VHDL 语法求解
2009|0
 楼主| damoyeren 发表于 2013-10-15 17:18 | 显示全部楼层 |阅读模式
Error (10482): VHDL error at bell.vhd(21): object "clk_in" is used but not declared
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_unsigned.all;
use ieee.std_logic_arith.all;
entity bell is
        port(clk_in:in std_logic;
                 reset:in std_logic;
                 fengming:out std_logic);
end bell;
architecture behave of fenpin is
        signal clk_temp:std_logic;--蜂鸣器驱动时钟信号
        signal pre_div:std_logic_vector(15 downto 0);--装预置分频数
        component fenpin is
        port(clk:in std_logic;
                 clk_out:out std_logic);
    end component;
begin
        gen_10M:fenpin port map (clk=>clk_in,clk_out=>clk_temp);
        process(clk_temp)
        variable cnt1:std_logic_vector(15 downto 0):=X"0000";--分频计数器
        variable cnt2:integer range 0 to 7000:=0;              --蜂鸣时间
        begin
                fengming<=clk_temp;                               --蜂鸣输出
                if reset='0'then                                  --复位时
                cnt1:='0';
                cnt2:='0';
                pre_div<="12a2";
                if rising_edge(clk_temp) then                     --时钟上升沿到来时
                        if cnt1=12a2 then
                        cnt1:=x"0000";
                        clk_temp<=not clk_temp;
                        cnt2:=cnt2+1;
                                if cnt2=1000 then                         --响500个时钟
                                pre_div<=109b;
                                elsif cnt2=2000 then
                                pre_div<=ecb;
                                elsif cnt2=3000 then
                                pre_div<=dfd;
                                elsif cnt2=4000 then
                                pre_div<=c74;
                                elsif cnt2=5000 then
                                pre_div<=b18;
                                elsif cnt2=6000 then
                                pre_div<=9e2;
                                elsif cnt2=7000 then
                                pre_div<=12a2;
                                end if;
                        else
                        cnt1:=cnt1+1;
                        end if;
                end if;
        end if;
        end process;
end behave;
