[AVR单片机] 只有延时服务的协作式的内核,Error: garbage at end of line
1979|5
 楼主| searover79 发表于 2013-9-7 16:42 | 显示全部楼层 |阅读模式
#include <avr/io.h>
#include <avr/interrupt.h>
//#include <avr/signal.h>
#include "config.h"
unsigned char Stack[200];
register unsigned char OSRdyTbl          asm("r2");    //任务运行就绪表
register unsigned char OSTaskRunningPrio asm("r3");    //正在运行的任务
#define OS_TASKS 3                    //设定运行任务的数量
struct TaskCtrBlock           //任务控制块
  unsigned int OSTaskStackTop;  //保存任务的堆栈顶
unsigned int OSWaitTick;      //任务延时时钟
} TCB[OS_TASKS+1];
//防止被编译器占用
register unsigned char tempR4  asm("r4");
register unsigned char tempR5  asm("r5");
register unsigned char tempR6  asm("r6");
register unsigned char tempR7  asm("r7");
register unsigned char tempR8  asm("r8");
register unsigned char tempR9  asm("r9");
register unsigned char tempR10 asm("r10");
register unsigned char tempR11 asm("r11");
register unsigned char tempR12 asm("r12");
register unsigned char tempR13 asm("r13");
register unsigned char tempR14 asm("r14");
register unsigned char tempR15 asm("r15");
register unsigned char tempR16 asm("r16");
register unsigned char tempR17 asm("r17");
//建立任务
void OSTaskCreate(void (*Task)(void),unsigned char *Stack,unsigned char TaskID)
  unsigned char i;
  *Stack--=(unsigned int)Task>>8;    //将任务的地址高位压入堆栈,
  *Stack--=(unsigned int)Task;         //将任务的地址低位压入堆栈,
  *Stack--=0x00;                     //R1 __zero_reg__
  *Stack--=0x00;                     //R0 __tmp_reg__
  *Stack--=0x80;                                        //SREG 在任务中,开启全局中断
  for(i=0;i<14;i++)    //在 avr-libc 中的 FAQ中的 What registers are used by the C compiler?
    *Stack--=i;                    //描述了寄存器的作用
    TCB[TaskID].OSTaskStackTop=(unsigned int)Stack;    //将人工堆栈的栈顶,保存到堆栈的数组中
    OSRdyTbl|=0x01<<TaskID;      //任务就绪表已经准备好
//开始任务调度,从最低优先级的任务的开始
void OSStartTask()
  OSTaskRunningPrio=OS_TASKS;
  SP=TCB[OS_TASKS].OSTaskStackTop+17;
  __asm__ __volatile__("reti      nt");
//进行任务调度
void OSSched(void)
   //  根据中断时保存寄存器的次序入栈,模拟一次中断后,入栈的情况
  __asm__ __volatile__("PUSH __zero_reg__         nt");  //R1
  __asm__ __volatile__("PUSH __tmp_reg__          nt");  //R0
  __asm__ __volatile__("IN   __tmp_reg__,__SREG__ nt");  //保存状态寄存器SREG
  __asm__ __volatile__("CLR  __zero_reg__         nt");  //R0重新清零
  __asm__ __volatile__("PUSH R18                  nt");
  __asm__ __volatile__("PUSH R19                  nt");
  __asm__ __volatile__("PUSH R20                  nt");
  __asm__ __volatile__("PUSH R21                  nt");
  __asm__ __volatile__("PUSH R22                  nt");
  __asm__ __volatile__("PUSH R23                  nt");
  __asm__ __volatile__("PUSH R24                  nt");
  __asm__ __volatile__("PUSH R25                  nt");
  __asm__ __volatile__("PUSH R26                  nt");
  __asm__ __volatile__("PUSH R27                  nt");
  __asm__ __volatile__("PUSH R30                  nt");
  __asm__ __volatile__("PUSH R31                  nt");
  __asm__ __volatile__("PUSH R28                  nt");  //R28与R29用于建立在堆栈上的指针
  __asm__ __volatile__("PUSH R29                  nt");  //入栈完成
  TCB[OSTaskRunningPrio].OSTaskStackTop=SP;           //将正在运行的任务的堆栈底保存
  unsigned char OSNextTaskID;                             //在现有堆栈上开设新的空间
  for (OSNextTaskID = 0;                                  //进行任务调度
    OSNextTaskID < OS_TASKS && !(OSRdyTbl & (0x01<<OSNextTaskID));
    OSNextTaskID++);
    OSTaskRunningPrio = OSNextTaskID ;
  cli();  //保护堆栈转换
  SP=TCB[OSTaskRunningPrio].OSTaskStackTop;
  sei();
    //根据中断时的出栈次序
  __asm__ __volatile__("POP  R29                  nt");
  __asm__ __volatile__("POP  R28                  nt");
  __asm__ __volatile__("POP  R31                  nt");
  __asm__ __volatile__("POP  R30                  nt");
  __asm__ __volatile__("POP  R27                  nt");
  __asm__ __volatile__("POP  R26                  nt");
  __asm__ __volatile__("POP  R25                  nt");
  __asm__ __volatile__("POP  R24                  nt");
  __asm__ __volatile__("POP  R23                  nt");
  __asm__ __volatile__("POP  R22                  nt");
  __asm__ __volatile__("POP  R21                  nt");
  __asm__ __volatile__("POP  R20                  nt");
  __asm__ __volatile__("POP  R19                  nt");
  __asm__ __volatile__("POP  R18                  nt");
  __asm__ __volatile__("POP  __tmp_reg__          nt");      //SERG 出栈并恢复
  __asm__ __volatile__("OUT  __SREG__,__tmp_reg__ nt");      //
  __asm__ __volatile__("POP  __tmp_reg__          nt");      //R0 出栈
  __asm__ __volatile__("POP  __zero_reg__         nt");      //R1 出栈
  //中断时出栈完成
void OSTimeDly(unsigned int ticks)
  if(ticks)                             //当延时有效
    OSRdyTbl &= ~(0x01<<OSTaskRunningPrio);
    TCB[OSTaskRunningPrio].OSWaitTick=ticks;
    OSSched();                          //从新调度
void TCN0Init(void)    // 计时器0
  TCCR0A = 0;
  TCCR0A |= (1<<CS02);  // 256预分频
  TIMSK0 |= (1<<TOIE0); // T0溢出中断允许
  TCNT0 = 100;         // 置计数起始值
SIGNAL(SIG_OVERFLOW0)
  unsigned char i;
  for(i=0;i<OS_TASKS;i++)       //任务时钟
    if(TCB.OSWaitTick)
      TCB.OSWaitTick--;
      if(TCB.OSWaitTick==0)     //当任务时钟到时,必须是由定时器减时的才行
        OSRdyTbl |= (0x01<<i);     //使任务在就绪表中置位
  TCNT0=100;
void Task0()
  unsigned int j=0;
  while(1)
    PORTB=j++;
    OSTimeDly(2);
void Task1()
  unsigned int j=0;
  while(1)
    PORTC=j++;
    OSTimeDly(4);
void Task2()
  unsigned int j=0;
  while(1)
    PORTD=j++;
    OSTimeDly(8);
void TaskScheduler()
  while(1)
     OSSched();//反复进行调度
int main(void)
  TCN0Init();
  OSRdyTbl=0;
  OSTaskRunningPrio=0;
  OSTaskCreate(Task0,&Stack[49],0);
  OSTaskCreate(Task1,&Stack[99],1);
  OSTaskCreate(Task2,&Stack[149],2);
  OSTaskCreate(TaskScheduler,&Stack[199],OS_TASKS);
  OSStartTask();
这个一个网上关于AVR单片机的只有延时服务的协作式的内核,使用at90can128单片机,AVR Studio4编译时出现错误:
C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp/ccs0dVB1.s:292:Error:garbage at end of line.
请问该怎么解决?
qin552011373 发表于 2013-9-7 23:55 | 显示全部楼层
不是你自己写的啊
john_lee 发表于 2013-9-8 23:34 来自手机 | 显示全部楼层
嵌入汇编语法错误,那些“nt”,应该是“\n\t”
 楼主| searover79 发表于 2013-9-9 21:44 | 显示全部楼层
不是你自己写的啊
嗯,我还没达到这个水平,还在学习
 楼主| searover79 发表于 2013-9-9 21:45 | 显示全部楼层
李老师威武,谢谢
