sst29sf040不是flash吗,为什么当作数据存储器时掉电数据会丢失
3497|1
 楼主| ccjchen 发表于 2007-9-24 20:09 | 显示全部楼层 |阅读模式
sst29sf040不是flash吗,为什么我把它当作数据存储器时一掉电数据就会丢失呢?
sst29sf040的A0-A7接74ls373的输出,74373集成在CPLD中,没画出来,A8-A14接AT89C52的P20-P26,而A15-A18接地,因为我用不到那么大的空间,而其片选端CE接AT89C52的P27
void  ByteProgram(uchar data SrcByte,uint Dst)
    XBYTE[0x0555] = 0xAA;
    XBYTE[0x02AA] = 0x55;
    XBYTE[0x0555] = 0xA0;
    XBYTE[Dst]   = SrcByte;
    wait(1,9);//等待25us
int Erase_One_Sector(uint Dst)
        /*  Issue the Sector Erase command to 39SF040   */
        XBYTE[0x0555] = 0xAA; /* set up address to be 555h    */
                             /* write data 0xAA to the address     */
        XBYTE[0x02AA] = 0x55; /* set up address to be 2AAh    */
                             /* write data 0x55 to the address     */
        XBYTE[0x0555] = 0x80; /* set up address to be 555h    */
                             /* write data 0x80 to the address     */
        XBYTE[Dst]   = 0x20; /* set up starting address to be erased */
                             /* write data 0x30 to the address     */
        wait(85,134);        /* check DATABOOK for the most  */
                             /* accurate value -- Tse        */
uchar ByteRead(uint addr)
    uchar GetData;
    GetData = XBYTE[addr];
    return(GetData);
void sst_save()//用于保存易丢失数据
     uchar i;
    Erase_One_Sector(128);
           for(i=0;i<4;i++)
              ByteProgram(syn[2*i+1],0x0080+i);
              syn[2*i+1]=ByteRead(0x0080+i);
void main()
   sst_save();我 在程序中改变syn 的值未写出,为什么我一断电,syn 的值还是原来的赋的初值呢?
 楼主| ccjchen 发表于 2007-9-25 18:20 | 显示全部楼层
难道没人用过sst29sf040吗?
