF);                //resp的最高字节保存响应令牌Rx,其他字节装入0xFF
//        SPI_Send_Byte(0xFF);        // 发送周期的最后发送8clock  at the last recycle,clock out 8 clock
    return SD_NO_ERR;                 // 返回执行成功 return perform sucessfully
//////////复位/////////////
BYTE SD_ResetSD(void)        /////
    BYTE  xdata param[4] = {0,0,0,0},ret,resp;
    ret = SD_SendCmd(CMD0, param, CMD0_R, &resp);    /* 复位命令 command that reset sd card */
    if(ret != SD_NO_ERR)
        return 1;
    if(resp != 0x01)
        TD_Poll(0x11);
        EZUSB_Delay(2000);
        TD_Poll(resp);
        EZUSB_Delay(2000);
        return 1;
    return SD_NO_ERR;
///////////激活/////////////////
BYTE SD_Active(void)
    BYTE xdata param[4] = {0,0,0,0},*resp1,*resp2,ret;
    BYTE xdata i;
     ret = SD_SendCmd(CMD55, param, CMD55_R, resp1);        // 后续命令为一个应用命令
        if (ret != SD_NO_ERR)
               TD_Poll(0x21);
            EZUSB_Delay(2000);
               return ret;                        // command that the followed commnad is a specific application
        if (*resp1 & 0x01 != 1 )    //CMD55响应值是0x01
             TD_Poll(0x22);
            EZUSB_Delay(2000);
//            TD_Poll(*resp);
//            EZUSB_Delay(2000);
             return SD_ERR_CMD_RESP;                    // 响应错误 response is error
    i = 0;
    do                         // 循环发出CMD55+ACMD41, 查询卡的状态
        ret = SD_SendCmd(ACMD41, param, ACMD41_R, resp2);
            TD_Poll(0x23);
            EZUSB_Delay(2000);
               return ret;
        i++;
    }while ((i < 200)&& (*resp2 != 0));/* 如果响应R1的最低位Idle位为1,则继续循环 */
    if (i >= 200)
        TD_Poll(0x24);
        EZUSB_Delay(2000);
        TD_Poll(*resp2);
        EZUSB_Delay(2000);
        return SD_ERR_TIMEOUT_WAITIDLE;                    // 超时,返回错误 time out,return error
    if (*resp2 != 0)
        return SD_ERR_CMD_RESP;                    //响应错误 response is error
    return SD_NO_ERR;        // 读出寄存器内容 read the content of the register
xwj 发表于 2008-6-10 11:59 | 显示全部楼层
呵呵,其实最快捷的方法是用逻辑分析仪看看别人是怎么做
当然,前提是有别人先做好的:-)
 楼主| zxb1717 发表于 2008-6-10 12:10 | 显示全部楼层
请热心的大侠帮忙看看
我的初始化时钟大约在150K,应该够慢了,再慢的100K也试了,还是返回0x01
 楼主| zxb1717 发表于 2008-6-10 13:14 | 显示全部楼层
难道没有高手做过类似的项目吗
帮帮忙高手们,给个建议吧
 楼主| zxb1717 发表于 2008-6-10 15:40 | 显示全部楼层
难道没有人做过吗
自己顶起来,等待中......
古道热肠 发表于 2008-6-10 15:53 | 显示全部楼层
给您一个建议
别上来就弄4G的SD卡,先整个512K的SD卡测试一下,看看您的驱动程序能否用起来,小容量的SD卡驱动能用的很好找,可以参考一下网友"章其波"先生的例程
if(容量<512K测试OK)
您的驱动要改一改,作兼容性更改,(印象中2G以内是一个模式,2G以上是另外一套模式[命令]了)
else
您的驱动彻底不能用
 楼主| zxb1717 发表于 2008-6-10 16:07 | 显示全部楼层
先谢谢古道热肠
手头没有512K啊,只有一个2G和一个4G的。能否说的稍微详细一点,2G以上是什么模式,继续等待中......
 楼主| zxb1717 发表于 2008-6-10 16:10 | 显示全部楼层
请问哪里有"章其波"先生的例程?
能否告诉我哪里有"章其波"先生的例程。百度上搜都不是
xujunchen 发表于 2008-6-10 16:26 | 显示全部楼层
与容量大小无关!
 楼主| zxb1717 发表于 2008-6-10 16:34 | 显示全部楼层
再问一下用SPI是否可讀寫SDHC的卡C
我的4G的KingSton的SDHC card,用SPI能进行读写操作吗?
 楼主| zxb1717 发表于 2008-6-10 17:11 | 显示全部楼层
自己顶,继续等
 楼主| zxb1717 发表于 2008-6-10 17:13 | 显示全部楼层
关于发送74个同步时钟的问题
网上给出的例程中,有的发送74个同步时钟时片选是关掉的,而有的是使能的,请问谁知道到底是关掉还是使能啊?
wlsui 发表于 2008-6-10 18:51 | 显示全部楼层
4G及4G以上的卡采用的是SDHC协议(SD2.0),
4G及4G以上的卡采用的是SDHC协议(SD2.0),而2G及2G以下的卡采用的是SD1.0协议,两者协议略有不同
所以,如果你要想读写4G卡,必须要先对SD1.0的驱动做些改动
 楼主| zxb1717 发表于 2008-6-10 19:42 | 显示全部楼层
多谢wlsui
但是不知道哪里能找到SDHC协议(SD2.0),网上的都是SD1.0的,能否请wlsui提示一下怎么改动,你有SDHC协议(SD2.0)吗,有的话能否给我一份,谢谢。谢谢大家关注,我实在是没办法了
 楼主| zxb1717 发表于 2008-6-10 20:16 | 显示全部楼层
顺便再问一下,SD卡内部的地址分配情况
如果要读取大小为2G的SD卡内部开始的512字节,地址是不是:0x00000000~~0x000001FF
huangqi412 发表于 2008-6-10 20:47 | 显示全部楼层
大容量的不同
 楼主| zxb1717 发表于 2008-6-10 21:06 | 显示全部楼层
能否请huangqi412说的详细一点
不同在什么地方,比如2G和4G的,如果都是从一开始写512字节,差别在什么地方
 楼主| zxb1717 发表于 2008-6-11 08:50 | 显示全部楼层
各位路过的大侠帮忙看看吧
在此谢过各位了,指点指点吧
 楼主| zxb1717 发表于 2008-6-11 10:29 | 显示全部楼层
SDHC card 的协议谁有能给我一份吗
 楼主| zxb1717 发表于 2008-6-11 10:37 | 显示全部楼层
找到SD2.0协议了,谁要用我发给他
其他的问题希望其他大侠帮忙解答,照顾一下菜鸟吧,谢谢
