求助!!!!verilog实现解码
1246|3
 楼主| djdj14 发表于 2013-7-31 16:44 | 显示全部楼层 |阅读模式
module sender_module(clk,rstn,load,code);
input clk;
input rstn;
output load;
output [3:0]code;
reg rload;
reg [3:0]code;
reg[1:0]count;
always@(posedge clk or negedge rstn)
        if(!rstn)
                count<=0;
        else if(count==3)
                count<=0;
        else
                count<=count+1'b1;
        if(!rstn)
                rload<=1'b0;
        else if(count==0)
        begin
                         rload<=1'b1;
        end
        else if(count>=1 && count<=3)
                rload<=1'b0;
assign load=rload;
reg [3:0]state;
        if(!rstn)
                state<=4'b0001;
        else if(load==1'b1)
        case(state)
                4'b0001: begin code<=4'b1111;state<=4'b0010; end
                4'b0010: begin code<=4'b0110;state<=4'b0100; end
                4'b0100: begin code<=4'b0101;state<=4'b1000; end
                4'b1000: begin code<=4'b0100;state<=4'b0000; end
                4'b0000: begin code<=4'bxxxx;end
                default:  state=4'b0001;
        endcase
        else if(load==1'b0)
                code<=4'bxxxx;
endmodule
`timescale 1 ps/ 1 ps
module sender_module_vlg_tst();
// constants
// general purpose registers
//reg eachvec;
// test vector input registers
reg clk;
reg rstn;
reg rload;
// wires
wire load;
wire [3:0]  code;
assign #1 load=rload;
// assign statements (if any)
sender_module i1 (
// port map - connection between master ports and signals/registers
        .clk(clk),
        .code(code),
        .load(load),
        .rstn(rstn)
initial
begin
// code that executes only once
// insert code here --> begin
// --> end
clk=0;
rstn=1;
#7 rstn=0;
#5 rstn=1;
$display("Running testbench");
end
always   #5 clk=~clk;
// optional sensitivity list
// @(event1 or event2 or .... eventn)
// code executes for every event on sensitivity list
//@eachvec;
// --> end
endmodule
求帮忙看看,为什么没有输出,不胜感激,这个问题已经卡了快一个礼拜了,非常感谢!
huangxz 发表于 2013-7-31 17:11 | 显示全部楼层
先仿真一下啊
GoldSunMonkey 发表于 2013-7-31 20:35 | 显示全部楼层
先仿真,一点点找原因
不能太着急啊。
