IC介绍CS6709芯片解密特征技术
1632|1
 楼主| pcbqc 发表于 2013-3-25 11:14 | 显示全部楼层 |阅读模式
CS6709 Features:
  Rise/fall time < 1ns
  Maximum programmable 80mA modulation current
  Maximum programmable 100mA bias current
  Maximum 2V laser diode forward voltage
  Differential PECL inputs
  Modulation current compensation to track the temperature dependence of the laser diode output power level
  Automatic Power Control circuitry
  Operation Temperature Range: -40C~+85C
  Supports both 3.3V and 5V operation
  24-pin SSOP, 32-pin QFN packages and die available
  Green packages available
  有CS6709芯片解密需求者请与我们联系咨询更多芯片解密详情与解密报价信息
ifpga 发表于 2013-3-25 11:29 | 显示全部楼层
个人签名:专业抄板技术www.pcbqc.com
17
