C8051F410单片机485通讯一直接收0
2146|2
 楼主| gluebi 发表于 2013-3-28 10:04 | 显示全部楼层 |阅读模式
单片机是SILICON的8051F410,MAX485芯片
代码和电路图如下,程序功能是当上位机通过串口有东西发下去时,单片机会进入接收中断返回对应的值
问题是我上位机还没发东西下去,单片机就不断返回给我SBUF0的值,而且都是0
一开始分析是485芯片A,B两点间按图中所连的电压差大于0.2V导致MAX485芯片RO输出为0,但是把R9去掉以后
还是一样不停接收0,求各位大牛看看到底问题出在哪里了,感激不尽
ps:是否需要给RX增加内部弱上拉?
#include <c8051F410.h>
#define SYSCLK 24500000
#define BAUDRATE 9600
unsigned char UART_Buffer[64];
unsigned char UART_Data=0;
unsigned char Byte;
unsigned char temp;
sbit comm=P0^7;
sbit LASER=P2^6;
//P0.4 digital push_pull UART TX
//P0.5 digital open_drain UART RX
void PORT_Init(void)
        //P2MDout=0x00;
        P0MDOUT|=0x90;          // Enable UTX as push-pull output
        XBR0=0X01;              // Enable UART on P0.4(TX) and P0.5(RX)
        XBR1=0X40;              // Enable crossbar and weak pull-ups
void SYSCLK_Init (void)
        OSCICN=0X87;            // Configure internal oscillator for 24.5MHz
        RSTSRC=0X04;                        // Enable missing clock detector
// Configure the UART0 using Timer1, for <BAUDRATE> and 8-N-1.
void UART0_Init(void)
        SCON0 = 0x10;                         // SCON0: 8-bit variable bit rate
                                                        // level of STOP bit is ignored
                                                        // RX enabled
                                                        // ninth bits are zeros
                                                        // clear RI0 and TI0 bits
        TH1 = 0x96;
        CKCON &= ~0x0B;
        TL1 = TH1;                                 // init Timer1
        TMOD &= ~0xf0;                         // TMOD: timer 1 in 8-bit autoreload
        TMOD |= 0x20;
        TR1 = 1;                                 // START Timer1
        IP |= 0x10;                                 // Make UART high priority
        ES0=1;
void UART0_Interrupt(void)interrupt 4
        //char i;
        if (RI0==1)
                RI0=0;
                Byte=20;                                // Clear interrupt flag
                temp=SBUF0;                        // Read a character from UART
                comm=0;
                LASER=0;
void main(void)
        unsigned int i, j;
        PCA0MD &= ~0x40;              // WDTE = 0 (clear watchdog timer enable)
        PORT_Init();                         // Initialize Port I/O
        SYSCLK_Init ();                         // Initialize Oscillator
        UART0_Init();
        EA=1;
        temp=10;
        LASER=1;
        comm=0;
           UART_Data=0;
        UART_Data=14;
        Byte=1;
        comm=0;
        while(1)
                if(Byte==20)
                        for (i=0; i<UART_Data; i++)
                                UART_Buffer=temp;
                         comm=1;
                        for(i=0;i<14;i++)
                                SBUF0 = UART_Buffer;
                                while(!TI0);
                                TI0 = 0;
                        Byte=1;
                        comm=0;
XZL 发表于 2013-3-28 15:43 | 显示全部楼层
呵呵,先看看电路有没有接错,A,B及R/T选择有没有错
jiaxinhui 发表于 2013-4-1 16:00 | 显示全部楼层
图看不见
